Topic: VGA ports using arduino (Read 1 time) previous topic - next topic
trenmost
Hi! i have an arduino uno, and i would like to drive a display trough a VGA port.
i searched for some VGA specifications, but im not sure so i will post about this:
if i undestand correctly if i output the pixel colors trough the RED, GREEN, BLUE pins,
i output a High signal on the HSYNC when i reach the end of the line,
i output a High signal on the VSYNC when i reach the end of the picture,
and i wire RGND, GGND, BGND, HSYNC_GND to the ground.
is this really the case? of course i have to make some timing delays so i can output a 320x240 image @60hz
also if it would work, what values shouzld i output on the R, G, B, HSYNC, VSYNC pins?
YoshiFan501
duality
have you seen this :)? http://www.youtube.com/watch?v=eGhsN9GWh48
http://www.youtube.com/user/Shockszzbyyous
Grumpy_Mike
well with 8 bit for each of the RG & B components that works out at:- 230K bytes, on a machine with only 2K of ram for everything where are you going to put the image?
trenmost
its 8bit total, not for RGB individually.
Grumpy_Mike
So only 79K to fit in a 2K machine, that is much better?
