Topic: Connecting xbee shield to leostick (Read 1 time) previous topic - next topic
k1w1
Hi All,
I'm trying to connect a xbee (series 1) to a leo stick via the xbee shield.  All that I have read state that I only need to connect the 5v, gnd ,tx and rx.  With the shield attached to an uno I have no problems communicating between the uno and the PC, but if I detach the shield and connect the 4 wires to the Leo I get no communication ( I have tried swapping the tx and rx, but no luck).  Are there any other connections I need to make with the shield?  I am planning to get just a standard breakout, but in the interim I would like to get these running.
Thanks
PaulS
Quote
What is a leo stick?
Quote
Which XBee shield?
Quote
Those 4 should be all that you need.
k1w1
PaulS,
Thanks for the reply:
The Leo Stick is the freetronics LeoStick http://www.freetronics.com/products/leostick#.T_JQAJF2H7M
The xbee shield is the Sparkfun xbee shield http://australianrobotics.com.au/products/xbee-shield.
When the xbee is plugged into the shield using an UNO then I have no problems with communicating, but if I remove the shield and cable the shield - via the 4 lines as suggested then I get nothing.
Regards
k1w1
belgaroo
K1w1 did you resolve this?
I would like to try this.
