Loading...
Pages: [1]   Go Down
Author Topic: Alcohol Sensor MQ3 - A lot of problems with it  (Read 519 times)
Offline Offline
Newbie
View Profile
Hi everyone,
I´m having some trouble with installing the MQ 3 to Arduino. We planned to do an upgrade for a bike and connect it to the alcohol sensor MQ 3. If you have under 1.6 promille a red light should be enlightened, if you have more than 1.6 promille a red light should be on. Now we desperately need a code for this action. Please help...
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
http://nootropicdesign.com/projectlab/2010/09/17/arduino-breathalyzer/
Conclusions
It’s really hard to calibrate this sensor for even an approximate BAC reading. It’s even difficult to correlate readings to looked-up BAC values. There are many environmental factors that affect the resistance within the sensor (humidity, temperature, oxygen concentration), and this is only a $5 device anyway.
Logged
Offline Offline
Edison Member
View Profile
This is an introduction with all the problems with these gas sensors: http://arduino.cc/playground/Main/MQGasSensors
So you have to do the burn-in time. After that you have to find a good value for the resistor. After that you need a standarized mixture to measure at what analog value the alcohol percentage is. The code is just analogRead() to get the analog value.
If you have done all that, the sensor needs time to heat-up. That could be 2 minutes. This is needed before using it every time.
For analyzing breath, the MQ303A is a much better choice. It doesn't need to be on for 2 minutes before use.
« Last Edit: July 02, 2012, 12:15:54 pm by Krodal » Logged
Pages: [1]   Go Up
Print
Jump to:
