Topic: is there a 24 volt version of arduino ? (Read 6526 times) previous topic - next topic
PGT
A friend of me wanted to know if there is a 24 volt version, or 'clone' of arduino
Because 24 volt is often used in the industrial sensors, he works with.
Operating at 24 volt, having 24v analog input, and able to switch (relays?) based upon 24 volt.
For him its important that the board is ready to use, without soldering resistors zenerdiodes etc.
I do not know if something like it exist so i ask it here, or maybe there is board for handeling higher voltages (for pinout and analog read) ?
spirilis
No, not really.  The chip itself can only run at 5V (6V maximum).  However I did see an arduino variant that was hardened for 12V -- http://ruggedcircuits.com/html/mb324p.html
It's conceivable one could design an Arduino with all the various I/O ports gated in such a way that they interface with 24V, using level shifters or voltage dividers (e.g. for analog inputs) but I've not heard of one already designed for this purpose.
DVDdoug
Virtually all "digital electronics" are 5V or 3.3V.  But of course there are relatively simple ways to interface with higher-voltage circuits, just as you can use a 12V or 24V relay to switch 120/240VAC.
If you have some kind if 24V industrial control board, there is a good chance that there is a 5V voltage regulator and some 5V logic on the board.
winner10920
Im pretty sure things wouldn't fly well if the boss found out the 10,000$ ... PLC was replaced with a 30$ arduino
although that would be pretty funny
maybe you can design your own board for 24v use, probably have some people interested in buying it
PGT
hm he didnt mention plc, i dont know what he uses.
I believe plc's are popular, i never seen one lol.
So creating something like it might be quite cool, and make the arduno adopted by more people
i hope it wont upset people who use plc's.
:D
Maybe i should convince him to make it, before this he used to work for a big electronic company, he has the knowledge to create it i'm sure.
graynomad
winner10920
I've programmed plcs a little bit in class, and its easier to a degree, all graphical interface with simple lader diagram type form
personally I prefer the arduino, it would be cool but plcs usually come with expandable modules so technically it would be more about the input/output modules than anything
you could probably hook an arduino to an existing plc setup, once you figure out how the modules communicate
graynomad
Probably Modbus, Profibus or similar.
______
Rob
PGT
@Rob it sounds like you already used arduino with PLC combinations, what's your view on it ? do you prefer it or ... ?
MarkT
PLCs are sold on ruggedness and reliability - they are bombproof, they will work next to an arc welder at high temperatures without a murmur etc etc.   If you need something to work in that sort of environment they are worth it I guess.  for less stringent requirements you don't need the 24V stuff at all - that gives the extreme immunity to electrical noise and to poor ground matching.
graynomad
I worked in the building control game years ago but we made all our own custom hardware, so I have no direct experience with PLCs.
I'm now continuing that tradition by designing my own set of monitoring and controlling devices but that's another story.
Bottom line is that I think commercial PLCs are overkill for the average Arduinoite's project, but standard Arduinos and shields are not really up to the job of robust control.
______
Rob
PGT
hmm its kinda strange,
You see computers at industrial workfloors (who are way more sensitive)
Yet people put question marks at replacing arduino for a plc.
In the end i think it comes down to proper electronics and shielding; and that could be done with any good circuits i think.
Best would be decoupled circuits / optical / relays /etc..
But its not up to me to change industries, dough i would assume its do able.
And perhaps they will if they start to realize it.
:) perhaps a nextgen project
SurferTim
This Mega from Freetronics has a switching power supply, and is advertised to handle up to 28v.
http://www.freetronics.com/products/ethermega-arduino-mega-2560-compatible-with-onboard-ethernet
winner10920
I don't think its a matter of possibility more of reliability, and the fact that say an allen bradley plc has a multimillion dollar company behind it with tech support and many engineers to figure out bugs
and arduino that a hobbyist designs can most likely do anything a professional plc can but there's no garuntee that something wasn't overlooked or some bug that would come out later in operation, and then there's no one around to ask for help( other than this amazing forum, which would be amusing to see some industrial companies asking for hobbyist help)
PGT
Well once Linux was for hobbyists too,
People bring and help with their different knowledge expertise and at some boiling point, there is a turn.
Suddenly a massive group of enthusiast role a dice against some commercial products.
I have seen this so often in software, (and i think rep rap, is another hardware example for this)
I think those free spirits, often create products that commercial people dont feel a need to create.
As they rather like to protect their market.
(i see now 2 posts of 24volt arduino in this blog, so i think such tipping points are near)
