Loading...
Pages: [1]   Go Down
Author Topic: Why is my variable loosing its value?  (Read 228 times)
Offline Offline
Newbie
View Profile
I'm working with this code, I think there is still something wrong with the formula but anyway It's not about the formula its about the variable ContR. By principle I should be able to use it as lcd.print(ContR) on the last line of my program but for some reason it won't work so I just make a work around by copying its value to another variable.
Code:
int test;
    float dRes;
    float RefV=5.00;
    float ContR;
    float dContR
    test=analogRead(A0);
    dRes=map(test, 0, 1023, 0, 6000);//Map A/D digital data. 6V max
    dRes=(dRes/1000);//To down scale reading to proper value
    if (RefV>dRes){//Do only if there was a voltage drop
    dRes=(RefV-dRes);//Get the voltage drop
    ContR=(dRes/(RefV/10000));//R1=V1/(V2/R2))
    dContR=ContR; //copying the value to another variable (my work arround so it would work with my LCD Display)
    Serial.println(ContR); //<---- OK! displays the right value
//more code here but not relevant, ContR variable was never used again only the dRes variable was reused here.
    Serial.println(ContR);// <---- Displays 0
    lcd.println(ContR);// <---- Displays 0
    lcd.print(dContR);// <---- OK! displays the right value
Could this be a bug?
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
We need to see the whole sketch.
Logged
Offline Offline
Full Member
View Profile
I have no idea why your code was working, and this probably has nothing to do with the problem, but
Code:
float dContR
Should be
Code:
float dContR;
Logged
nr Bundaberg, Australia
Online Online
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Code:
float dContR
That would not even compile.
_____
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
'round the world...
Offline Offline
Edison Member
View Profile
WWW
Code:
Have you tried using the same instructions for both variables? Or maybe change the order you use them?
Like
Code:
   Serial.println(dContR);// <---- Displays 0
    lcd.println(dContR);// <---- Displays 0
    lcd.print(ContR);// <---- OK! displays the right value
Or
Code:
    lcd.print(ContR);// <---- Displays 0
Logged
Eu não sou o teu criado. Se respondo no fórum é para ajudar todos mediante a minha disponibilidade e disposição. Responder por mensagem pessoal iria contra o propósito do fórum e por isso evito-o.
Se realmente pretendes que eu te ajude por mensagem pessoal, então podemos chegar a um acordo e contrato onde me pagas pela ajuda que eu fornecer e poderás então definir os termos de confidencialidade do meu serviço. De forma contrária toda e qualquer ajuda que eu der tem de ser visível a todos os participantes do fórum (será boa ideia, veres o significado da palavra fórum).
Nota também que eu não me responsabilizo por parvoíces escritas neste espaço pelo que se vais seguir algo dito por mim, entende que o farás por tua conta e risco.
Dito isto, mensagens pessoais só se forem pessoais, ou seja, se já interagimos de alguma forma no passado ou se me pretendes convidar para uma churrascada com cerveja (paga por ti, obviamente).
Pages: [1]   Go Up
Print
Jump to:
