Author Topic: [Ethernet + SD] Download zip files from SD  (Read 706 times)
I'm making a website with ethernet shield.
I wanted to click a link, and download a file from the memory card. Example: zip file
Click a link and do a task I know, I just wanted the part of the SD.
Anybody can help me?
and files *.txt, its possible?
 smiley-roll-sweat sorry for double post.
Seattle, WA USA
Online Online
Seattle, WA USA
That's possible.
Your web page, provided by the Arduino, needs to contain links. Does it? What does the Arduino do when a link is selected?
Example: zip file
What is the browser going to do with a zip file?
You haven't demonstrated this.
The SD library comes with examples for listing the files on an SD card, and for reading from an SD card. Combining the relevant example with the web server code should be trivial. Read from a file and write to the client. Nothing really to it.
The browser download the file to PC
The code:
  if (client) {
    Serial1.println(F("new client"));
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    String vars;
    int varDL=0;
    int dlaio=0;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial1.write(c);
        vars.concat(c);
        if (vars.endsWith("=Download"))
          varDL=1;
        else if (vars.endsWith("/download/arduinoIO"))
          varDL=1;
          dlaio=1;
if (c == '\n' && currentLineIsBlank) {
          client.println(F("HTTP/1.1 200 OK"));
          client.println(F("Content-Type: text/html"));
          client.println(F("Connnection: close"));
          client.println();
          client.println(F("<!DOCTYPE HTML>"));
          client.println(F("<html>"));
          client.println(F("<head>"));
          // meta tag -> Faz refresh ao browser de 2 em 2 segundos
          client.println(F("<meta http-equiv=\"refresh\" content=\"2\">"));
if (varDL==1) // DOWNLOAD CENTER
            client.println(F("<h1>Downloads</h1>"));
            client.println(F("<a href='/download/arduinoIO'>Matlab Support Package for Arduino (Arduino IO)</a>"));
if (dlaio==1) // DOWNLOAD ARDUINO IO
           //CODE FOR DOWNLOAD FILE
But the library only read/write txt files.
« Last Edit: July 01, 2012, 04:56:55 pm by bl0w » Logged
Seattle, WA USA
Online Online
Seattle, WA USA
The examples only show how to read/write text files, since they are the easiest to demonstrate proper functionality.
There is nothing in the library that restricts it from operating on files with other extensions. Whether a file contains "text" or binary data depends on what you write to the file. Text IS binary data, after all.
           myFile = SD.open("ArduinoIO.zip");
           if (myFile)
             // read from the file until there's nothing else in it:
             while (myFile.available())
               client.write(myFile.read());
             // close the file:
             myFile.close();
             // if the file didn't open, print an error:
             client.println("FILE NOT FIND");
i do this: replace Serial.write(myFile.read()); for client.write(myFile.read()); and don't work
to tell the browser that arduino are writing an html page we do:
do we have to do a similar thing to another file type? how can I indicate this?
Seattle, WA USA
Online Online
Seattle, WA USA
Yes. The type follows the / (text/html --> text/zip).
You should look at the return type from myFile.read() and the expected input to client.write(). You will see that they don't match. An intermediate variable or an explicit cast may be required.
if i do this:
  if (client) {
    String vars;
    int varDL=0;
    int dlaio=0;
    int html=1;
    int txt=0;
    int zip=0;
    int dltext=0;
          varDL=1;
          dlaio=0;
          zip=0;
          html=1;
          dltext=0;
          txt=0;
        else if (vars.endsWith("/download/ArduinoIO.zip"))
          varDL=1;
          dlaio=1;
          zip=1;
          html=0;
          txt=0;
        else if (vars.endsWith("/download/sensor.txt"))
          varDL=1;
          dlaio=0;
          dltext=1;
          zip=0;
          html=0;
          txt=1;
          // Cliente terminou de comunicar e o arduino tem de enviar
          // o seguinte cabeçalho para o browser
          if(html==1)
          if(txt==1)
            client.println(F("Content-Type: text/txt"));
          if(zip==1)
            client.println(F("Content-Type: text/zip"));
          client.println();
            client.println(F("<a href='/download/ArduinoIO.zip'>Matlab Support Package for Arduino (Arduino IO)</a>"));
            client.println(F("<a href='/download/sensor.txt'>TESTE</a>"));
          if (dltext==1) // download sensor.txt
            myFile = SD.open("sensor.txt");
            if (myFile)
              myFile.close();
            if (myFile)
              myFile.close();
client.println(F("</body>"));
client.println(F("</html>"));
The result is this:
FOR ZIP FILE:
FOR TXT FILE:
in the case of. * txt file the true file is this:
I am not able to do that, anyone who knows can tell me?
Seattle, WA USA
Online Online
Seattle, WA USA
myFile.read() returns an int. The data of interest is in the low order byte. You need to research what happens when you call client.write() with an int. It may be sending both the high order byte and the low order byte, which would definitely screw up the file as saved on the PC.
It is not really recommended that you do this. Create an intermediate variable of the correct type to hold the output of the read() method, then call the write() method with that variable.
The Content-Type record should contain application/zip, not text/zip (sorry about that).
You may need to use a "Content-Encoding" record, too.
Maybe this:
char myStrings[];
File myFile;
if (varDLtxt==1) // download sensor.txt
            int i;
            if (myFile)
                i=0;
                myStrings[i]=myFile.read();
                i=i+1;
                client.write(myStrings);
              myFile.close();
but we can't declare an array without size, right?
Edit: I test with char myStrings[100];
Now appears the right values on page, but don't download.
« Last Edit: July 02, 2012, 01:06:00 pm by bl0w » Logged
