Topic: Revolutions Per Minute Calculating Error (Read 5379 times) previous topic - next topic
mykiscool
Jun 19, 2012, 01:59 am Last Edit: Jun 19, 2012, 02:01 am by mykiscool Reason: 1
Can someone please help me with this code. It is supposed to detect the revolutions per second on a bicycle wheel and then convert it to revolutions per minute. The magnetic sensor code works fine, the timer resets itself when it passes by, but no matter what speed or increment of time i wait to pass the magnet by again, it only comes up with 2 readings 5,000 and 6,000, which are not goods revolution per second readings. I expect to get some number like 230.14 or something random like that. My code is below. Any help is appreciated.
//these are just some references for it to work properly
#include <StopWatch.h>
#include <LiquidCrystal.h>
//these are the microcontroller ports that an lcd screen is connected to, a status led, and the switch.
LiquidCrystal lcd(12, 11, 7, 6, 5, 4);
#define LED 13 //pin for the LED indicator (green)
#define Reed 3 //pin for the switch
//create a timer
StopWatch MySW;
//state of sensor 1 or 0
byte reedState=0;
//time between pass of magnet
float timeSincePass=0;
//revolutions per second
float RPS=0;
//revolutions per minute
float RPM=0;
//just some setup stuff
 pinMode(LED,OUTPUT);
 pinMode(Reed,INPUT);
 lcd.begin(16, 4);
 lcd.print("Your Revs/Sec");
 //get the state of the sensor
 reedState=digitalRead(Reed);
 //time since pass of magnet
 timeSincePass= MySW.elapsed();
 //set the lcd cursor to write on the second line
 lcd.setCursor(0, 1);
//if the magnet engages the switch
 if (reedState==HIGH)
   //turn on status led for visual purposes
   digitalWrite(LED, HIGH);
   //convert milliseconds to seconds
   RPS=(float)timeSincePass*1000;
   //reset the timer storage int
   timeSincePass=0;
   //reset the timer and start it again
   MySW.reset();
   MySW.start();
   //turn off led otherwise
   digitalWrite(LED, LOW);
 //convert seconds to minutes
 RPM=(float)RPS*60;
 //print the results to a screen
 lcd.print(RPS);
 lcd.print("  ");
 lcd.print(timeSincePass);
Technician at Yuneec Electric Aviation
marco_c
It is possible that you are counting multiple times each time the sensor is triggered, as the code will execute very fast.
You need to include some form of trigger detection. This is done by remembering if the digital input was low or high the last time you checked and only counting the low to high (or high to low) transitions.
A relatively straightforward way to do this is to use an interrupt that will be triggered on the transition only - there is lots of stuff on hte board on how this can be done.
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
mykiscool
Ok thanks that's a good idea. Ill look into it and get back to you if it doesn't work.
jraskell
You convert milliseconds to seconds by dividing by 1000, not multiplying by 1000.
Then RPS is 1 / time for 1 revolution (I assume that's your timeSincePass value).
James C4S
It is also a good practice to make your constants match the kind of math you are doing.  "1000" is an integer constant.  "1000.0" is a float constant.
marco_c
#5
Jun 19, 2012, 04:12 am Last Edit: Jun 19, 2012, 05:02 am by marco_c Reason: 1
I also don't see any of the logic that I would expect in this code.
There are 2 ways to do this:
1. Count how long it takes for one revolution (sec/rev) and then take the reciprocal to get rev/sec. You will probably count ms so a conversion will be required.
2. Count the number of 'clicks' in a second (or partial second) and then use the count directly.
What was your intention here?
mykiscool
My intention was to measure the speed of a bike wheel as it turns in revolutions per second or minute and then calculate that to the actual speed using the wheel size. Also I tried using a debounce to make sure I wasn't getting the magnetic reed giving me 2 readings and I still have the same thing not the right reading. Any suggestions?
mykiscool
I sort of made it into a reciprocal when I divided 1000 by the milliseconds which would be the same as dividing 1 by the seconds. Ex: 5 seconds = 5/1 1 divided by 5 = 1/5 opposite of 5/1. I think the math is right as far as i can tell. Constructive criticism would be appreciated to help me find the right solution.
Nick Gammon
More info:
mykiscool
Here's my updated code to include a debounce:
//create a timer
StopWatch MySW;
byte reedState=0;
float RPS=0;
float RPM=0;
//last state of reed switch on or off
byte lastReedState=LOW;
long lastDebounceTime = 0;
long debounceDelay = 50;
  lcd.begin(16, 4);
  byte reading = digitalRead(Reed);
  //get the state of the sensor;
  if (reading != lastReedState)
    // reset the debouncing timer
    lastDebounceTime = millis();
    if ((millis() - lastDebounceTime) > debounceDelay)
    // whatever the reading is at, it's been there for longer
    // than the debounce delay, so take it as the actual current state:
    reedState = reading;
    timeSincePass=0;
    MySW.reset();
    MySW.start();
  RPM=(float)RPS*60;
  lcd.print(RPS);
  lcd.print("  ");
  lastReedState = reading;
jraskell
I don't see any divisions anywhere.
mykiscool
Ooops sorry I thought I made that division change that he suggested Ill change it and get back to you.
mykiscool
Ok now I'm getting somewhat more realistic numbers like 200 and 250 revs per second, but still those are the only 2 readings I'm getting.
//create a timer
StopWatch MySW;
byte reedState=0;
float RPS=0;
float RPM=0;
  lcd.begin(16, 4);
    RPS=(float)1000/timeSincePass;
    timeSincePass=0;
    MySW.reset();
    MySW.start();
  RPM=(float)RPS*60;
  lcd.print(RPS);
  lcd.print("  ");
GoForSmoke
Just be aware that "wheel size" depends on tire pressure, tire width and load on the wheel as well as the nominal diameter. At 75 psi it will be less than at 90 or 110.
IMO you should make a small solid wheel that the bicycle wheel turns and find the rpms of that.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
jraskell
It's a resolution issue, in this case the resolution of your timer.
milliseconds returns whole millisecond results, so:
1000/4 = 250.
1000/5 = 200.
You'll never get any values between 4 and 5, so you'll never get any results between 250 and 200.
One easy option here is to switch to a higher resolution timer, ie use micros() instead of millis.  You'll need to adjust your calculations appropriately.
