Although there is a Tutorial called "TelnetClient" under the Ethernet Libraries, it seems, the tutorial does not cover the topic in full. I tried to use Arduino Ethernet as a Telnet client, but got stuck with the negotiation process. After some tries and searches (there is another topic here
http://arduino.cc/forum/index.php/topic,110166.0.html), I tend to think that either the code must handle the negotiation between Telnet server and client, or a library, which supports Telnet negotiation process, is needed. Here's what I've got with Wireshark, when putty Telnet client negotiates with a BusyBox-based Telnet server:
PACKET CONTENTS DESCRIPTION HEX VALUES
CLIENT--
Command: Will Negotiate About Window Size ff fb 1f
Command: Will Terminal Speed ff fb 20
Command: Will Terminal Type ff fb 18
Command: Will New Environment Option ff fb 27
Command: Do Echo ff fd 01
Command: Will Suppress Go Ahead ff fb 03
Command: Do Suppress Go Ahead ff fd 03
SERVER--
Command: Do Terminal Type ff fd 18
Command: Do Terminal Speed ff fd 20
Command: Do X Display Location ff fd 23
Command: Do New Environment Option ff fd 27
CLIENT--
Command: Won't X Display Location ff fc 23
SERVER--
Command: Do Negotiate About Window Size ff fd 1f
Command: Will Echo ff fb 01
Suboption Begin: Terminal Speed ff fa 20
Option data 01
Command: Suboption End ff f0
Suboption Begin: New Environment Option ff fa 27
Option data 01
Suboption Begin: Terminal Type ff fa 18
Send your Terminal Type 01
CLIENT--
Suboption Begin: Negotiate About Window Size ff fa 1f
Width: 80 00 50
Height: 24 00 18
CLIENT--
Option data 00 33 38 34 30 30 2c 33 38 34 30 30
CLIENT--
Option data 00
CLIENT--
Here's my Terminal Type 00
Value: XTERM 58 54 45 52 4d
SERVER--
Command: Will Status ff fb 05
Command: Do Remote Flow Control ff fd 21
CLIENT--
Command: Won't Echo ff fc 01
CLIENT--
Command: Don't Status ff fe 05
CLIENT--
Command: Won't Remote Flow Control ff fc 21
SERVER--
Data: login: 6c 6f 67 69 6e 3a 20Before I try to work on a solution (eventually a new library), I would like to ask the community, if there is already a solution for this task. Any input would be highly appreciated.
