Topic: Analog Multiplexing (Read 2934 times) previous topic - next topic
zeus2kx
Hello,
I am using some sensors with UNO R2 board. Since it has only 6 ADC ports, I am trying to build multiplexer to attach all sensors at once.
Here is the code:
Code: [Select]
#include <SD.h>  //http://www.ladyada.net/products/microsd/
#include <Wire.h>
#include <SPI.h>
int CS_pin = 10;
int SD_led = 8;
#include "floatToString.h"
#include "RTClib.h"
RTC_DS1307 RTC;
float COValue = 0;
float NO2Value = 0;
float O3Value = 0;
float e_NO2Value = 0;
float e_NOValue = 0;
float e_COValue = 0;
float celsius = 0, kelvin=0;
#include <math.h>
int dustPin=0;
int ledPower=2;
int delayTime=280;
int delayTime2=40;
float offTime=9680;
float ZeroPercentVoltage = 0.8;
float val = 0;
float max_voltage = 3.27;
  char date_time[20];
  char CO_Vout[20];
  char NO2_Vout[20];
  char O3_Vout[20];
  char cel[20];
  char e_NO2_Vout[20];
  char e_NO_Vout[20];
  char e_CO_Vout[20];
  char dust[20];
  #include <avr/pgmspace.h>
int _outputserialchar( char c, FILE *t) {
Serial.write( c );
return 1;
  pinMode(4, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  fdevopen( &_outputserialchar, 0);
  Wire.begin();
  SPI.begin();
  Serial.println("Initializing Card");
  pinMode(10, OUTPUT);
  RTC.begin();
  pinMode(ledPower,OUTPUT);
  pinMode(5, OUTPUT);
  if (!SD.begin(CS_pin))
      Serial.println("Card Failure");
      return;
  Serial.println("Card Ready");
  //Write Log File Header
  File logFile = SD.open("ARD1.csv", FILE_WRITE);
  if (logFile)
    logFile.println(", , , , , , , ,"); //Just a leading blank line, incase there was previous data
    String header = "Date_Time, Temp, e_NO2_Vout, e_NO_Vout, e_CO_Vout, CO_Vout, NO2_Vout, O3_Vout, Dust_Vout";
    logFile.println(header);
    logFile.close();
    Serial.println(header);
    Serial.println("Couldn't open log file");
  delay(3000);
//Read Value of 4051 analog-in 5 by setting the values of s0,s1 and s2
  digitalWrite(4, HIGH);
  digitalWrite(6, LOW);
  digitalWrite(7, HIGH);
  delay(3000);
  int readInFive = analogRead(0);
  kelvin = readInFive * 0.004882812 * 100;
  celsius = (kelvin - 273.15) - 5;
  floatToString(cel, celsius, 1);
  //Read Value of 4051 analog-in 1 by setting the values of s0,s1 and s2
  digitalWrite(7, LOW);
  delay(2000);
  int readInOne = analogRead(0);
  val = readInOne;
  digitalWrite(ledPower,LOW);
  delayMicroseconds(delayTime);
  int dust_Vout = analogRead(dustPin);
  delayMicroseconds(delayTime2);
  digitalWrite(ledPower,HIGH);
  delayMicroseconds(offTime);
  floatToString(dust, dust_Vout, 1);
  //Read Value of 4051 analog-in 2 by setting the values of s0,s1 and s2
  digitalWrite(4, LOW);
  digitalWrite(6, HIGH);
  delay(3000);
  int readInTwo= analogRead(0);
  e_NO2Value = readInTwo * 0.004882812;
  floatToString(e_NO2_Vout, e_NO2Value, 8);
  //Read Value of 4051 analog-in 3 by setting the values of s0,s1 and s2
  delay(3000);
  int readInThree= analogRead(0);
  e_COValue = readInThree * 0.004882812;
  floatToString(e_CO_Vout, e_COValue, 8);
  //Read Value of 4051 analog-in 4 by setting the values of s0,s1 and s2
  delay(3000);
  int readInFour= analogRead(0);
  e_NOValue = readInFour * 0.004882812;
  floatToString(e_NO_Vout, e_NOValue, 8);
  NO2Value = analogRead(1) * 0.004882812;
  COValue = analogRead(2) * 0.004882812;
  O3Value = analogRead(3) * 0.004882812;
  floatToString(CO_Vout, COValue, 8);
  floatToString(NO2_Vout, NO2Value, 8);
  floatToString(O3_Vout, O3Value, 8);
  DateTime now = RTC.now();
  sprintf_P(date_time,PSTR("%d/%d/%d %d:%d:%d"),now.day(),now.month(),now.year(),now.hour(),now.minute(),now.second());
  String dataString = String(date_time) + ", " + String(cel) + ", " + String(e_NO2_Vout) + ", " + String(e_NO_Vout) + ", " + String(e_CO_Vout) + ", " + String(CO_Vout) + ", " + String(NO2_Vout) + ", " + String(O3_Vout) + ", " + String(dust_Vout);
  if (logFile)
    logFile.println(dataString);
    logFile.close();
    printf_P(PSTR("%s, %s, %s, %s, %s, %s, %s, %s, %s\r\n"), date_time, cel, e_NO2_Vout, e_NO_Vout, e_CO_Vout, CO_Vout, NO2_Vout, O3_Vout, dust);
    pinMode(SD_led, OUTPUT);
    digitalWrite(SD_led, HIGH);
  delay(15000);
  digitalWrite(SD_led, LOW);
For multiplexing (with 4051) I followed a tutorial on this page http://miscellanea.com/how-to-get-more-arduino-analog-inputs/
My circuit is connected exactly as the photo on the website suggests to.
Problems:
1. This code doesn't write values to the csv file on SD card except for header. Although when I remove the multiplexing part from the code, it does work perfectly (writes data on SD and serial monitor).
2. On serial monitor I see values (but not on SD card). Also, after 5-6 measurement cycles, code stops working.
Kindly help me fix these issues.
Thanks a lot.
Best,
Z
zeus2kx
Grumpy_Mike
You have far too many delays. You do not need them after switching the multiplexer.
You seem to be opening and closing the file without writing any data to it.
You have all the code in the loop() function, try splitting it up into small functions so it is easier to follow.
Try just printing out all your data to the monitor first, get that right before trying to write it to a card.
Learn how to use arrays so you can have a simple way of writing to the multiplexer select line, see:-
http://www.thebox.myzen.co.uk/Tutorial/Arrays.html
Look at the code here for an example of controlling a multiplexer:-
http://www.thebox.myzen.co.uk/Hardware/MIDI_Footsteps.html
Basically start simply, use functions, build up the complexity.
zeus2kx
Thanks for reply, Mike.
Here is my new code:
Code: [Select]
#include <Wire.h>
#include <SPI.h>
#include "RTClib.h"
#include <math.h>
int CS_pin = 10, SD_led = 8;
RTC_DS1307 RTC;
float COValue = 0, NO2Value = 0, O3Value = 0;
float e_NO2Value = 0, e_NOValue = 0, e_COValue = 0;
float celsius = 0;
int dust_Vout = 0, ledPower = 5, delayTime = 280, delayTime2 = 40;
char date_time[15];
char cel[15];
char e_NO2_Vout[15];
char e_NO_Vout[15];
char e_CO_Vout[15];
char dust[15];
char CO_Vout[15];
char NO2_Vout[15];
char O3_Vout[15];
Serial.write( c );
return 1;
int pins [3] = {2, 3, 4};
  for(int i = 2; i<6; i++) pinMode(i, OUTPUT);
  Wire.begin();
  SPI.begin();
  RTC.begin();
  headerW();
  dustsensor();  //Dust sensor
  E_NO2(); //E_NO2 sensor
  E_CO(); //E_CO sensor
  E_NO(); //E_NO sensor
  MOS();
  temperature(); //Temp sensor
  FtoS();
  DnT();
  SDWrite();
void temperature() {
  boolean five [3] = {HIGH, LOW, HIGH};
  for(int i=0; i<3; i++) digitalWrite(pins[i], five[i]);
  delay(1);
  float kelvin = readInFive * 0.004882812 * 100;
void dustsensor() {
  boolean one [3] = {HIGH, LOW, LOW};
  for(int i=0; i<3; i++) digitalWrite(pins[i], one[i]);
  delay(1);
  dust_Vout = analogRead(0);
void E_NO2() {
  boolean two [3] = {LOW, HIGH, LOW};
  for(int i=0; i<3; i++) digitalWrite(pins[i], two[i]);
  delay(1);
void E_CO() {
  boolean three [3] = {HIGH, HIGH, LOW};
  for(int i=0; i<3; i++) digitalWrite(pins[i], three[i]);
  delay(1);
void E_NO() {
  boolean four [3] = {LOW, LOW, HIGH};
  for(int i=0; i<3; i++) digitalWrite(pins[i], four[i]);
  delay(1);
void MOS() {
void FtoS() {
  floatToString(cel, celsius, 2);
void DnT() {
void headerW() {
      return;
  if (logFile)
    logFile.close();
void SDWrite() {
  if (logFile)
    logFile.close();
  delay(29000);
This code shows data on Serial Monitor but doesn't write on SD card except for header and some gibberish.
Here's a link to check the csv file. https://rapidshare.com/files/3321600708/ARD1.CSV
Please suggest where is the problem.
Thanks.
Best,
Z
Grumpy_Mike
Quote
This is probably because you have two totally different ways of writing to the SD card and the serial monitor.
What you want to do is to write out to the monitor EXACTLY the same data as you are writing to the SD card at exactly the same point in the code.
For example:-
Code: [Select]
void SDWrite() {
  if (logFile)
    logFile.close();
    Serial.println(dataString); // testing if the data string is correct
  delay(29000);
Why the very long delay at the end?
zeus2kx
I added
Code: [Select]
Serial.println(dataString); to check and found that there is a problem in dataString. I am sure multiplexing is causing this issue since same code without multiplexing works perfectly.
I am not sure why dataString corrupts during the process. Please help me sort it out.
For writing to SD card I am using same way for both header and dataString. Please check in both functions I have used "logFile.println".
This
Code: [Select]
is only a serial print command to print without consuming much RAM.
30 secs delay is sensor sampling period.
Best,
Z
Grumpy_Mike
Quote
I can't see why that should be.
Take this line:-
Code: [Select]
and print out each variable separately and see if that shows up something wrong.
zeus2kx
Thanks.
I now understand where is the problem.
Static buffer is overrunning.
With this code:
Code: [Select]
#include <Wire.h>
#include <SPI.h>
#include "RTClib.h"
#include <math.h>
RTC_DS1307 RTC;
float celsius = 0;
char date_time[20];
char cel[10];
char e_NO2_Vout[10];
char e_NO_Vout[10];
char e_CO_Vout[10];
char dust[10];
char CO_Vout[10];
char NO2_Vout[10];
char O3_Vout[10];
Serial.write( c );
return 1;
  Wire.begin();
  SPI.begin();
  RTC.begin();
  headerW();
  MOS();
  FtoS();
  DnT();
  SDWrite();
  Serial.flush();
  delay(1);
void dustsensor() {
  delay(1);
void E_NO2() {
  delay(1);
void E_CO() {
  delay(1);
void E_NO() {
  delay(1);
void MOS() {
void FtoS() {
  floatToString(cel, celsius, 0);
  floatToString(dust, dust_Vout, 0);
  floatToString(e_NO2_Vout, e_NO2Value, 5);
  floatToString(e_CO_Vout, e_COValue, 5);
  floatToString(e_NO_Vout, e_NOValue, 5);
  floatToString(CO_Vout, COValue, 5);
  floatToString(NO2_Vout, NO2Value, 5);
  floatToString(O3_Vout, O3Value, 5);
void DnT() {
void headerW() {
      return;
  if (logFile)
    logFile.close();
void SDWrite() {
  //String dataString = String(date_time) + ", " + String(cel) + ", " + String(e_NO2_Vout) + ", " + String(e_NO_Vout) + ", " + String(e_CO_Vout) + ", " + String(CO_Vout) + ", " + String(NO2_Vout) + ", " + String(O3_Vout) + ", " + String(dust_Vout);
  Serial.println(date_time);
  Serial.println(cel);
  Serial.println(e_NO2_Vout);
  Serial.println(e_NO_Vout);
  Serial.println(e_CO_Vout);
  Serial.println(CO_Vout);
  Serial.println(NO2_Vout);
  Serial.println(O3_Vout);
  Serial.println(dust_Vout);
  if (logFile)
    //logFile.println(dataString);
    logFile.close();
    //Serial.println(dataString); // testing if the data string is correct
   // printf_P(PSTR("%s, %s, %s, %s, %s, %s, %s, %s, %s\r\n"), date_time, cel, e_NO2_Vout, e_NO_Vout, e_CO_Vout, CO_Vout, NO2_Vout, O3_Vout, dust);
  delay(29000);
problem is almost solved! except for temperature.
Temperature values are received with minus sign (say -218, -210..). There is no problem with formula used. My other devices (mega board) are working fine with same formula but without multiplexing. How can I solve this issue now?
I could use dynamic memory allocation if I had all code in the main loop (like before) but since now they are defined as functions, dynamic would be not easier to define.
Is there a better way for memory management?
Thanks.
Best,
Z
zeus2kx
Temperature sensor is connected on 5th pin of 4051.
Readings are not changing even though I change to different pin.
I am using LM35 http://www.ti.com/product/lm35.
Readings become 'normal' when I connect it to a separate ADC Arduino pin.
Grumpy_Mike
What is on the inputs you switch to. If nothing then that is your answer, the reading will not change.
Why put all the strings into one long string before writing it to the SD card? You can build up the record by writing the strings one at a time.
zeus2kx
I am sorry I didn't understand your question. Please clarify.
4051 Circuit arrangement:
S0: Digital pin 2 on Arduino
S1: Digital pin 3 on Arduino
S2: Digital pin 4 on Arduino
Pin16: 5V Arduino Pin
Pin 6,7 and 8: GND Arduino
Pin 3: Arduino Pin A0 ADC
Pin 14(i.e. 4051 ADC Pin 1), Pin 15(i.e. 4051 ADC Pin 2), Pin 12(i.e. 4051 ADC Pin 3), Pin 1(i.e. 4051 ADC Pin 4), Pin 5(i.e. 4051 ADC Pin 5): My sensors are connected on them. Temperature sensor is on Pin 5.
Because I want all my sensor values to be in the same row for every measurement.
If I use two separate strings then values would be written differently.
Thanks.
Best,
Z
Grumpy_Mike
Quote
Code: [Select]
logFile.println(myString);
will put stuff on a new line but
Code: [Select]
logFile.print(myString);
Will not.
Quote
You said:-
Quote
So what exactly do you mean by this?
zeus2kx
I mean changing temperature sensor output pin to a different 4051 ADC pin. Currently it is connected to pin5 but I see no difference in reading even though it is connected to Pin6 or 7 or any other. Of course when I change pin, I modify code.
Yes, my bad. logFile.print(dataString); will write in the same line.
I will check it later this evening.
Thanks.
Best,
Z
Grumpy_Mike
Quote
Again I am still not sure what this means.
Is it:-
1) The reading is no different on either pins 5, 6 or 7 and it is what I expect.
2) The reading is no different on either pins 5, 6 or 7 and it shows no change when I increase the temperature of the probe.
3) I only get a correct reading when I use pin 5, when I use pin 6 or 7 there is no change when I increase the temperature of the probe.
zeus2kx
Hi Mike,
It's option 1 and 2.
Readings show -119, -120, 40, -200, so and so. These are random with 90% of negative values. Also, temperature sensor is not faulty at all. When I connect it directly to Arduino ADC pin, it gives correct temp value.
