Topic: Problema collegamento con Ethernet Shield R3 (Read 1 time) previous topic - next topic
christiank30
Salve,
ho collegato Arduino Uno R3 e Ethernet Shield R3 insieme,collegato con USB e cavo RJ45 al MacBook e il codice come prova è questo (vedi qui sotto) in altro modo come posso?Io uso Arduino 1.0.1 per programmare,ma alla fine mi dice errore della libreria w5100.cpp e w5100.h.Che cosa devo fare?Grazie.
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {  0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
char serverName[] = "www.google.com";
EthernetClient client;
   while (!Serial) {
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    while(true);
  Serial.println("connecting...");
  if (client.connect(serverName, 80)) {
    Serial.println("connected");
    client.println("GET /search?q=arduino HTTP/1.0");
    client.println();
  else {
    Serial.println("connection failed");
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  if (!client.connected()) {
    Serial.println();
    Serial.println("disconnecting.");
    client.stop();
    while(true);
PaoloP
Ciao,
su WinXP, IDE 1.0.1 compila perfettamente.
Prova a riscaricare l'IDE e ricopia qui sul forum gli errori che ti da. Cosi ci facciamo un'idea più precisa.
christiank30
Va bene, scaricherò gli errori che mi dà,grazie PaoloP.
superp
Ho appena provato con macbook, UNO, ETH shield tutto R3 e compila senza problemi
N.
christiank30
Gli errori:
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/w5100.cpp: In member function 'void W5100Class::init()':
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/w5100.cpp:28: error: 'delay' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/w5100.cpp:30: error: 'SPI' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/w5100.cpp: In static member function 'static uint8_t W5100Class::write(uint16_t, uint8_t)':
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/w5100.cpp:133: error: 'SPI' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/w5100.cpp: In static member function 'static uint16_t W5100Class::write(uint16_t, const uint8_t*, uint16_t)':
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/w5100.cpp:146: error: 'SPI' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/w5100.cpp: In static member function 'static uint8_t W5100Class::read(uint16_t)':
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/w5100.cpp:159: error: 'SPI' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/w5100.cpp: In static member function 'static uint16_t W5100Class::read(uint16_t, uint8_t*, uint16_t)':
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/w5100.cpp:172: error: 'SPI' was not declared in this scope
christiank30
Salve,
ho collegato Arduino Uno R3 e Ethernet Shield R3 insieme,collegato con USB e cavo RJ45 (no cavo cross over-incrociato) al MacBook e il codice come prova è questo (vedi qui sotto).Al Monitor Seriale compare così:
coconnecting…
connection failed
disconnecting.
#include <SPI.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0D, 0x23, 0x1F };
byte ip[] = {  192,168,2,4 };
byte server[] = { 173, 194, 35, 151 }; // Google
byte subnet[] = { 255, 255, 255, 0 };    //subnet mask of the network
byte gateway[] = { 192, 168, 2, 1 };   //your router's IP address
void resetEthernet() {
  client.stop();
  Ethernet.begin(mac, ip);
  if (client.connect(server, 80)) {
    client.println();
    Serial.print(c);
    Serial.println();
    client.stop();
    for(;;)
escozzaro
Salve,
ho il tuo stesso problema, è passato tempo da allora, per caso hai risolto?
se si come?
Grazie di tutto.
Saluti
Vincenzo
