Loading...
Pages: [1]   Go Down
Author Topic: Problemas para escrever no micro Sd card  (Read 428 times)
Offline Offline
Newbie
View Profile
Boa tarde galera, estou com um pequeno problema para escrever no SD card usando o arduino mega+Ethernet Shield, eu consigo abrir o arquivo e escrever nele uma vez, mas na segunda vez ele da erro, segue o codigo, abraços.
Quote
Code:
#include <glcd.h>
#include <fonts/allFonts.h>
#include <Keypad.h>
#include <SD.h>
//DECLARAÇÃO DO TECLADO
unsigned long startMillis;
unsigned int iter = 0;
unsigned int iterStart = 0;
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] = {
    '1','2','3','A'          }
    '4','5','6','B'          }
    '7','8','9','C'          }
    '*','0','#','D'          }
byte rowPins[ROWS] = {
  A12, A13, A14, A15}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {
  A8, A9, A10,A11}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
char key = keypad.getKey();
char id[5];
int a=0;
const int chipSelect =10;
  pinMode(10, OUTPUT);
  //INICIALIZAÇÃO DO DISPLAY
  GLCD.Init(NON_INVERTED);   // initialise the library
  GLCD.ClearScreen();        //limpa lcd
  GLCD.SelectFont(System5x7);       // select fixed width system font
  GLCD.SetTextMode(SCROLL_UP);
void loop(){
  int i=0;
  delay(150);
  GLCD.ClearScreen();
  GLCD.CursorTo(0,0);
  GLCD.print("ID=");
  //SE NÃO FOI DIGITADO NENHUM ID AINDA ID=0000
  if (a == 0){ //A VARIAVEL FOR FALSA ELE JOGA O ID = 0000
    for(i=0;i<5;i++){
      id[i]=0;
  while (i < 5 ){   //MOSTRA O ID
    GLCD.CursorTo(i+4,0);
    GLCD.print(id[i]);
    i++;
  GLCD.CursorTo(0,1);
  GLCD.println("PRECIONE A FUNCAO    DESEJADA");
  GLCD.println("A=Identificação");
  GLCD.println("B=Mensagens Diversas");
  //MENU DE ESCOLHA
  switch (key = keypad.getKey()){
 case 'B':
    funcoes();
void funcoes(){
   File myFile;
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  myFile = SD.open("test.txt", FILE_WRITE);
  // if the file opened okay, write to it:
  if (myFile) {
    Serial.print("Writing to test.txt...");
    myFile.println("testing 1, 2, 3.");
    // close the file:
    myFile.close();
    Serial.println("done.");
  else {
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
  // re-open the file for reading:
  myFile = SD.open("test.txt");
  if (myFile) {
    Serial.println("test.txt:");
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
      Serial.write(myFile.read());
    // close the file:
    myFile.close();
  else {
  delay(2000);
Logged
Pages: [1]   Go Up
Print
Jump to:
