Topic: Odd behavior shiftOut and Servo control (Read 1 time) previous topic - next topic
RazorFly
Jun 19, 2012, 03:40 pm Last Edit: Jun 19, 2012, 03:42 pm by RazorFly Reason: 1
I am having an issue using a button to control LEDs/Servo.
This is what I am attempting:
1) press button Once and is HIGH
      a) "servo moves"
2) release button
    a) "servo moves back"
    b) LEDS in sequence for x then stay lit for 10 seconds\
    c) command sent to reset sequence
This is what is happening
as soon as i press the button the leds light and the delays interfere with the servo movement(becomes jittery).
*** I tried running the && line as an else() statement...same issue
Suggestions would be nice:
#include <Servo.h>
#define clock 3
#define data 2
#define clock2 5
#define data2 4
#define clock3 7
#define data3 6
long interval = 125;
int ledState = LOW;             // ledState used to set the LED
long previousMillis = 0;
int x = 50;
// this constant won't change:
const int  buttonPin = 13;    // the pin that the pushbutton is attached to
const int ledPin = 9;
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;
Servo myservo;  // create servo object to control a servo
const int open= 85;
const int close = 31;
int val;
byte zero = B00000000;
byte one  = B10000000;
byte two   = B11000000;
byte three = B11100000;
byte four  = B11110000;
byte five  = B11111000;
byte six   = B11111100;
byte seven = B11111110;
int y = 150;
 myservo.attach(10);
 pinMode(clock, OUTPUT); // make the clock pin an output
 pinMode(data, OUTPUT); // make the data pin an output3
 pinMode(clock2, OUTPUT); // make the clock pin an output
 pinMode(data2, OUTPUT); // make the data pin an output3
 pinMode(clock3, OUTPUT); // make the clock pin an output
 pinMode(data3, OUTPUT); // make the data pin an output3
 pinMode(8, OUTPUT);
 pinMode(ledPin, OUTPUT);
 Serial.begin (9600);
 unsigned long currentMillis = millis();
 // compare the buttonState to its previous state
 if (buttonState != lastButtonState) {
   // if the state has changed, increment the counter
   if (buttonState == HIGH) {
     // if the current state is HIGH then the button
     // wend from off to on:
     buttonPushCounter++;
      Serial.println (buttonPushCounter);
     myservo.write(open);
if(buttonState == LOW && buttonPushCounter == 1) {
   myservo.write(closeTrap);
   delay(30);
   shiftOut(data, clock, LSBFIRST, one);
   delay(x);
   shiftOut(data, clock, LSBFIRST, two);
   delay(x);
   shiftOut(data, clock, LSBFIRST, three);
   delay(x);
   shiftOut(data, clock, LSBFIRST, four);
   delay(x);
   shiftOut(data, clock, LSBFIRST, five);
   delay(x);
   shiftOut(data, clock, LSBFIRST, six);
   delay(x);
   shiftOut(data, clock, LSBFIRST, seven);
   delay(x);
   shiftOut(data2, clock2, LSBFIRST, one);
   delay(x);
   shiftOut(data2, clock2, LSBFIRST, two);
   delay(x);
   shiftOut(data2, clock2, LSBFIRST, three);
   delay(x);
   shiftOut(data2, clock2, LSBFIRST, four);
   delay(x);
   shiftOut(data2, clock2, LSBFIRST, five);
   delay(x);
   shiftOut(data2, clock2, LSBFIRST, six);
   delay(x);
   shiftOut(data2, clock2, LSBFIRST, seven);
   delay(x);
   shiftOut(data3, clock3, LSBFIRST, one);
   delay(x);
   shiftOut(data3, clock3, LSBFIRST, two);
   delay(x);
   shiftOut(data3, clock3, LSBFIRST, three);
   delay(x);
   shiftOut(data3, clock3, LSBFIRST, four);
   delay(x);
   shiftOut(data3, clock3, LSBFIRST, five);
   delay(x);
   shiftOut(data3, clock3, LSBFIRST, six);
   delay(x);
   shiftOut(data3, clock3, LSBFIRST, seven);
   delay(x);
   digitalWrite(8, HIGH);
   delay(x);
 lastButtonState = buttonState;
 if (buttonPushCounter == 0) {
   shiftOut(data, clock, LSBFIRST, zero);
   shiftOut(data2, clock2, LSBFIRST, zero);
   shiftOut(data3, clock3, LSBFIRST, zero);
   digitalWrite(8, LOW);
   digitalWrite(ledPin, LOW);
   myservo.write(close);
majenko
Simple answer: lose the delays.
You will get much better results by examining the millis() return value and using that for your timing.
RazorFly
Well the delays worked just fine for what i needed before i used a shift register to sequence my leds.
jraskell
Delays work fine when you're trying to do just 1 single task.  Once you start attempting to perform multiple actions, delay() just throws all sorts of wrenches into the works.
Graynomad
The delay() function screws with interrupts, the Servo library uses timer interrupts, put those together and there's a good chance you will have jittery servos.
Are you saying that if you take the exact same code and comment out all the shiftOut() calls the servo doesn't jitter?
______
Rob
RazorFly
#5
Jun 19, 2012, 11:57 pm Last Edit: Jun 20, 2012, 12:06 am by RazorFly Reason: 1
This is what i had...then decided to run a shift register and it worked fine:
#include <Servo.h>
long interval = 1;
int x = 50;
const int  buttonPin = A0;    // the pin that the pushbutton is attached to
const int ledPin = 13;       // the pin that the LED is attached to
// Variables will change:
int lastButtonState = 0;     // previous state of the button
const int open = 85;
int val;
 myservo.attach(1);
 pinMode(buttonPin, INPUT);
 pinMode(2, OUTPUT);
 pinMode(3, OUTPUT);
 pinMode(4, OUTPUT);
 pinMode(5, OUTPUT);
 pinMode(6, OUTPUT);
 pinMode(7, OUTPUT);
 pinMode(8, OUTPUT);
 pinMode(9, OUTPUT);
 pinMode(10, OUTPUT);
 pinMode(11, OUTPUT);
 pinMode(12, OUTPUT);
 pinMode(13, OUTPUT);
 // initialize serial communication:
 // read the pushbutton input pin:
     delay(10);
   else {
     delay(x);
     digitalWrite(2, HIGH);
     delay (x);
     digitalWrite(3, HIGH);
     delay (x);
     digitalWrite(4, HIGH);
     delay (x);
     digitalWrite(5, HIGH);
     delay (x);
     digitalWrite(6, HIGH);
     delay (x);
     digitalWrite(7, HIGH);
     delay (x);
     delay (x);
     digitalWrite(9, HIGH);
     delay (x);
     digitalWrite(10, HIGH);
     delay (x);
     digitalWrite(11, HIGH);
     delay (x);
     digitalWrite(12, HIGH);
     delay (x);
     if(currentMillis - previousMillis > interval) {
       // save the last time you blinked the LED
       previousMillis = currentMillis;
       // if the LED is off turn it on and vice-versa:
       if (ledState == LOW)
         ledState = HIGH;
         ledState = LOW;
       // set the LED with the ledState of the variable:
       digitalWrite(13, ledState);
 if (buttonPushCounter == 2) {
   digitalWrite(2, LOW);
   digitalWrite(3, LOW);
   digitalWrite(4, LOW);
   digitalWrite(5, LOW);
   digitalWrite(6, LOW);
   digitalWrite(7, LOW);
   digitalWrite(9, LOW);
   digitalWrite(10, LOW);
   digitalWrite(11, LOW);
   digitalWrite(12, LOW);
RazorFly
dont know what i did...but it works now.....no changes in code....maybe a loose wire...but thanks for your help.
Thanks as always
Graynomad
That happens, wiggling wires is one of the first debugging techniques.
______
Rob
