Topic: Grove - Humidity & Temperature sensor (Read 5076 times) previous topic - next topic
sirus
Hello everyone.I would like to help me if you could.
Well the problem is that i want to count temperature with accurate 1 digit.Ok until now?
I was looking Arduino's site and i found the dht11 and dht22 library.
Code: [Select]
#include <dht.h>
dht DHT;
#define DHT22_PIN 16
   Serial.println("DHT TEST PROGRAM ");
   Serial.print("LIBRARY VERSION: ");
   Serial.println(DHT_LIB_VERSION);
   Serial.println("Type,\tstatus,\tHumidity (%),\tTemperature (C)");
   // READ DATA
   Serial.print("DHT22, \t");
   int chk = DHT.read22(DHT22_PIN);
   switch (chk)
     case DHTLIB_OK:
                 Serial.print("OK,\t");
     case DHTLIB_ERROR_CHECKSUM:
                Serial.print("Checksum error,\t");
     case DHTLIB_ERROR_TIMEOUT:
                Serial.print("Time out error,\t");
     default:
                Serial.print("Unknown error,\t");
   // DISPLAY DATA
   Serial.print((float)DHT.humidity);
   Serial.print(",\t");
   Serial.println((float)DHT.temperature);
The dht11 library works fine but i don't have accurate result like:
23.5 C
28.7 C etc.
On the other hand dht22 works too but i'm taking results like :
e.g
Humidity %,     Temperature C
1166.20          692.2
1484.60          716.8
Could you help me to corrext my problem please???
My Arduino is ATMEGA 2560
and my dht sensor is the Grove - Humidity & Temperature sensor v1
http://www.seeedstudio.com/wiki/Grove-_Temperature_and_Humidity_Sensor
An other test example which displays me the same result is the source code from this site:
http://www.ajpdsoft.com/modules.php?traducir=es-en&name=News&file=article&sid=572#programasensorarduino
I can't understand why dht22 lib displays these results.
Thanks a lot!
pylon
Although DHT11 and DHT22 are similar they are not the same. You cannot use a DHT22 library to read values from the DHT11 but also not a library which is for both and read the value for a DHT22 as you do in your posted code.
sirus
Hello again!
Is there a way which give me accuration to my temperature result???
That's what i'm looking for.
Thanks!
mauried
The accuracy spec of the Sensor you are using is shown as +- 2 D C, so its not a very accurate sensor.
If you want a more accurate answer you need a far better sensor such as a SHT75.
http://www.sensirion.com/fileadmin/user_upload/customers/sensirion/Dokumente/Humidity/Sensirion_Humidity_SHT7x_Datasheet_V5.pdf
robtillaart
Quote
The lib here - http://arduino.cc/playground/Main/DHTLib - supports both dht11 and dht22. It has separate read functions per sensortype which use the same handshake for the 5 bytes but interpret these differently.
Can you post actual output, including the CRC check output?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
monyet_galau
Hi sirus, can you give me the library you've used that works? because I've been trying many libraries & examples but didnt work.. I am using Grove Temperature & Humidity. Dont know what's wrong with either my sensor or the codes.
mauried
The DHT11 Sensor that you are using is a poor quality sensor that only has 1D resolution, so the best you can get
is readings like 22.0 D or 30.0 D .
You cant get fractional parts of the temperature.
You need a better sensor to get fractional readings, like a DHT22.
The DHT22 and the DHT11 are similar in pinout only, the decoding of the data is differant.
