Author Topic: wireless transceiver  (Read 397 times)
Hi Guys,
I used to program directly with AVR's but am loving the easy Arduino libraries.
I want to produce a wireless transimssion of a message when a buton is pressed, and another arduino receives it. I know boards already exist to help do this, but I came across this:
http://www.swharden.com/blog/2011-08-06-ridiculously-simple-avr-mcu-am-radio-transmitter/
The hardware here is super simple. I know it is messing with fuses to get the 1Mhz ckOut but I thought I could set up a hardware interupt pin at 1Mhz based on the built in 16Mhz clock on my Arduino.
Apart from that the rest of the code looks easy to replicate. Then set up a button to send the message rather than loop the message out forever.
But Now for receiving. And maybe Im in the wrong forum because this is more of an electronics question.
Can I use the same circuitry as in the above link, and just change the code to "receiving code"? Im not sure what it would have to do, but i am imagining something like another interupt timer, also set to 1Mhz listening to data coming in on an analog pin - or maybe continuous listening, because the two devices might be completely out of sync.
Any experts in this field be able to advise me here.
P.S The reason i am looking at this circuit is because I am after a very small transmitter, and exisitng decives are quite bulty in comparison to how small and adaptable this one could be.
Anaheim CA.
Experienced old Whitebeard with a Full head of Hair...
If you connected the Vcc to the fet directly to the audio pin the fet would be powered  off and on at the addio rate and the fet would be when powered up switched off and on at the Clock rate... Simple. It's called a gated driver... the fet can draw a max of 27mA through the 220 ohm resistor, well within the port capabilities. The only problem is the receiver. a 1/4 wave  antenna @ 1 Mhz is about 9 meters long. a small even medium length > 1 m... is a very small aperture. I found a reliable (so far) and inexpensive place to buy those little 433 Mhz radios. Rx&Tx pairs can be had for $1.80 US  @ ElectroDragon.com
This is the URLhttp://www.electrodragon.com/?product=433m-rf-wireless-module-a-pair-of-receiver-and-transmitter.
Mine work very well too.
Doc
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
The problem with that circuit is that it's going to splatter all over the shortwave band - an RF signal needs to be spectrally pure within legal limits, and within bands you are legally entitled to use.  That circuit produces a square wave, not a sine wave.  You can get various legal and cheap modules for the unlicensed ISM bands, from simple wire-replacement tx/rx pairs to packet transceiver modules and all the way up to mesh network nodes like the Xbee's
Be aware that if your circuit transmits over a sensitive frequency such as fire and rescue services or aircraft bands you run a risk of endagering other's life and safety.  Also an effective aerial for 1MHz is awkwardly large anyway.
Washington
Firefox & Arduino rocks
A: You do not know what country the OP is and what the regulations there are if it is not the US
B: If run with a higher resistor and with a small antenna (FCC part 15 limits you to 10ft of antenna anyway) I do not think that it will cause any issues
I recommend using a resistor higher then 220 ohms to lower the output power
A low pass filter can correct this but once again if you keep the output low (say 10mW), the chance of causing problems is very low.
XBees are neat since they work as a virtual serial port making them easy to use.
This is extremely unlikely since those are in the VHF/UHF bands meaning it would be the 20th to 300th harmonics and they would likely be attenuated sufficiently to not interfere with multi-watt transmitted signals.
Obviously this is true. And also illegal to use an antenna of this size in the US on a part 15 transmitter.
This will almost certainly not works as you expect this is will pick up all kinds of electrical noise and crud. Without an input band pass filter, it would receive any radio signals from DC-0.5MHz. Even with a proper bandpass filter, sampling in that manner will not work well.
Also you would have to sample at 2MHz to receive at 1Mhz because the Nyquist frequency effect.
If communication between arduinos is your goal, then I suggest purchasing a module designed for doing this.
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
Australia
If all you wish to do is be able to press a button and have the event transmitted over a radio link
you dont need any computers at all.
Can be done entirly with simple hardware.
A pair of 433 Mhz low power Transmitter / Receiver modules with a pair of SM5172 / SM5162
emcoder decoder ICs will do everything you need.
