Loading...
Pages: [1]   Go Down
Author Topic: New to PCB design: Need advice. Plus low cost PCB Fab.  (Read 1158 times)
USA, FL
Offline Offline
God Member
A life? Where can I download one of those?
View Profile
This is my first PCB design and would like some advice on it.  Basically it's just a 595 Shift Reg that will control a series of LEDs hooked to an Arduino.
Secondly, would like to know a reputable online source for this PCBs fabrication.  Just need a few boards made.  One problem I am finding with online fabs is that I am using Fritzing for design.  When I export to Gerber files, the online sites don't like them. Can anyone recommend a good site for Fritzing?  I looked at Fritzing for the fab work and they seem expensive.
Any thoughts?
Thanks for reading.
Logged
//LiNK
"The old Europe"
Offline Offline
Edison Member
Bootloaders suck!
View Profile
WWW
I can't see anything unusual with your gerber files. I didn't check for electrical sanity though.
If you only need a small number of boards made, have a look at OSHPARK (formerly Laen's PCB service - dorkbotpdx). Very good quality, but the boards are purple ;-) It costs 5$ per square inch for 3 boards. Everything is US-made if you should care for these things.
Logged
• Upload doesn't work? Do a loop-back test.
• There's absolutely NO excuse for not having an ISP!
• Your AVR needs a brain surgery? Use the online FUSE calculator.
My projects: RGB LED matrix, RGB LED ring, various ATtiny gadgets...
• Microsoft is not the answer. It is the question, and the answer is NO!
USA, FL
Offline Offline
God Member
View Profile
Thanks for the reply.  I did check that site, but I seen they only do 2 or more layers.  Mine is only single-sided.  That was also the site that gave me trouble on the files.  Says I was missing files..
Quote
The following errors were found with your design:
I couldn't identify a top layer
I couldn't identify a top solder mask
Should I just email them?
Logged
//LiNK
"The old Europe"
Offline Offline
Edison Member
Bootloaders suck!
View Profile
WWW
Ah...
Surely you can export an _empty_ top-copper and top-mask layer? Is there a specific reason why your mounting holes are not on both copper layers? That would solve that 'issue'.
Believe me, they don't care if layers are empty ;-)
Logged
USA, FL
Offline Offline
God Member
View Profile
How do I do that in Fritzing?  This is my first design.
Logged
//LiNK
USA, FL
Offline Offline
God Member
View Profile
Ok, I got it.  Had to change the PCB board to Double-Sided...
Thanks
Logged
//LiNK
Pages: [1]   Go Up
Print
Jump to:
