Topic: Arduino Mega + Ethernet Shield (Read 1 time) previous topic - next topic
Wellington Junior
I'm with a problem reading the Micro Sd through the Ethernet Shield, the first time it reads the file, but the second time he already failed, perhaps I'm using the keypad? or by using the library display 128x64 GLCD?
Quote
Code: [Select]
#include <glcd.h>
#include <fonts/allFonts.h>
#include <Keypad.h>
#include <SD.h>
//DECLARAÇÃO DO TECLADO
unsigned long startMillis;
unsigned int iter = 0;
unsigned int iterStart = 0;
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] = {
    '1','2','3','A'          }
    '4','5','6','B'          }
    '7','8','9','C'          }
    '*','0','#','D'          }
byte rowPins[ROWS] = {
  A12, A13, A14, A15}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {
  A8, A9, A10,A11}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
char key = keypad.getKey();
char id[5];
int a=0;
const int chipSelect =4;
  pinMode(10, OUTPUT);
  //INICIALIZAÇÃO DO DISPLAY
  GLCD.Init(NON_INVERTED);   // initialise the library
  GLCD.ClearScreen();        //limpa lcd
  GLCD.SelectFont(System5x7);       // select fixed width system font
  GLCD.SetTextMode(SCROLL_UP);
void loop(){
  int i=0;
  delay(150);
  GLCD.ClearScreen();
  GLCD.CursorTo(0,0);
  GLCD.print("ID=");
  //SE NÃO FOI DIGITADO NENHUM ID AINDA ID=0000
  if (a == 0){ //A VARIAVEL FOR FALSA ELE JOGA O ID = 0000
    for(i=0;i<5;i++){
      id[i]=0;
  while (i < 5 ){   //MOSTRA O ID
    GLCD.CursorTo(i+4,0);
    GLCD.print(id[i]);
    i++;
  GLCD.CursorTo(0,1);
  GLCD.println("PRECIONE A FUNCAO    DESEJADA");
  GLCD.println("A=Identificação");
  GLCD.println("B=Mensagens Diversas");
  //MENU DE ESCOLHA
  switch (key = keypad.getKey()){
  case 'B':
    Sd();
void Sd(){
   File myFile;
    delay(110);
   myFile = SD.open("test.txt", FILE_WRITE);
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  // if the file opened okay, write to it:
  if (myFile) {
    Serial.print("Writing to test.txt...");
    myFile.println("testing 1, 2, 3.");
    // close the file:
    myFile.close();
    Serial.println("done.");
  else {
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
   delay(110);
  // re-open the file for reading:
  myFile = SD.open("test.txt");
  if (myFile) {
    Serial.println("test.txt:");
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
      Serial.write(myFile.read());
     myFile.close();
  else {
SurferTim
Try disabling the w5100 SPI. That caused the same problem with my SD card.
Code: [Select]
  // add this
  digitalWrite(10,HIGH);
  // rest of your setup
Wellington Junior
Continue message initialization failed!   =(
SurferTim
Code: [Select]
void Sd(){
   File myFile;
    delay(110);
   // you are opening this before the SD is initialized
  // this should be in setup()
  if (!SD.begin(4)) {
    return;
  // rest of code
Wellington Junior
I still have problems, will be a problem of the Ethernet Shield? Sdfat16 tried to use the library but could not.
SurferTim
#5
Jun 29, 2012, 04:08 pm Last Edit: Jun 29, 2012, 04:50 pm by SurferTim Reason: 1
Try this sketch. Does the SD still fail?
Code: [Select]
#include <SD.h>
 pinMode(10,OUTPUT);
 Serial.print("Starting SD...");
 if(!SD.begin(4)) Serial.println("failed");
 else Serial.println("ok");
edit: My bad on the serial command.
If it fails, explain what keypad and GLCD you are using, and how they are connected.
Wellington Junior
I managed to make it work with the library fat16, someone has some examples explaining the commands?
The 4x4 keypad is connected to pins A10 ... A15
  The display is connected to pins traditional, is the type B.
SurferTim
Quote
Can you be more specific? The lcd stuff in the examples has pin assignments that will conflict with the SD.
You can't use digital pins 4 or 10. Those are used by the SD and w5100.
Wellington Junior
Pino do Display LCD 128×64      Pin Arduino Mega
1                                          GND
2                                          5V
3                                            -
4                                           36
5                                           35
6                                      37
7                                      22
8                                      23
9                                      24
10                                      25
11                                      26
12                                      27
13                                      28
14                                      29
15                                      33
16                                      34
17                                      Reset
18                                      -
19                                      5V
20                                      GND
SurferTim
Is this the GLCD you are using?
http://www.sparkfun.com/products/710
Wellington Junior
this is the display http://www.datasheetcatalog.org/datasheet/vishay/128g064e.pdf
SurferTim
That looks ok. I see no conflict. You said above "I managed to make it work", so it is working now?
Wellington Junior
Yes,using SdFat16 worked, but it is much more complicated, I am having difficulty sending the data file for the serial.
Sorry for my english beginner. =(
Wellington Junior
It worked, thanks for the support.  :)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
