Pages: [1] 2   Go Down
Author Topic: Negative voltage  (Read 1201 times)
SE USA
@ssh0le
I recently got a LCD module as it was headed to the trash at work (cause the touch screen was smashed, which is just a add on module) I intended to be half way though a library by now, but after making a ribbon cable breakout header and blah blah blah ...
Its one of those units that require a negative voltage to drive the optics!
blah, ok I have a chip that takes 5v and inverts it to -5, so I know they exist, but I really didn't want to wait an extra half week to get a smd model (cause that was all that is available) for the voltages needed (up to -18)
goggling around  I saw a few different ways of doing it, 1 using a 4000 chip (dont remember off hand) and another using a handful of pnp resistors, all seemed like a pita until I found this one which just uses a 555 timer, a couple extra caps and a couple of diodes (which can run upto 15 volts which is close enough for contrast)
http://www.csgnetwork.com/ne555c1.html
so I made it up, not using the recommended components (10nf vs 1, 330uf vs 470, 2k2 vs 2k, and for the diodes I used some standard "power" silicon types) and while not perfect, and I am loosing a little using the silicon diodes, I have to say it is doing the job just fine
so check it out if you have the need
« Last Edit: August 14, 2010, 09:55:50 pm by Osgeld » Logged
B0100111001000011, USA
I'm confused.  Wait, maybe not..
I've never really looked into it, but I just don't get negative voltage...
Isn't it just a power supply connected backwards? smiley-razz
</ignorance>
SE USA
@ssh0le
yea but how do you wire a power supply both backwards and frontwards at the same time smiley (ok its super easy if your using an AC source or batteries, but from a DC wall wart)
btw you would get a kick out of this, its a 240x64 glcd
« Last Edit: August 14, 2010, 10:16:06 pm by Osgeld » Logged
its a 240x64 glcd
:O cool!  You'll have to post about it some time.  What's the chipset?  It's funny that I keep telling myself I shouldn't spend ~20 bucks on stuff I don't need (GLCD), and then I find myself placing a $25 dollar order for things I DEFINITELY don't need smiley-razz.
SE USA
@ssh0le
its using a toshiba T6963C chipset
and here is a pic from google images
England
Isn't it just a power supply connected backwards? Tongue
</ignorance>
kind of, I think the easiest example is a centre tap on a battery connected as ground, the negative end would then become a negative voltage.
yea but how do you wire a power supply both backwards and frontwards at the same time Smiley (ok its super easy if your using an AC source or batteries, but from a DC wall wart)
Use two wall warts, or a dual isolated output one, connect them in series and use the centre wire that you just connected as ground.
North Yorkshire, UK
Umm, nope
Well you know you need one of these:
http://cgi.ebay.co.uk/ART-USED-LCD-graphical-640x480-mono-8-4-EG9018C-/390223734243?pt=LH_DefaultDomain_212
about $12 including postage or something...
...until I found this one which just uses a 555 timer, a couple extra caps and a couple of diodes (which can run upto 15 volts which is close enough for contrast)
Where did you get the +15V from in the first place?
The 555 will just produce some square waves, which can also be produced by a spare Arduino PWM pin... As this will give you -5V only @10mA (whilst the 555 can deliver 100mA) an all purpose NPN transistor is also needed, collector to the higher + voltage.
For peeople interested in this: http://www.holger-klabunde.de/dcdc/picdcdc.htm
It is not English but you need not understand the text, it's all in the diagrams :-)
« Last Edit: August 15, 2010, 09:14:19 am by mpeuser » Logged
That's AWESOME!  Any idea if it's EVER been interfaced to Arduino?  smiley-razz  I suppose it'd be a challenge, but I'd probably fail haha
SE USA
@ssh0le
Im not, im dumping +12v from a wallwart
this thing is expects -18 for its darkest contrast, which is also useless cause then the screen is black, at -9 the contrast is actually just about perfect at -5 its barley visible unless the backlight is off and you hold it at a perfect angle
If I could have ran it off of -5 that would have been convenient, but nope, -11.x while not opaque is more than enough to blacken the entire screen  and have plenty of room for adjustment
« Last Edit: August 15, 2010, 01:40:39 pm by Osgeld » Logged
Katowice POLAND
Please tel me that someone did run that lcd on arduino!
Office meets Adruino
arent you going to need some type of HVT to run the CCFL?
Good catch.  I hadn't noticed that it had a CCFL.
North Yorkshire, UK
http://*Negative voltage generator on board*Inverter for CCFT on board
It's in the pic.
You only need 5v and 5v logic but the arduino would be a bit slow. Nobody has tried it with an arduino yet as far as I know but if I remember, i'll buy one in a few weeks. I doubt I'd get very far though. We need one of our resident LCD experts to buy one!  smiley-grin
Mowcius
Again, nice catch smiley-wink.  I need to read more carefully before posting.  Yeah, I know NOTHING about how LCDs process data, so I'd be a bad one to experiment.  So you don't even need any high (positive) voltages for the LCD drive?
I'm going to post a thread here in Bar Sport asking people who know what they're doing to please try it out ;D
[edit]http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1281907513/0[/edit]
« Last Edit: August 15, 2010, 04:26:18 pm by Tchnclfl » Logged
Pages: [1] 2   Go Up
