Topic: easiest throwing ball mechanism? (Read 4574 times) previous topic - next topic
ironbot
I need to finish a mechanism to throw the ping-pong ball, or shoot the ball indoor (in the room), i.e. say for 5 meeter max in distance and 2 meter height max.
I googled for it but not much interesting results, so decided to ask here to point me to a good example
Thank you
lesto
look at the machine that throw tennis ball, the mechanism is quite simple
Guida per principianti http://playground.arduino.cc/Italiano/newbie
Unoffical Telegram group https://telegram.me/joinchat/ALRu8ACkdTdXyz-2P7v13A
PeterH
Any other constraints? Do you need to be able to aim it or control the speed? Is it single shot or does it need to be able to fire multiple balls? Any restrictions on size, weight, power supply etc?
I only provide help via the forum - please do not contact me for private consultancy.
ironbot
My need is very simple: to shoot once, then get reset manually, no need for automation. Shooting power of max 100gr is enough. My powr supply is LiPo, Mystery, 2800mah, 30C.
I have servo and 12v dc motors available, but don't have imagination for shooting :)
no more constraints.
PeterH
In that case I'd use a catapault with a servo acting as a release. It's mechanically simple, and you have ample scope to adjust it to get any range you want.
ironbot
I googled catapult and found many examples of it. I finally implemented it not by a servo, but with ordinary dc motor, then in the path of throwing mechanism installed a bumper switch and connected it to int0 on digital pin 2, so that to some learn interrupting too.
It seems to work reasonably. Thank you and thanks to Lesto.
macegr
Look at putt return devices. It's just a solenoid that kicks the ball. You could put a solenoid in a piece of PVC pipe.
Unique RGB LED Modules and Arduino shields: http://www.macetech.com/store
ironbot
any example link please? can't find it in google!
PeterH
To fire a ping-pong ball 5m it's going to need to be going darned fast and I think you'll struggle to get a solenoid to fire it that fast - and if you do manage it, I suspect you'll need a great deal of care to avoid breaking the ball in the process.
ironbot
Well I already got the desired results by implementing catapult, just curious to know more of various shooting mechanisms. By the way, I've never did any project with solenoid, very interesting to do one :)
lesto
http://www.youtube.com/watch?v=LBxUjBUdQ5o
this is the basic idea. change the weel with an engine and you are done.
Udo Klein
I wonder why this guy is wearing a helmet. Nowadays it seems important that anyone close to a bike carries a helmet. Seems that helmet marketing finally got it into a lot heads that bikes are inherently dangerous ;)
Check out my experiments http://blog.blinkenlight.net
Runaway Pancake
He's manning the launcher but otherwise defenseless, so it could be in case the tennis player returns one right home, but a face-mask isn't shouldn't be out of the question.
[The last thing you remember is hearing this Maria Sharapova-like shriek and then you're seeing stars.]
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
Udo Klein
IMHO a face mask would be much more appropriate than a helmet. But this stresses my point. Obviously the "inherent danger" of the stationary bike appears larger than the danger of being hit by a tennis ball. This is marketing success.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
