Loading...
Pages: [1]   Go Down
Author Topic: Resistor on pin 1 needed?  (Read 343 times)
Offline Offline
Newbie
View Profile
I've just built an arduino clone using a atmega328 chip.
It seems to work just fine without a resistor on pin 1.
I was under the impression it would continually reset without it?
or have I just gotten the wrong end of the stick....?
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
I believe there is a weak internal pull-up on pin 1.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Previous discussions have gone ovef erratic behavior without the external pullup.
Atmel Application notes seem to suggest having one, especially with DTR cap, external reset switch connected.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
SE USA
Offline Offline
Faraday Member
@ssh0le
View Profile
I have personally had zero problems with it while tinkering around, but I have never left it out on something that's going further than a evening on the breadboard, as I have been able to reset the chip by waving my finger over it once before
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Yes it will work without it but not reliably. That means under all conditions of noise and temprature.
Logged
Washington
Online Online
God Member
Firefox & Arduino rocks
View Profile
The internal pull up is very weak. I built an attiny13 project and without and external pullup resistor, it occasionally resets by itself.
Logged
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
Pages: [1]   Go Up
Print
Jump to:
