Topic: How to solder on a perfboard. (Read 11888 times) previous topic - next topic
Ufoguy
I'm completely new to soldering and I want to make a ldr circuit using a perfboard. I'm having difficulty deciding how to solder on a perf board. Should I use jumper wire  or use solder trails to connect components together? Is there a tutorial or instructable on how to solder on a perf board. Can you give me tips on how to do it. Thank you very much.
If you want to meet a beautiful nurse you must be patient.
Graynomad
Use whatever is easiest, there's no right way.
Often with long-legged components like LDRs you don't cut the the leads but bend them to the next component.
Otherwise use jumper wires.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
Ufoguy
How do I know where to place the components. Do I place them like on a bread board. Is there a program which automatically generates a picture or something on how to place the parts?
Graynomad
Quote
Just figure it out, place components as appropriate, for example if A connects to B then it makes sense for them to be near each other unless there's an overriding reason not to.
Quote
There may be but I will guarantee it will do a crap job, all auto-placement tools do AFAIK.
______
Rob
cyclegadget
You should also think about strip board. It is similar to bread board with parallel traces. Use a dremel or knife to break-up trace lengths.
http://en.wikipedia.org/wiki/Stripboard
Good links: Eagle tutorial= http://www.youtube.com/playlist?list=PLDE1858BD83D19C70
General Arduion tutorials = http://tronixstuff.wordpress.com
http://www.gammon.com.au/forum/bbshowpost.php?bbtopic_id=123
Graynomad
Quote
Or a 1/8th drill bit in a pin vice, I find that's the easiest.
______
Rob
BulletMagnet83
I usually just use hookup wire. Once all my components are in, any leads are trimmed back to about a cm or so. The wires themselves (I use .15/7 PTFE insulated for almost everything low-current) are stripped back to about 4mm, tinned on each end and made into little eyelets around round-nosed pliers. I then hook this over the component lead, press down on the pad with some tweezers and reheat the solder joint. Presto!
It's probably by no means the BEST method, and it does get a bit challenging when there's lots of connections to be made, but it seems to work ok for me!
oric_dan
You asked about using jumper wire or use "solder trails" on a "perfboard", and
GN said use either one. That doesn't sound right. Perfboard typically means a
fiberboard with holes spaced at 0.1" and no traces [stripbars] or pads on the
board. If this is the case, you certainly do not want to use solder trails to
make connections.
If the fiberboard has pads, however, you may get away with using solder trails
to make your connections, but it's still probably better to use short jumpers from
solid wire.
This is assuming that what you mean by "solder trails" is what I assume you
mean. I'm beginning to realize that about 98% of the confusion around this
forum is people using their words to mean different things.
pwillard
There is software... LOCHMASTER is one of them.
Docedison
Adafruit sells a real solder-able Bread Board... Looks just like an 830 point solderless bread board except it requires soldering... one lays out the thing on a 'solderless'  (830 point only) bread board and once it is working as you intended just transfer the parts and jumper wires and it's done.
Doc
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
Docedison
I understand that Lochmaster works well too, makes pretty pictures.
Doc
--> WA7EMS <--
Osgeld
use jumper wire or component leads, you will drive yourself nuts trying to bridge pads
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
nschoonover
Just to round out the software suggestions... Use Fritzing! Its a great way to prototype Arduino and many other things! Its also free!
http://fritzing.org/home/
LarryD
In the olden days, I used stained glass self sticking copper foils.
I used Kapton tape for bridge crossings.
You can get the foil in many different widths.
It gave a nice flat, neat result.
http://www.ebay.ca/sch/Stained-Glass-Supplies-/4770/i.html
http://www.delphiglass.com/stained-glass-supplies/copper-foil-supplies/
http://www.kaptontape.com/
No technical PMs.
The last thing you did is where you should start looking.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
