Topic: Solder bridges on ethernet shield purchased online.....suggestions? (Read 1 time) previous topic - next topic
jerseyguy1996
I purchased this ethernet shield from a Chinese distributor off of ebay.  Upon inspection it appears to have quite a few solder bridges on the WIZnet chip.  I know that most of the pins on that chip are grounded so it may not matter if there are bridges but I am not confident that I would be able to figure out which ones are okay and which aren't.  Is running a hot soldering iron across all of the pins the best way to resolve this?
IMAG0475 by jg1996business, on Flickr
IMAG0475-1 by jg1996business, on Flickr
IMAG0476 by jg1996business, on Flickr
IMAG0476-1 by jg1996business, on Flickr
Arduino Uno;
Mega328
cr0sh
I think I'd first get the datasheet for the chip and check that; I don't know enough about smt rework on what to suggest to fix it if necessary though - but I bet there are others here that would know.
P18F4550
Good advise
If you confident at soldering some liquid flux and desolder braid will sort that, maybe the flux and a hot soldering iron alone will do it.
If your not confident enough the forget what i said just contact the seller
jerseyguy1996
Thanks!  I checked the datasheet and cross checked it against the schematic and all of those pins are grounded so it should be fine as is.  I am hopefully going to try out my first application with it tonight so we will see how it does.
Arduino Uno;
Mega328
pYro_65
I wondered the same thing with mine, but it seems intentional, also mine are bridged in exactly the same place. Puts my mind at ease as I haven't yet tested my board.
Forum Mod anyone?
https://arduino.land/Moduino/
lawren5
I also have the same board and the solder bridges appear in the same places as the photos. I have no problem writing to the SD card but haven't been able to get the ethernet working yet.
jcy123
I know this is an old topic, but did anyone figure out if those solder bridges impacted the usage of ethernet?
pYro_65
No, mine works fine.
It was probably cheaper/easier than running a trace.
Forum Mod anyone?
jcy123
Ok.
I received a replacement board due to the bridging and it also had the pins bridge. The new one worked immediately though. I must have had a separate issue.
I agree, these pins must be OK to bridge.
