Loading...
Pages: [1] 2   Go Down
Author Topic: arduino + SD card Question  (Read 872 times)
Offline Offline
Newbie
View Profile
Hi everyone,
I use Arduino uno + SD shield and use external power, save data in sd card
but sometime I read SD card from PC , data write to SD card stop
how can I solve the question ?    Thanks.
my code.
Code:
Serial.print("Initializing SD card...");
pinMode(10, OUTPUT);
if (!SD.begin(10)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
myFile = SD.open("test.txt", FILE_WRITE);
if (myFile) {
Serial.print("Writing to test.txt...");
Serial.println("done.");
Serial.println("error opening test.txt");
myFile = SD.open("test.txt");
if (myFile) {
Serial.println("test.txt:");
myFile.close();
myFile.print(temp, DEC);
myFile.close();
Logged
Miramar Beach, Florida
Offline Offline
Faraday Member
View Profile
I don't know if this is your problem, but my rule for files is if you open a file, you should close it.
Code:
if (myFile) {
                // close the file here, just like below.
myFile.close();
        // with your sketch, myFile is still open from above
if (myFile) {
myFile.close();
Logged
Offline Offline
Newbie
View Profile
hi
my problem ,example..
i save data to SD card every second from Arduino
if it operation 30 min ,i should get 600 data
but i see SD card , maybe write 10min stopped
so i lose after 10 minutes of data
thank.
Logged
Offline Offline
Faraday Member
View Profile
You should post your code. Your code above does not compile. No headers, no global variables, and my compiler does not like the "......" deal in the loop function.
Here are some of my other rules:
If the user thinks it isn't important enough to include, it probably is.
If the user says "don't worry about that", you probably should.
If the user says "it is taken care of", it probably isn't.
« Last Edit: June 27, 2012, 07:27:16 am by SurferTim » Logged
Offline Offline
Newbie
View Profile
hi SurferTim
Code:
#include <SD.h>
File myFile;
int t;
return;
if (myFile) {
                myFile.close();
if (myFile) {
myFile.close();
int analogValue0;
t++;
analogValue0 = analogRead(0);
myFile.print(t);
myFile.print("\t");
myFile.println(analogValue0);
myFile.close();
Logged
Offline Offline
Faraday Member
View Profile
What kind of equipment are we discussing? What Arduino and SD device are you using?
And I would add some error checking. Change the loop to this, then upload and open the serial monitor. Does it still fail after 10 minutes? Does it always open the file?
Code:
int analogValue0;
t++;
        Serial.print("Open ");
        if(myFile)
   myFile.print(t);
   myFile.print("\t");
   myFile.close();
           Serial.println("OK");
        else Serial.println("failed");
Logged
Offline Offline
Newbie
View Profile
hi SurferTim
I use equipment list
Arduino Uno(http://arduino.cc/en/Main/ArduinoBoardUno/)
SD shield(http://www.seeedstudio.com/depot/sd-card-shield-p-492.html?cPath=109)
series two  3.7V 1100mAh battery(like http://arduino.cc/playground/Learning/9VBatteryAdapter)
I used USB to computer always success(not loss data to sd card)
but because some required i need go out
so i can't use serial monitor
thank very much.
Logged
Offline Offline
Faraday Member
View Profile
OK. Now I see. It is a power supply challenge.
Have you checked the +5v on the Arduino after the fail? Is it still +5v? That sounds like an overtemp shutdown on the voltage regulator. Is the regulator getting really hot?
Logged
Offline Offline
Newbie
View Profile
hi SurferTim
i touch regulator very hot
If the problem is that it..
how can i do ?
http://softsolder.com/2010/10/15/arduino-mega-voltage-regulator-heatsink/
do you think it is a good idea ?
thanks.
Logged
Offline Offline
Faraday Member
View Profile
Did you monitor the +5v pin on the Arduino during the test?
I would try a check to see if that is it. Remove the SD shield and run the blink example on the batteries. Does it fail after 10 minutes? Does the regulator still get as hot?
Logged
Offline Offline
Newbie
View Profile
hi
I try Remove SD card and add LED blink
for some time , regulator sill hot , LED alway working
the Arduino out 5V pin , I monitor about 4.5V
Logged
Greenville, IL
Offline Offline
Edison Member
Warning Novice on board! 0 to 1 chance of errors!
View Profile
Quote
What are reading?  Does the device use power from the Uno?
Logged
Offline Offline
Newbie
View Profile
Yes , power from Uno  ,the device(sensor) also need 5V
Logged
Greenville, IL
Offline Offline
Edison Member
View Profile
Quote
  The device may need too much current for the Uno to supply. Can you tell us more about it or supply a datasheet?
Logged
Offline Offline
Newbie
View Profile
in fact, i use Arduino Uno power support
CO sensor(MQ-7  http://probots.co.in/Datasheets/MQ7.pdf)
Humidity and Temperature Sensor(SHT15  http://www.emesystems.com/pdfs/parts/SHT15.pdf )
because can working at the beginning , so i think current enough
Logged
Pages: [1] 2   Go Up
Print
Jump to:
