Topic: New library for PWM playback from SD cards: SimpleSDAudio (Read 105923 times) previous topic - next topic
Tuttut
Jul 03, 2012, 09:24 pm Last Edit: Jan 23, 2013, 01:24 am by Tuttut Reason: 1
Hello,
I like to promote my new library which makes playback of audio from SD cards very simple. The audio quality is 8-bit, but a PWM frequency of 62.5 kHz is used which gives decent sound quality at very low effort. The library is completely free, fully documented and includes some example projects for quick start. Enjoy, feedback here if you like it.
Edit/New: I updated the library (ported the core output part to hand-optimized ASM) and now also 16 Bit audio output (even in stereo) is possible (combining two PWM outputs using 2 resistors, known as 256R-R-network).
Edit/New: I updated the library again and now you don't have to call the .worker() function anymore if you provide a flag at init. Also added more examples like a doorbell with ding-dong sound as well as an example that shows file access from SD card using this library.
Regards,
Lutz
xl97
#2
Jul 05, 2012, 05:27 pm Last Edit: Jul 05, 2012, 06:10 pm by xl97 Reason: 1
cant wait to play with it!..
Audio & Arduino is a hard thing for noobies (like myself) to achieve...
havent read it yet.. does it play .wav files? or do you have to convert to a specific format first to play off SD?
update: read link.. yep I saw you have to convert the files to another format..
thanks
Tuttut
Yes, you have to convert the files, but for Windows users the conversion is a simple drag'n'drop operation of the wav-file to a batch-file. I also show a very simple and cheap approach to build an SD-card adapter just from two standard pin-headers.
Tuttut
I also thought about that, but the thing is that it is hard to get a high quality playback if PWM runs not at an integer multiple of the sample rate. That is the magic behind my library and that is why I can get such good quality. With high-speed PWM as available in ATtiny85 then it makes more sense to use the original playback rate (as Elm-Chan does).
funkyguy4000
Accelerate to 88 miles per hour.
WilliamK Govinda
I love this, thank you, sounds pretty good, a bit of hiss, so I have to see how to clean it up.
Questions:
1) could you add an option for 20Mhz too? I got some 20Mhz crystals and ATmega328 chips lying around, wondering if at 20Mhz I could play stereo files better?
2) I did a PWM output that was nearly 10 bits, with a better audio. Check this out:
https://github.com/Beat707/BeatVox
Tuttut
Hello,
1)
it would work with 20 MHz, but not better regarding stereo playback at full rate, because this is just a matter of free cycles. But with 20 MHz fullrate will be 78kHz, so just a little better. I think the next improvement I will make is to use a 256R-R network to go from 8 bit to 16 bit with just another port and 3 resistors.
2)
I don't find the circuit for the audio output. Increasing bit resolution is always about decreasing PWM frequency, the only way around is to use either a AVR with high-speed PWM (like Elm-Chan did with ATtiny85) or combining two PWM outputs.
WilliamK Govinda
Niiice, I wonder about that.
Plus, I wonder about the ATtiny85 too.
Thanks!  8)
WilliamK Govinda
Question about the ATtiny85, as I also use those and have a few to test out, what kind of bit-depth are we talking with those? I'm not talking about SD card playback, just internal flash playback, as I'm doing another project, and all I need is to be able to play a single drum sound from the ATtiny85, but I need better quality, as better possible. ;-)
Thanks again!  :smiley-mr-green:
WilliamK Govinda
Maybe this could help you getting 16-bit using 2 PWM outputs?
http://embeddednewbie.blogspot.com.br/2011/02/review-of-arduino-dac-solutions.html
Resistor/PWM hybrid DAC
This is a good explanation on how to combine two PWM outputs in order to double the bit resolution. So combining two 8-bit arduino PWM outputs you can get a 16-bit PWM output! Remember Arduino's limits if you plan on going down this road. I mean, the Atmega chip is just 8-bit...
Tuttut
#14
Jul 16, 2012, 11:47 pm Last Edit: Jul 17, 2012, 12:05 am by Tuttut Reason: 1
now I tried the 16-bit thing with the R256-R DAC and it gives a big advantage. It is not as good as you would expect from 16-Bit because it is hard to get rid of all those digital noise in such a circuit. The problem with all those circuits is to keep away the digital noise from supply from audio output. As long as a digital output pin that is supplied from uC is used, you also hear all the uC noise. Maybe it gets better if you decouple the uC better or use something like a buffer. But simply said, using just those two additional resistors you get rid of those hiss noise. After playing a little bit around it seems that most noise comes from the USB port - maybe you get acceptable results by using battery power.
What I did is the following: I set the following mode in software:
SdPlay.init(SSDA_MODE_HALFRATE | SSDA_MODE_STEREO)
Then I prepared my file with the following modified batch-file:
@echo off
cd %~dp0
mkdir converted
FOR %%A IN (%*) DO sox %%A --norm=-1 -e unsigned-integer -b 16 -r 31250 -c 1 -t raw "converted\%%~nA.ahd"
pause
Connections I made:
Pin 9  ----[220k]------+
                      |  100nF
Pin 10 -[1k trimmer]---+---||----[10k]--AudioOut--[1k]--GND
With trimmer the sound can adjusted for minimum hiss, I prepared also a special audio-file for easier trimming.
