Topic: Mighty 1284p SPI / Ethernet how to get it work ? (Read 9350 times) previous topic - next topic
sync
Hey!
I can't figure out how change from default Arduino 10 (SS), 11 (MOSI), 12 (MISO), and 13 (SCK). to 4, 5, 6, 7 to match The Mighty 1284p ?
Anyone ?
sync
I figured out it was located in pins_arduino.h
static const uint8_t SS   = 4;
static const uint8_t MOSI = 5;
static const uint8_t MISO = 6;
static const uint8_t SCK  = 7;
But, i still can't get any basic Ethernet examples to work, it just hang. I've tried with 4 different 1284p, no love.
nickgammon
What Ethernet card/board are you using and how is it connected?
sync
Nick,
Pretty much straightforward set-up. It works with any atmega i have here but not the 1284p, go figure. I've tried all week.
I use an Ethernet Shield (no SD) and i power it with 3.3 v, connect the ground of course. Then, i wire pins 10, 11, 12 and 13 to the 1284p 4, 5, 6, 7  like this 10->4, 11->5, 12->6, 13->7
The 1284p operates correctly until it hit line Ethernet.begin(mac)
It freeze right there.
Like i said, i do the same thing for months with other megas and it is all fine.
FYI, i've also tried Jeelabs Ethercard, using ethercard library, diferents SS_pin but same problem. Again, works fine with other megas.
Thanks for the help.
nickgammon
Do you mean the pins on the chip?
From this page:
http://maniacbug.wordpress.com/2011/11/27/arduino-on-atmega1284p-4/
           (D 0) PB0 1|        |40 PA0 (AI 0 / D24)
           (D 1) PB1 2|        |39 PA1 (AI 1 / D25)
      INT2 (D 2) PB2 3|        |38 PA2 (AI 2 / D26)
       PWM (D 3) PB3 4|        |37 PA3 (AI 3 / D27)
    PWM/SS (D 4) PB4 5|        |36 PA4 (AI 4 / D28)
      MOSI (D 5) PB5 6|        |35 PA5 (AI 5 / D29)
  PWM/MISO (D 6) PB6 7|        |34 PA6 (AI 6 / D30)
   PWM/SCK (D 7) PB7 8|        |33 PA7 (AI 7 / D31)
                 RST 9|        |32 AREF
                VCC 10|        |31 GND
                GND 11|        |30 AVCC
              XTAL2 12|        |29 PC7 (D 23)
              XTAL1 13|        |28 PC6 (D 22)
      RX0 (D 8) PD0 14|        |27 PC5 (D 21) TDI
      TX0 (D 9) PD1 15|        |26 PC4 (D 20) TDO
RX1/INT0 (D 10) PD2 16|        |25 PC3 (D 19) TMS
TX1/INT1 (D 11) PD3 17|        |24 PC2 (D 18) TCK
     PWM (D 12) PD4 18|        |23 PC1 (D 17) SDA
     PWM (D 13) PD5 19|        |22 PC0 (D 16) SCL
     PWM (D 14) PD6 20|        |21 PD7 (D 15) PWM
You appear to be out by one in each case. (SS is pin 5 not pin 4).
sync
Actually, i was referring to D4, D5, D6, D7  :smiley-red:
Anyone here has Ethernet working on Mighty 1284p ?
nickgammon
Can you post the exact sketch you are trying? In code tags.
sync
All sketch from the Ethernet examples. Basic stuff.
Arduino 1.0, 1.0.1 on either Windows7 or Mac OS X latest
I'm very confused at this point, i  manage to find solution all by myself most of the time, must be a silly thing hanging there.
nickgammon
Looking at w5100.h:
private:
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
  inline static void initSS()    { DDRB  |=  _BV(4); };
  inline static void setSS()     { PORTB &= ~_BV(4); };
  inline static void resetSS()   { PORTB |=  _BV(4); };
#elif defined(__AVR_ATmega32U4__)
  inline static void initSS()    { DDRB  |=  _BV(6); };
  inline static void setSS()     { PORTB &= ~_BV(6); };
  inline static void resetSS()   { PORTB |=  _BV(6); };
#elif defined(__AVR_AT90USB1286__) || defined(__AVR_AT90USB646__) || defined(__AVR_AT90USB162__)
  inline static void initSS()    { DDRB  |=  _BV(0); };
  inline static void setSS()     { PORTB &= ~_BV(0); };
  inline static void resetSS()   { PORTB |=  _BV(0); };
#else
  inline static void initSS()    { DDRB  |=  _BV(2); };
  inline static void setSS()     { PORTB &= ~_BV(2); };
  inline static void resetSS()   { PORTB |=  _BV(2); };
#endif
They don't seem to have a define for the Atmega1284 and the default would appear to be incorrect for you.
CrossRoads
maniacbug's 1284 core files don't cover that?
He's been pretty thorough with those.
nickgammon
I don't know. I just looked in w5100.h which is part of the Ethernet library.
sync
nickgammon
nickgammon
Try changing, in the code I posted:
to:
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__) || defined(__AVR_ATmega1284P__)
I didn't look further than that. However it appears that the 1284P is not catered for in w5100.h. Maybe search for similar things in the Ethernet library.
sync
Well i did change the lines inside w5100.h but it still doing the same.
Feels like i don't know what i'm doing. :-)
