Topic: vw_get_message ----- Rx issue (Read 5192 times) previous topic - next topic
leeperrin
Jun 19, 2012, 10:44 pm Last Edit: Jun 21, 2012, 09:28 am by leeperrin Reason: 1
Hi There,
Programming newbie here......
I have a arduino uno setup. Im trying to send a signal between transmitter and receiver.
I have tx on pin 13 and rx on pin 11.
vw have message is true
but vw_get_message(buf, &buflen) is false
the receiver does not seem to be working is there anyway that I can confirm that the receiver works
any help is much appreciated
Code
Code: [Select]
#include <VirtualWire.h>  //TxRx
#include <iostream>
#include <math.h>
#include <TimerOne.h>
#include <ctime.h>
using namespace std;  //using standard library
 //int led_pin_sent = 8; //led test for message sent confirmation
 //int led_pin_receive = 7; //led test for message received confirmation
 int motor1Pin = 9; //motor 1
 int motor2Pin = 10; //motor 2
 int potPin = A0; //potentiometer pin 23 ADC
 int receive_1_pin = 11;  //receiver 1
 int transmit_pin = 13;  //dummy transmitter to act as ball
 byte count =0; //byte stores a 8 bit numerical value without decimals points. 0-255
   TimerOne t;   //declare t as timer1 function for timing receiver to work out distance
                 //this section will be remove
                 //transmiter start with bit speed, in future the ball should start when receiver is in range
 vw_setup(1000); //Bits per sec
 vw_set_tx_pin(transmit_pin);  //set pin 13 for transmiter
 //vw_set_rx_pin(receive_1_pin);  //set pin 11 for receiver 1
 vw_set_ptt_inverted(true); // ?????????
 t.initialize(1000);   //1 second period
//declare IO ports
   pinMode(13,OUTPUT);  //T
   pinMode(11,INPUT);  //R1
   Serial.begin(9600); // sets serial rate for pc monitoring purposes
   Serial.println("receivers active and waiting"); //print line in monitoring
   delay(100);  //delay to allow print to finish
//receiver settings
  vw_rx_start();       // Start the receiver PLL running
  delay(100);    //ms
//temp transister section
 //digitalWrite(led_pin_sent, HIGH);    //led on for message sending
Serial.print("cycle number ");
 Serial.println(count);
 delay(100);  //ms
 Serial.println("message sending");
 delay(100);  //ms
 int i;
 i = count;
 t.restart();   //restart timer value
//testing message send
  const char *msg = "hello";
         vw_send((uint8_t *)msg, strlen(msg));
         delay(400);
 vw_wait_tx(); // Wait until the whole message is gone
 t.start();    //start timer to determine the
 count = count +1;
 if  (vw_send((uint8_t *)msg, strlen(msg)))
    Serial.println("message sent");
 delay(100);  //ms
if (vw_have_message() == 1); //condition to prove message is received
  unsigned int time[] = {0,0,0};
  byte l = 0;
  time[l] = t.read();   //time is seconds
   Serial.println(msg);
   delay(100);
//distance calculation
 int tm;  //time taken
 int d; // distance
   tm = time[l];
 d = 320 * tm; //distance in [m]
 Serial.println("message recieved");
   delay(100);  //ms
 Serial.print("Receiver_1  ");  //show receiver 1 received message and time value
   delay(100);  //ms
 Serial.print(d);
     delay(100);  //ms
 Serial.println(" [m] ");
     delay(100);  //ms
      Serial.print("Time recorded was ");
     delay(100);  //ms
  Serial.println(time[l]);
     Serial.println(" ");
//receiver message
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen))    //check if any messages have been received
  int m;
  Serial.print("got");
  for(m = 0; m < buflen; m ++)
   delay(1000);  //ms
 Serial.println('Receiver_1', t.read());  //show receiver 1 received message and time value
   delay(1000);  //ms
return;
Arrch
Put your code inbetween the code tags, it makes it a lot easier to read.
Have you tried some of the example code that came with VW to confirm that your hardware is working?
leeperrin
Hi
Thank you for the reply.
I will read up on code tags and use it next time.I have looked at a few basic example codes to connect the tx rx and all fail to communicate.
vw_have_message works but get_message stays false which makes me think that the receiver might be faulty.
Arrch
Hi
You should edit your above code to use the code tags in your original post.
If the example code doesn't even work, then that typically points to either a bad module, or incorrect wiring.
leeperrin
What I have noticed and realise that I might not have mentioned is that I am using one Arduino uno board. And the sample code available is in two sections. One for Rx and the other for Tx this to connect two Arduino boards wirelessly. What I am doing is defining an output for the Tx and defining a input for the Rx, could this not be the problem? Or is this possible?
Arrch
Do you have the RX and TX modules hooked up to the same Uno? I doubt that would work.
Could the RX TX I am using be incorrect, here are there specs.
http://www.ebay.co.uk/itm/433Mhz-RF-transmitter-and-receiver-link-kit-for-ARM-MCU-WL-/330748921917?pt=LH_DefaultDomain_2&hash=item4d022c083d#ht_1415wt_933
Link doesn't work.
leeperrin
#7
Jun 21, 2012, 11:08 pm Last Edit: Jun 21, 2012, 11:11 pm by leeperrin Reason: 1
Quote
Link doesn't work.
A part on ebay with this name:
433Mhz RF transmitter and receiver link kit for ARM/MCU WL
Here is another link:
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=m570.l2736&_nkw=433Mhz+RF+transmitter+and+receiver+link+kit+for+ARM%2FMCU+WL
Quote
And yes the Rx and Tx is on the same board. I assumed that by assigning a output for the Tx and a input for the Rx would work. But it feels as if this may well be the problem. Can two Rx units be used on one board? Can they be named differently, meaning vw_set_rx(pin1). This name defines the pin, but does not define the Rx. Is there something like vw_set_rx_[font=Verdana]1[/font](pin1)?
Sorry for bombarding problems
Arrch
I'm not aware of any provisions in the virtual wire library that allow you to hook up multiple RX pins, although I don't see any reason why that would be necessary.
Why don't you give us a broader idea of what you are trying to do?
leeperrin
Im trying to measure the distance between a Tx unit and two Rx units for a application up to 100m as illustrated
             Tx
  Rx1                Rx2
To do this I would lie to time the message received by each Rx unit and form the time I can calculate the distance. So ideally I would like to use one Arduino board for both Rx units, but can move tx unit to another Arduino if need be.
Hope this helps.
