Topic: error: expected constructor, destructor, or type conversion (Read 24741 times) previous topic - next topic
rikkifirmansyah
anyone help please i have a errors in this program
Code: [Select]
#include <SD.h>
#include <LiquidCrystal.h>
int CS_pin = 53;
volatile long lastSave = 0; // time value of last save. Relies on realtime clock
volatile long lcdTimeOut = 0; //timer for turning off LCD
volatile int saveInterval = 10; //time between saves (units = seconds, not millis)
volatile int lcdInterval= 60; //time to wait before shutting off LCD (units = seconds)
const int reps = 9; //number of temp readings to average per channel (count from zero)
LiquidCrystal lcd(8,3,4,5,6,7); //RS,EN,DB4,DB5,DB6,DB7
#define muxA0 15
#define muxA1 16
#define muxA2 17
#define tempPin 0
#define lcdLight 9
#define button1 2
int button1INT = 0;
#define aref_voltage 1.1
const int chs = 8;
const int numReadings = 10;
long tempInArray[numReadings][chs];
int index = 0;
long total[chs];
float averages[chs];
void error(char *str)
  lcd.clear();
  lcd.home();
  lcd.print("error: ");
  lcd.print(str);
  while(1);
void setup(void)
  analogReference(INTERNAL1V1);
  pinMode(muxA2, OUTPUT);
  pinMode(muxA1, OUTPUT);
  pinMode(muxA0, OUTPUT);
  pinMode(button1, INPUT);
  digitalWrite(lcdLight, HIGH);
  lcd.begin(20,4);  //(columns,rows)
  lcd.setCursor(0,0);
  lcd.print("Tugas Akhir");
  lcd.setCursor(0,1);
  lcd.print("Miniatur Hujan Salju");
  delay (5000);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print ("Oleh: ");
  lcd.setCursor(0,1);
  lcd.print ("Mochamad Rikki Firmansyah");
  lcd.setCursor(0,2);
  lcd.print ("dan");
  lcd.setCursor(0,3);
  lcd.print ("Ichsan T Primanizar");
  delay (5000);
  lcd.clear();
  //initialize the SD card
  if (!SD.begin(CS_pin))
      lcd.setCursor(0,0);
      lcd.println ("Card Failure ");
      delay (3000);
      lcd.clear();
      return;
      lcd.println ("Card Ready");
      delay (3000);
      lcd.clear();
  //Membaca Konfigurasi command.txt
  File commandFile = SD.open ("COMMAND.txt");
  if (commandFile)
    lcd.setCursor(0,0);
    lcd.println ("Membaca File");
    delay (3000);
    lcd.clear();
    while (commandFile.available());
    lcd.println ("File Tdk Trsedia");
    delay (3000);
    lcd.clear();
  //Write log file
  File logFile = SD.open ("LOG.csv", FILE_WRITE);
  if (logFile)
    logFile.println (", , , , , , , ,");
    String header = "Ch1, Ch2, Ch3, Ch4, Ch5, Ch6, Ch7, Ch8";
    logFile.println (header);
    logFile.close();
    lcd.setCursor (0,0);
    lcd.print  ("data failed");
    delay (2000);
    lcd.clear();
  // Have user select save-data interval and lcd timeout
  // These two lines call sub-routines that are down at the bottom of this file
  saveInterval = saveInt(); //call saveInt sub-function and return value
  lcdInterval = lcdInt();   //call lcdInt sub-function and return value
  // initialize analog temperature value array
  for (int channel = 0; channel < chs; channel++) {
    for (int i = 0; i < numReadings; i++) {
      tempInArray[i][channel] = 0;
i had a errors is
Code: [Select]
sketch_jul03c:169: error: expected constructor, destructor, or type conversion before '=' token
sketch_jul03c:170: error: expected constructor, destructor, or type conversion before '=' token
sketch_jul03c:175: error: expected unqualified-id before 'for'
sketch_jul03c:175: error: expected constructor, destructor, or type conversion before '<' token
sketch_jul03c:175: error: expected constructor, destructor, or type conversion before '++' token
Tom Carpenter
#1
Jul 03, 2012, 06:31 pm Last Edit: Jul 03, 2012, 06:33 pm by TCWORLD Reason: 1
Code: [Select]
You can't just declare stuff like that outside a function. You need to put it inside a function such as void loop(){}, or void setup(){};
I think this is what you were trying to do:
Code: [Select]
#include <SD.h>
int CS_pin = 53;
#define muxA0 15
#define muxA1 16
#define muxA2 17
#define tempPin 0
#define lcdLight 9
#define button1 2
int button1INT = 0;
const int chs = 8;
int index = 0;
long total[chs];
  lcd.clear();
  lcd.home();
  lcd.print(str);
  while(1);
void setup(void)
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  delay (5000);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  lcd.setCursor(0,2);
  lcd.print ("dan");
  lcd.setCursor(0,3);
  delay (5000);
  lcd.clear();
    lcd.setCursor(0,0);
    delay (3000);
    lcd.clear();
    return;
  delay (3000);
  lcd.clear();
  if (commandFile)
    lcd.setCursor(0,0);
    delay (3000);
    lcd.clear();
    delay (3000);
    lcd.clear();
  //Write log file
  if (logFile)
    logFile.close();
    delay (2000);
    lcd.clear();
//Moved brace from here...
} //To here...
~Tom~
E-Xen
Please, who can help me with this problem.
Code: [Select]
//Añadimos la librería servo.h
#include <Servo.h>
//Creamos un objeto Servo
Servo servo1;
int grados = 90; // Grados del servo
int servoPin = 9; // Pin para el Servo
boolean estadoP1; // Estado del pulsador Player 1
boolean estadoP2; // Estado del pulsador Player 1
int rep1 = 0; // Variable para primer ciclo For
int rep2 = 0; // Variable para segundo ciclo For
int numAl = 0; // Numero aleatorio
int time = 0; // Tiempo ejecucion
int time2 = 0; // Tiempo ejecucion 2
int contP1; // Contador pulsos P1
int contP2; // Contador pulsos P2
int freqJuego = 1000; // Tiempo LED apagados
int freqLed = 500; // Tiempo LED encendidos
//Pines para los LED del juego
int pinLedGeneral = 3;
int pinLedErrorP1 = 4;
int pinLedErrorP2 = 5;
int pinLedAciertoP1 = 6;
int pinLedAciertoP2 = 7;
int pinLedP1 = 8;
int pinLedP2 = 10;
int botonP1 = 11;
int botonP2 = 12;
  servo1.attach(servoPin); // Asignamos servoPin como Servo
  servo1.write(0); // Lo mandamos al grado 0
  delay(800); // Le damos tiempo a que llegue
  servo1.write(179); // Lo mandamos al grado 179
  servo1.write(grados); // Lo llevamos al punto de partida
  //Establecemos la configuracion de lo Pines
  pinMode(pinLedGeneral, OUTPUT);
  pinMode(pinLedErrorP1, OUTPUT);
  pinMode(pinLedErrorP2, OUTPUT);
  pinMode(pinLedAciertoP1, OUTPUT);
  pinMode(pinLedAciertoP2, OUTPUT);
  pinMode(pinLedP1, OUTPUT);
  pinMode(pinLedP2, OUTPUT);
  pinMode(botonP1, INPUT);
  pinMode(botonP2, INPUT);
  numAl = random(0, 99); // Generamos un numero aleatorio
  time = millis(); // Almacenamos el tiempo
  contP1 = 0; // Establecemos el contaador a cero
  contP2 = 0; // Establecemos el contaador a cero
  // Comprobamos que la velocidad del juego no sea demasiado alta
  if (freqJuego < 50)
    Ganador();
  // Disminuimos tiempos
  freqJuego = (freqJuego - 10);
  freqLed = (freqLed - 4);
  // Encendemos un LED y comprobamos si
  // pulsa durante el LED encendido el jugador correcto
  while ((time2 - time) <= freqLed)
    time2 = millis();
    if ((numAl % 2) == 0) // Led Player 1
      digitalWrite(pinLedP1, HIGH);
      digitalWrite(pinLedP2, LOW);
      estadoP1 = digitalRead(botonP1);
      estadoP2 = digitalRead(botonP2);
      if ((estadoP1 == true) & (contP1 == 0))
        BienP1();
      if ((estadoP2 == true) & (contP2 == 0))
        P2Error();
    // Led Player 2
      digitalWrite(pinLedP1, LOW);
      digitalWrite(pinLedP2, HIGH);
        BienP2();
        P1Error();
// Apagamos los LED
//Comprobamos que nadie pulse mientras estan apagados
time = millis();
while ((time2 - time) <= freqJuego)
  time2 = millis();
    P1Error();
    P2Error();
// Rutina para comprobar si ha gandao P1
void GanaPlayer1()
  if (grados == 170)
    digitalWrite(pinLedAciertoP1, HIGH);
    digitalWrite(pinLedAciertoP2, LOW);
    digitalWrite(pinLedErrorP1, LOW);
    digitalWrite(pinLedErrorP2, LOW);
    Ganador();
// Rutina para comprobar si ha gandao P2
void GanaPlayer2()
  if (grados == 10)
    digitalWrite(pinLedAciertoP1, LOW);
    digitalWrite(pinLedAciertoP2, HIGH);
    Ganador();
// Rutina cuado pulsa correctamente P1
void BienP1()
  contP1++;
  grados = (grados + 10);
  GanaPlayer1();
// Rutina cuado pulsa correctamente P2
void BienP2()
  contP2++;
  grados = (grados - 10);
  GanaPlayer2();
// Rutina cuado pulsa mal P1
void P1Error()
  contP1++;
  digitalWrite(pinLedErrorP1, HIGH);
  GanaPlayer2();
// Rutina cuado pulsa mal P2
void P2Error()
  contP2++;
  digitalWrite(pinLedErrorP2, HIGH);
  GanaPlayer1();
// Rutina cuando alguien gana el juego
void Ganador()
  for (rep1=0; rep1<3; rep1++)
    servo1.write(0);
    for (rep2=10; rep2<250; rep2++)
      analogWrite(pinLedGeneral, rep2);
      delay(3);
    servo1.write(179);
    for (rep2=250; rep2>10; rep2--)
      delay(3);
  digitalWrite(pinLedGeneral, LOW);
  grados = (90);
  delay(5000);
  freqJuego = 100;
  freqLed = 500;
This is the problem:
game.ino:108:13: error: expected constructor, destructor, or type conversion before '(' token
game.ino:109:13: error: expected constructor, destructor, or type conversion before '(' token
game.ino:112:1: error: 'time' does not name a type
game.ino:113:1: error: expected unqualified-id before 'while'
 enabled in File > Preferences.
christop
E-Xen: read the thread that you hijacked. Your program has the same problem and the same solution.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
