Topic: The ClientConstructor Example Does Not Seem To Compile (Read 1 time) previous topic - next topic
12970
Hi Everyone:
I have a Mega with an Ethernet Shield running in "Client" mode using a static IP to address a "server".  (Version 1.0.1)
The code runs very well, except I would like to address the server by name.
As I began looking into this, I decided to cut and paste this code to play around with it.
http://arduino.cc/en/Reference/ClientConstructor
I can NOT figure out what I am doing wrong; but, this code just will not compile for me.
When I look at the .h files, I agree with the compiler errors.
I tried running this under 1.0.1 and 1.0... with essentially the same results.
Any thoughts would be greatly appreciated.
Thanks
-Rick
johnwasser
The first error I got with that code was "Client is now called EthernetClient".  Perhaps using the example for EthernetClient would work better:
http://arduino.cc/en/Reference/EthernetClient
It looks very similar to the Client code except (server, 80) moved from the Client constructor to the client.connect() call.  This allows a single Client instance to connect to different servers at different times.
Code: [Select]
#include <Ethernet.h>
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 10, 0, 0, 177 };
byte server[] = { 64, 233, 187, 99 }; // Google
EthernetClient client;
  Ethernet.begin(mac, ip);
  Serial.println("connecting...");
  if (client.connect(server, 80)) {
    Serial.println("connected");
    client.println("GET /search?q=arduino HTTP/1.0");
    client.println();
    Serial.println("connection failed");
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  if (!client.connected()) {
    Serial.println("disconnecting.");
    client.stop();
    for(;;)
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
12970
Hi John:
This makes sense...  I missed the first error message.
Thanks for taking a look.
-Rick
