Loading...
Pages: [1]   Go Down
Author Topic: Problema collegamento con Ethernet Shield R3  (Read 354 times)
near Slovenia
Offline Offline
Jr. Member
Arduino rocks
View Profile
Salve,
ho collegato Arduino Uno R3 e Ethernet Shield R3 insieme,collegato con USB e cavo RJ45 al MacBook e il codice come prova è questo (vedi qui sotto) in altro modo come posso?Io uso Arduino 1.0.1 per programmare,ma alla fine mi dice errore della libreria w5100.cpp e w5100.h.Che cosa devo fare?Grazie.
Code:
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {  0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
char serverName[] = "www.google.com";
EthernetClient client;
   while (!Serial) {
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    while(true);
  Serial.println("connecting...");
  if (client.connect(serverName, 80)) {
    Serial.println("connected");
    client.println("GET /search?q=arduino HTTP/1.0");
    client.println();
  else {
    Serial.println("connection failed");
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  if (!client.connected()) {
    Serial.println("disconnecting.");
    client.stop();
    while(true);
Logged
Cagliari
Offline Offline
Faraday Member
View Profile
Ciao,
su WinXP, IDE 1.0.1 compila perfettamente.
Prova a riscaricare l'IDE e ricopia qui sul forum gli errori che ti da. Cosi ci facciamo un'idea più precisa.
Logged
near Slovenia
Offline Offline
Jr. Member
Arduino rocks
View Profile
Va bene, scaricherò gli errori che mi dà,grazie PaoloP.
Logged
Italy
Offline Offline
Full Member
View Profile
Ho appena provato con macbook, UNO, ETH shield tutto R3 e compila senza problemi
N.
Logged
"The question is not whether intelligent machines can have emotions, but whether machines can be intelligent without any emotions"
near Slovenia
Offline Offline
Jr. Member
Arduino rocks
View Profile
Gli errori:
Code:
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/w5100.cpp: In member function 'void W5100Class::init()':
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/w5100.cpp:28: error: 'delay' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/w5100.cpp:30: error: 'SPI' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/w5100.cpp: In static member function 'static uint8_t W5100Class::write(uint16_t, uint8_t)':
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/w5100.cpp:133: error: 'SPI' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/w5100.cpp: In static member function 'static uint16_t W5100Class::write(uint16_t, const uint8_t*, uint16_t)':
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/w5100.cpp:146: error: 'SPI' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/w5100.cpp: In static member function 'static uint8_t W5100Class::read(uint16_t)':
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/w5100.cpp:159: error: 'SPI' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/w5100.cpp: In static member function 'static uint16_t W5100Class::read(uint16_t, uint8_t*, uint16_t)':
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/w5100.cpp:172: error: 'SPI' was not declared in this scope
Logged
near Slovenia
Offline Offline
Jr. Member
Arduino rocks
View Profile
Salve,
ho collegato Arduino Uno R3 e Ethernet Shield R3 insieme,collegato con USB e cavo RJ45 (no cavo cross over-incrociato) al MacBook e il codice come prova è questo (vedi qui sotto).Al Monitor Seriale compare così:
coconnecting…
connection failed
disconnecting.
Code:
#include <SPI.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0D, 0x23, 0x1F };
byte ip[] = {  192,168,2,4 };
byte server[] = { 173, 194, 35, 151 }; // Google
byte subnet[] = { 255, 255, 255, 0 };    //subnet mask of the network
byte gateway[] = { 192, 168, 2, 1 };   //your router's IP address
void resetEthernet() {
  client.stop();
  Ethernet.begin(mac, ip, gateway, subnet);
  Ethernet.begin(mac, ip);
  if (client.connect(server, 80)) {
    client.println();
    Serial.print(c);
    client.stop();
    for(;;)
Logged
Pages: [1]   Go Up
Print
Jump to:
