Loading...
Pages: [1]   Go Down
Author Topic: Looking for advice on CHEAP ardunio compatible Bluetooth Modules  (Read 492 times)
Offline Offline
Jr. Member
View Profile
Hi All
Looking for advice on CHEAP ardunio compatible Bluetooth module - two way communication with PC. Maybe Wireless Serial Port?
I have been looking at EBAY and see some cheap bluetooth devices - but do these work with Ardunio? and are they worth looking at?
http://www.ebay.co.uk/itm/Wireless-Serial-Port-4-Pin-Bluetooth-RF-Transceiver-Module-Backplane-RS232-/261031580546?pt=LH_DefaultDomain_0&hash=item3cc6b1d382
I am wanting to send simple small payloads both ways between a PC with Bluetooth adapter + Ardunio or (similar) with Bluetooth ( and back to the PC)
Does anyone have any expericence with these board, or any boards and what is the cheapest + easiest to work?
My preference would be something that can work with an ATTINY at some point in the future as well.
Chris
Logged
Switzerland
Offline Offline
Faraday Member
View Profile
These modules usually work with Arduino as they are all base on some HC-XX submodule. HC-03/05 are fairly easy to configure and use, flexibility is OK but as most other modules limited to the serial profile.
HC-06 based modules seems to be a bit more limited but I never used such a module, so I have no experience with it.
The problem is, that all versions are sold as JY-MCU so you probably don't know what you get before your hold it in your hands.
ATtiny is not a principal problem if you get your code into the limited flash.
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Those JY-MCU modules are definitely the cheapest for a wireless communication link, but they suck in terms of documentation. You can buy them if you just need to send some data to your PC, but if you want to do anything more, like changing between master and slave mode, have fun! The Bluetooth modules based off the RN-42 such as the BlueSMIRF silver are much easier to use but cost $15 for the bare module and $40 from Sparkfun for a breakout board.
Logged
Pages: [1]   Go Up
Print
Jump to:
