Loading...
Pages: [1]   Go Down
Author Topic: Simple program to output an mp3 or wav file?  (Read 327 times)
Offline Offline
Newbie
View Profile
I'm very new to the world of MicroControllers and even C++ programing. I have managed to cobble together some code to emit a click from a speaker, but I need to figure out how to send out a single sound file (about 15kb in size) to said speaker. I have found nothing in the current examples in the newest version of the Arduino programming software, so if any one could point me in the right direction I'd be much appreciated.
If they can go a step further and point out where I can find some example code or even post some, that would be even better. I'm not asking for any one to do the work for me, just help in the right direction.
That said I am TOTALLY lost when it comes to programming.
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Where are you planning to store the 15 Kb file? An SD card?
Logged
Offline Offline
Newbie
View Profile
I was hoping that there was enough space to store the file in the memory, but will store it to an SD card if need be. the board I have has an ATMEGA328 so I was guessing (feel free to correct me) that the program would be a few KBs max and would accomodate the file i need to output.
Logged
Offline Offline
Edison Member
Arduino rocks
View Profile
You're probably going to need something like this:
http://www.sparkfun.com/products/10628
Logged
Offline Offline
Newbie
View Profile
Even If i do need an external device that still doesn't help me with my current problem. I need to add an output sound to this code:
Code:
const int buttonPin = 2;
const int ledPin =  13;
const int spkrPin = 12;
int buttonState = 0;
  pinMode(ledPin, OUTPUT);
  pinMode(spkrPin, OUTPUT);
  pinMode(buttonPin, INPUT);
void loop(){
  buttonState = digitalRead(buttonPin);
  if (buttonState == HIGH) {
    digitalWrite(ledPin, LOW);
  else {
    digitalWrite(ledPin, HIGH);
    digitalWrite(spkrPin, HIGH);
  else {
    digitalWrite(spkrPin, LOW);
This code is 1,096 bytes with a max capacity of roughly 32kb (30 i believe after proper allocation). I just want to add a simple snippet to the above in order to load and output a small 15kb file (half of available storage).
Thanks again for any assistance!
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Are you listening here? The external device that you need has a SD card reader and appropriate decoder chip to allow you to store a wav file on the SD card. Then, you just tell the device to play the file, and it does all the work.
Quote
Where is the data? The time to play each note, and which note to play? Just diddling the speaker pin will make a noise, but you have NO control over what noise it makes. Using the tone() library, you can play notes - recognizable, controllable sounds. The problem is that you can only play one note at a time, and most music is composed of multiple notes being played simultaneously.
Logged
Offline Offline
Newbie
View Profile
I understand I'm going to need something to store the file onto if the memory can not store it. The problem I'm having is how do I call the file from where it is stored, output it and if extra hardware is needed, how do I code that into the existing program or what library do I look into to to write a new program that would do this job.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
32 Kb of program memory. You have 2 Kb of RAM. You won't fit 15 Kb into it. Time to rethink.
Logged
Pages: [1]   Go Up
Print
Jump to:
