Topic: Better than bluetooth (Read 7028 times) previous topic - next topic
njdurkin
#15
Jun 23, 2012, 09:32 pm Last Edit: Jun 23, 2012, 09:37 pm by njdurkin Reason: 1
Sorry. I meant to say either a router with a network ethernet cable shield or just an arduino wifi shield alone.
Which wifi shield were you referring to in that post? And what kind of range could I get from it. Say I'm on the third floor of an apartment building and the arduino is on the first floor. Would I have a good connection with the wifi shield?
Thank you for your help florinc
Thank drone creates its own wifi network that has a pretty good range. I want my arduino to create its own wifi network with a good range too but I need more than just line of sight. I need it to go through a wall or two and still have good range.
florinc
Quote
I don't know what the Parrot quadrocopter uses for WiFi.
I personally used the WiFly:
http://dlnmh9ip6v2uc.cloudfront.net/datasheets/Wireless/WiFi/WiFly-RN-XV-DS.pdf
Its range should cover 2-3 floors, I would think, considering its Tx power consumption (about 200mA).
njdurkin
This is probably stupid. But could I increase the range slightly if I had a longer larger higher antenna? OR does the antenna have to be a specific length?
florinc
The antenna is tailored for the frequency (2.4MHz).
Range depends on many things, even the orientation of the antenna.
If your Arduino-based device is not mobile and WiFi is not necessarily required, you should also consider the networking through power lines.
njdurkin
I guess I will just have to buy it and see. Will purchase this tomorrow:
http://www.sparkfun.com/products/10822
florinc
The WiFly you just pointed to has an XBee footprint, therefore requires an XBee shield.
If you want to use it directly with Arduino, consider the WiFly shield:
http://www.sparkfun.com/products/9954
