Loading...
Pages: [1]   Go Down
Author Topic: using the chips  (Read 606 times)
Offline Offline
Newbie
View Profile
I have just purchased a UNO( an UNO?  smiley-confuse).
In a previous life I was the primary PLC programmer for a CNC manufacturing company.
I have succeeded in getting a few programmes to work and am wondering how this can be transferred to a project.
I don't fancy putting the UNO into a project so :-
Is it possible to just build a board, do you call them shields? with the minimum of components on?
Are there any links that would explain the best way to go about this?
Is it possible to run it from 24v? I assume using a 7805 regulator would be the best way.
Could it be done with a smaller chip than the atmega328? would the uno be able to program anything smaller?
I only really want it to run, for the moment, 3 or 4 inputs(digital) and 3 or 4 outputs.
Logged
'round the world...
Offline Offline
Edison Member
View Profile
WWW
Hello,
a shield is something you place on top of an arduino to enhance its functionality (XBee, Ethernet, Motor control, etc...)
Yes, you can make a stand alone board with an arduino chip. that is no problem, all you'd need is a crystal and a few capacitors and power supply. Look for breadboard arduino and you'll get plenty of hits on how to do this.
Regarding the power supply, 7805 with 24V at its input will fry the thing. There are some several chips that you can cascade (to share the power dissipation) or use with a power transistor to regulate that sort of power, but it will always end up regulating by dissipating. If you are serious about the projetc, I think a switched power supply on your board would be better.
The UNO has a sketch that will transform it into a chip programmer. You can then program any chip in the AVR range. You do however, need a bit more knowledge about fuses (not the ones to limit current), AVR-GCC and makefiles (although some of these chips have been adapted to the Arduino IDE). But there are plenty of resources on the internet.
Look for ATmega48 or ATtiny along with Arduino to see what people have been doing.
Some of the times, the problem is not so much the inputs and outputs, but the memory of the chip. Hence a smaller chip, may or may not suit your project.
One interesting board that resembles a lot like a PLC is this one:
http://ruggedcircuits.com/html/ruggeduino.html
« Last Edit: June 20, 2012, 06:45:27 pm by bubulindo » Logged
Eu não sou o teu criado. Se respondo no fórum é para ajudar todos mediante a minha disponibilidade e disposição. Responder por mensagem pessoal iria contra o propósito do fórum e por isso evito-o.
Se realmente pretendes que eu te ajude por mensagem pessoal, então podemos chegar a um acordo e contrato onde me pagas pela ajuda que eu fornecer e poderás então definir os termos de confidencialidade do meu serviço. De forma contrária toda e qualquer ajuda que eu der tem de ser visível a todos os participantes do fórum (será boa ideia, veres o significado da palavra fórum).
Nota também que eu não me responsabilizo por parvoíces escritas neste espaço pelo que se vais seguir algo dito por mim, entende que o farás por tua conta e risco.
Dito isto, mensagens pessoais só se forem pessoais, ou seja, se já interagimos de alguma forma no passado ou se me pretendes convidar para uma churrascada com cerveja (paga por ti, obviamente).
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
http://arduino.cc/playground/Learning/AtmegaStandalone
http://arduino.cc/playground/Learning/Standalone
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Here's a schematic with some notes that will be handy.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Or an Eagle version
Logged
Offline Offline
Newbie
View Profile
thank you for your replies gentlemen, I will be building one of them soon
much appreciated.
Bob.
Logged
Pages: [1]   Go Up
Print
Jump to:
