Hey guys,
not sure if this is the right place for this question, but it involves an example code so maybe it is.
for a project of mine, of i have an older arduino mega 1280 connected to a blue smirf gold from sparkfun:
http://www.sparkfun.com/products/158however, with the example code provided with arduino 1.0, i can't get anything to show up in the bluetooth serial port(using putty for the bluetooth port)
does anybody have an idea as to why the bluetooth would be seemingly not working? I have the hardware connections exactly as they say in the sample code:
RX(bluesmirf)-->TX(pin 3)(arduino)
TX(bluesmirf)-->RX(pin 2)(arduino)
VCC(bluesmirf)-->3.3v arduino mega
ground-->ground
Software serial multple serial test
Receives from the hardware serial, sends to software serial.
Receives from software serial, sends to hardware serial.
The circuit:
* RX is digital pin 2 (connect to TX of other device)
* TX is digital pin 3 (connect to RX of other device)
created back in the mists of time
modified 9 Apr 2012
by Tom Igoe
based on Mikal Hart's example
This example code is in the public domain.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX, TX
Serial.begin(57600);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.println("Goodnight moon!");
// set the data rate for the SoftwareSerial port
mySerial.begin(4800);
mySerial.println("Hello, world?");
void loop() // run over and over
if (mySerial.available())
Serial.write(mySerial.read());
if (Serial.available())
mySerial.write(Serial.read());
