Topic: cheap sound module: what version is this? (Read 63812 times) previous topic - next topic
onesky
mine is not working too
maybe i connected it wrong to the arduino or maybe it doesnt support 5volts or maybe the skecth i used was wrong, or maybe the files must be mp3. There are very few informations on this module combined with arduino.
i used this scheme  (except for the 5v power) to connect it to analog A3 A4 A5arduino pins
the-rebel-agent
#16
Jul 12, 2012, 08:38 pm Last Edit: Jul 12, 2012, 08:40 pm by the-rebel-agent Reason: 1
Will try that this night. I am using these audio files already converted to ad4
http://www.4dsystems.com.au/downloads/Audio-Sound-Modules/SOMO-14D/Docs/AD4-sample-files.zip
Tried mp3 control mode, as I told you via pm and did not work cause the module is hardwired to work 2 serial line mode. I am also using "kingstone" micro sd card brand. I am pretty sure they are fake, but vendor told me that any brand will be fine.
onesky
i also followed the very confusing informations here:
http://emartee.com/product/41540/MP3%20Sound%20Module%20Mini%20SD%20Card
and used this test sketch with the appropriate AD4 sound file loaded on the microsd 1gb card and named 0000.ad4
http://yapan.googlecode.com/svn/trunk/arduino/examples/SOMO_14D_Test/SOMO_14D_Test.pde
but it keeps silent
the-rebel-agent
What about the busy light? What about its behavior?
onesky
i dont remember, i tested weeks ago
we must test all kind of files: wav, ad4, mp3
should connect also the led blinking status on the module to see if it's working
we should know if the connection scheme as showed above is correct (connected to the analog pins of arduino) and if the skecth test is ok
that means we need help
the-rebel-agent
Will test all this night, but I am pretty sure this module will only play certain ad4 and Wav files encoded in the right rate. As read in other websites, this one and somo-14d shares the same IC so connection diagram should be fine, even the sketch program should be correct. Your problem was the Vcc and mine the connection. Keep you posted. We are in the same boat. And If anybody have this working, we will really appreciate any help.
onesky
from the link above i downloaded also this test program, next time i will try this
  Control Arduino Wave
int RST = A3;
int CLK = A4;
int DAT = A5;
    pinMode(RST, OUTPUT);
    pinMode(CLK, OUTPUT);
    pinMode(DAT, OUTPUT);
    digitalWrite(RST, HIGH);
    digitalWrite(CLK, HIGH);
    digitalWrite(DAT, HIGH);
    digitalWrite(RST, LOW);
    delay(5);
    delay(300);
  send(0x0000);
  delay(60000);
  send(0x0001);
  delay(60000);
  send(0x0002);
  delay(60000);
  while(1);
void send(int addr)
  digitalWrite(CLK, LOW);
  delay(2);
  for (int i=15; i>=0; i--)
    delayMicroseconds(50);
    if((addr>>i)&0x0001 >0)
        //Serial.print(1);
         digitalWrite(DAT, LOW);
        // Serial.print(0);
    if(i>0)
    if(i>0)
  delay(20);
onesky
i used the somo tool to create the ad4 file
http://www.4dsystems.com.au/prod.php?id=74
the-rebel-agent
Checking the diagram I noticed that A0, AX, etc are only inputs for arduino. How will this woork that way? I do believe that theconnection diagram is wrong and you should use other pins as outputs.
the-rebel-agent
Did all the test using almost every code available and got a few conclusions. A pins are only analog inputs, so you should use any other digital output ( example: 2,3,4 for reset,clock,data). When I turn on the WTV020-SD-mini-16P, the busy light blinks quickly and after a second of so keeps on. I connected the reset, clock and data and reset the board at the setup portion of the code. You should put the rst pin for 5ms down and later wait 300ms before send any command. I noticed that this guy, was able to do something with the  WTV020-SD-20s board:
http://www.vduenasg.blogspot.com.ar/2012/03/wtv020-sd.html
He modified the clock timing, from 200us to 50us to make it work. So, basically I am pretty sure that now is a software problem with the data and clock pins, since I believe the rst function is working. A out the 3.3v problem, the manual states that you can connect two N4007 diodes in serial from a 5v output power. Did not test it yet. Will be playing with this modified code:
  SOMO-14D Test
  Control a SOMO-14D module to play sounds
  Reference
  http://www.4dsystems.com.au/prod.php?id=73
  Created 20 October 2009
  By Shigeru Kobayashi
const int clockPin = 2;  // the pin number of the clock pin
const int dataPin = 3;  // the pin number of the data pin
const int resetPin = 4;  // the pin number of the reset pin
const unsigned int VOLUME_0 = 0xFFF0;
const unsigned int VOLUME_1 = 0xFFF1;
const unsigned int VOLUME_2 = 0xFFF2;
const unsigned int VOLUME_3 = 0xFFF3;
const unsigned int VOLUME_4 = 0xFFF4;
const unsigned int VOLUME_5 = 0xFFF5;
const unsigned int VOLUME_6 = 0xFFF6;
const unsigned int VOLUME_7 = 0xFFF7;
const unsigned int PLAY_PAUSE = 0xFFFE;
const unsigned int STOP = 0xFFFF;
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(resetPin, OUTPUT);
  digitalWrite(clockPin, HIGH);
  digitalWrite(dataPin, LOW);
  // reset the module
  digitalWrite(resetPin, HIGH);
  delay(100);
  digitalWrite(resetPin, LOW);
  delay(5);
  delay(300);
  sendCommand(VOLUME_7);
  // play "0000.ad4"
  sendCommand(0x0000);
  // play "0001.ad4"
  sendCommand(0x0001);
  // stop playing
  sendCommand(STOP);
void sendCommand(unsigned int command) {
  // start bit
  digitalWrite(clockPin, LOW);
  delay(2);
  // bit15, bit14, ... bit0
  for (unsigned int mask = 0x8000; mask > 0; mask >>= 1) {
    if (command & mask) {
      digitalWrite(dataPin, HIGH);
    else {
    // clock low
    // clock high
  // stop bit
  delay(2);
onesky
at this point i am not even sure wich one is Pin 1
A or B?
the-rebel-agent
Def A is pin # 1. That's the way I tried.
onesky
#27
Jul 13, 2012, 06:31 pm Last Edit: Jul 13, 2012, 06:54 pm by onesky Reason: 1
then my wiring wrong was wrong
now i turned into A
i loaded the sketch
i changed variables into analog
const int clockPin = A4;  // the pin number of the clock pin
const int dataPin = A5;  // the pin number of the data pin
const int resetPin = A3;  // the pin number of the reset pin
i loaded the wav files
0000.wav
0001.wav
i turned on the board and i could listen a sound, very short, distorted and not as original.
but it's a step forward. Now i will try to change wave formats
the-rebel-agent
#28
Jul 13, 2012, 06:46 pm Last Edit: Jul 13, 2012, 06:52 pm by the-rebel-agent Reason: 1
Hurray, good for you. I just heard a small noise. What do you mean you turned the pins to Analog? Are you still using A pins as clock, rst, and dta?
You were using Arduino nano right? Ask you this cause since I am using UNO, will have to put some resistors between rst,clock and dta pins. Cause UNO high value is 5v and I think WTV020-SD-16P is 3.3v.
onesky
i am using the analog pins on Nano as the scheme above
