Loading...
Pages: [1]   Go Down
Author Topic: Error message: avrdude: stk500_getsync(): not in sync: resp=0x00  (Read 2454 times)
Offline Offline
Newbie
View Profile
Hi guys
First of all, Im a noob, so bare with me.
I Just recieved my Arduino yesterday, and have spent all day trying to find a solution for the "avrdude: stk500_getsync(): not in sync: resp=0x00" error message.   smiley-confuse
I know there is a lot of subjects in the forum about this already, but none of the solutions have seemed to work for me.
I run a Windows 64-bit computer and the arduino is a Duemilanove ATmega328.
I followed the tutorial on this site on how to get started. When I plugged in my Arduino board, the drivers where successfully installed automatically.
When I check my devices. It says, that it is working proberly and is on COM3.
I made sure to choose the right board and com port in the software.
I also tried resetting the board manually, before/ and during upload (even though what I read suggests the duemilanove has an automatic re-set function yes?)
But when I press upload the following happens (been trying with the blink example sketch):
the RX blinks 3 times, then a pause for approx 10 sec. then the red L13 will be blinking continously.
The bar in the bottom writes:
Uploading...
Binary sketch size: 1.084 bytes (of a 30.720 byte maximum
and then (with verbose output enabled):
Done uploading
Binary sketch size: 1.084 bytes (of a 30.720 byte maximum)
C:\Users\Asger\Documents\Arduino\arduino-1.0.1\hardware/tools/avr/bin/avrdude -CC:\Users\Asger\Documents\Arduino\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM3 -b57600 -D -Uflash:w:C:\Users\Asger\AppData\Local\Temp\build857580504558195651.tmp\Blink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Users\Asger\Documents\Arduino\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude done.  Thank you.
I also did the loop back test. It worked.
Could it be something with the BAUD rate? (I already tried different options with no success).
And what should the "Tools -> programmer -> " be set to? It was set by default to AVRISP mkII (But what is it?)
Any help will be greatly appreciated! Thanks   smiley
« Last Edit: June 24, 2012, 08:53:28 am by Asger81 » Logged
Austin, TX
Offline Offline
Sr. Member
carpe diem
View Profile
Where did you get the Duemilanove? A link to the one you ordered would help.
It's possible the Duemilanove you have, may have a different bootloader installed. Try setting the board type to UNO to see if it may have the UNO's bootloader installed.
Logged
Offline Offline
Newbie
View Profile
Hi Louis
I bought it as a start kit including some sensors etc. from dealextreme.com ( http://www.dealextreme.com/p/duemilanove-2009-atmega-328p-basic-kits-for-arduino-starters-122866?item=59 )
(Ive been thinking if it is a fake?)
I have tried changing the setting to most of the boards, but with no success  smiley-confuse
« Last Edit: June 24, 2012, 11:33:24 am by Asger81 » Logged
Austin, TX
Offline Offline
Sr. Member
carpe diem
View Profile
That board does not look like an official Arduino board.
This is what it should look like if it was an official Arduino board : http://arduino.cc/en/Main/ArduinoBoardDuemilanove
Logged
Offline Offline
Newbie
View Profile
Ok, I have ordered a new Arduino Uno from ebay.co.uk. Hope I have better luck with that  -  but still odd that I can get it to work.
Thanks for the help anyway!
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
It certainly sounds like a bootloader incompatibility.
What does the verbose log look like when you use board type "Uno" ?  What about "Diecimila with m168" ?  (The idea being to get some information from avrdude other than "I can't communicate at all")
Quote
That setting is only relevant if you're using the "burn bootloader" or "upload using programmer"...
Logged
Offline Offline
Newbie
View Profile
Hi westfa
When chosing Uno, diecimila, duemilanove or nano, it gives me the same message with only the "overriding baud rate" varying.
If I chose the Mega 2560 or Mega ADK the following comes up:
Binary sketch size: 1.632 bytes (of a 258.048 byte maximum)
C:\Users\Asger\Documents\Arduino\arduino-1.0.1\hardware/tools/avr/bin/avrdude -CC:\Users\Asger\Documents\Arduino\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM3 -b115200 -D -Uflash:w:C:\Users\Asger\AppData\Local\Temp\build857580504558195651.tmp\Blink.cpp.hex:i
         Using Programmer              : stk500v2
         Overriding Baud Rate          : 115200
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv:
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: stk500v2_getsync(): timeout communicating with programmer
         AVR Part                      : ATMEGA2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500V2
         Description     : Atmel STK500 Version 2.x firmware
         Programmer Model: Unknown
avrdude: Send: . [1b] . [01] . [00] . [02] . [0e] . [03] . [90] . [85]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
And it seems to never finish..
Does it make any sense to you? (or anybody else reading this).. thanks
Logged
Offline Offline
Newbie
View Profile
And if I choose the Arduino Leonardo, this comes up:
Binary sketch size: 4.858 bytes (of a 28.672 byte maximum)
Forcing reset using 1200bps open/close on port COM3
PORTS {COM3, } / {COM3, } => {}
Uploading using selected port: COM3
C:\Users\Asger\Documents\Arduino\arduino-1.0.1\hardware/tools/avr/bin/avrdude -CC:\Users\Asger\Documents\Arduino\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega32u4 -cavr109 -P\\.\COM3 -b57600 -D -Uflash:w:C:\Users\Asger\AppData\Local\Temp\build857580504558195651.tmp\sketch_jun24b.cpp.hex:i
         Using Programmer              : avr109
         AVR Part                      : ATmega32U4
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
           eeprom        65    10     8    0 no       1024    8      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
         Programmer Type : butterfly
         Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: Send: . [1b]
avrdude: Send: S [53]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: V [56]
avrdude: Recv:
avrdude: Send: v [76]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: p [70]
avrdude: Recv:
Found programmer: Id = "sÿ("; type = ²
    Software Version = E.; Hardware Version = ð.
avrdude: Send: a [61]
avrdude: Recv:
avrdude: Send: b [62]
avrdude: Recv:
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
Thanks..
Logged
Offline Offline
Newbie
View Profile
Just a thought, but have you checked that the chip is correctly inserted?
I think I had the same error message when I had put the chip in the wrong way.
So check that the groove at the top of the chip itself is aligned with the groove in the "holder".
Logged
Offline Offline
Newbie
View Profile
Sadly, yes. The grove is drawed in a white line on the board it self, and they allign.
But in ready to try everything by now - but if I turn the chip around the wrong way, wont it fry?
Logged
Offline Offline
Newbie
View Profile
Well thats too bad, would have been a quick fix. smiley
I don't think it will fry mate, at least mine didn't.
I would also check all the soldering on the card, I once bought a LCD-shield from dx and the quality was dodgy to say the least.
Good luck mate.
Logged
Offline Offline
Newbie
View Profile
Yes, that would have been a nice quick-fix.
Thanks for your input though  smiley
Logged
Offline Offline
Newbie
View Profile
Got my Arduino Uno today! No problems running with that at all.
Thanks a lot for the effort guys - now im off to creating something spectacular! (.. or at least a 'Hello World!' sketch) hahahaha  smiley-lol
Logged
Pages: [1]   Go Up
Print
Jump to:
