Topic: New library for PWM playback from SD cards: SimpleSDAudio (Read 84524 times) previous topic - next topic
WilliamK Govinda
Ohhh, very nice! I need to download a library update, right? Thanks again for such hard work!  8)
Tuttut
No, I have not changed the library yet. Maybe I will do it later after documenting it better - you only need the new batch file. We should try level-shifters or buffers (anything that is very cheap and easy available) to improve the sound (should be placed between Arduino outputs 9/10 and resistor stuff.
WilliamK Govinda
I haven't messed out with the library source yet, but do you think it would be possible to get a more instant playback and re-play by setting an initial file, and just have it play, and re-play when requested? This way I could use this to playback long drum sounds. (crashes and cymbals) I need this for a small project I'm doing. ;-) Maybe an option to open the file and have it used until said to open a new one? Also, an option to re-start the file, even if its not done yet, for when you play a drum sound, you are in the middle, but needs to re-trigger the sound.
WilliamK Govinda
I wonder one thing, would it be possible to handle 16-bit stereo files? Using 4 x pwm outputs for 2 x 16-bit hybrid dacs? What's the limitation them? I see that a 5Mb SD Card can handle it without problems, is the bottle-neck the SPI or the ATmega itself? Maybe running at 20Mhz would help? Just wondering, as it would be KILLER to be able to play 16-bit stereo files.
WilliamK Govinda
In any event, it should be possible to handle mono 16-bit 31khz .WAV files now, right? I know how to handle WAV files, so I will see if I can be of any help on this...
WilliamK Govinda
With this I got a perfect loop:
while (1)
    // Start playback
    SdPlay.play();
    // Let the worker work until playback is finished
    while(!SdPlay.isStopped()) {
      SdPlay.worker();
WilliamK Govinda
I just tested the 16-bit hybrid dac with your code, as explained, and I love it, great quality!  8) I hear a strange buzz on the background, is that the PWM? I'm using an external power-adapter and running the ATmega328 at 3.3V, to keep the SD Card connections simpler.
I haven't done your full 16-bit dac specs, I used a 256k and just one 1k resistor, so now I will try the way you did, to see if the buzz goes away. ;-)
Thank you so much for the hard work on this lib!!  :smiley-mr-green:
WilliamK Govinda
The project I'm working requires 4 loops to be played, not at the same time, but with the option to go from one to another. So I wonder if I could do some sort of pre-buffering for all 4 files, in a way I could just go from one to another with min. gaps?
WilliamK Govinda
Ok, I found the buzz sound problem. It was the 3.3 V thingy. Now I'm running at 5V and using a proper SD Card adapter for Arduino (it has all the voltage converters) and it sounds GREAT! Thanks again!  8) 8)
WilliamK Govinda
Darn, the buzzing sound is still there, its from the PWM output. But its much lower now, compared to before.
WilliamK Govinda
Ok, assuming you can also hear the buzzing sound there, how about using 2 timers? One for the DAC and another one for the sample-rate. For instance, Timer1, which you already use now for both sample-out and sample-buffering, you could leave just for the DAC and setup for 9 bits, so the frequency of PWM is much faster. Then another timer for the rest, lets say, Timer2.
I will check the code when possible to see if I could just hack it and hear the result.
At least on my 6-voice sampler I did it with a higher frequency PWM using Timer1 and there's no buzzing sound. Unless my chip is faulty. I will test my 6-voice sampler on this same setup, just in case. ;-) Here's the link: https://github.com/Beat707/BeatVox
Again, thanks for doing this lib, I'm really loving it!  8)
WilliamK Govinda
Darn, I can't figure out this buzzing sound, no idea where its coming from, maybe the SPI interface? (doubt that) What I see you did different from my 6-voice thingy, is that you take a bit to update the PWM outputs, I do it first-thing, from a 2-byte buffer, maybe that could help? I will try that. ;-)
WilliamK Govinda
Darn thing, it does sound like the SPI. Here's a simple test.
uint8_t bufferL = 80, bufferR = 80;
void SdPlayClass::interrupt(void)
//SSDA_OC1L = bufferL;
//SSDA_OC2L = bufferR;
SSDA_OC1L = 255;
SSDA_OC2L = 255;
  uint8_t  flags = _flags;  // local copy for faster access
  SdPlay.init(SSDA_MODE_HALFRATE | SSDA_MODE_STEREO);
  SdPlay.setFile("Loop5.a16"); // 16-bit mono file - half rate
   while (1)
     SdPlay.play(); while(!SdPlay.isStopped()) { SdPlay.worker(); }
     pinMode(SCK, INPUT);
     digitalWrite(SCK, HIGH);
     pinMode(SCK, OUTPUT);
I can hear the buzzing sound, once the loop is done, it will pause for 1 second without the buzz sound.
Unless I'm doing this test wrong. ;-)
WilliamK Govinda
Well, it does seem to be the SPI clock leaking somewhere, not sure what to do... any ideas?  :smiley-red:
Tuttut
the buzzing sound can come from anything on the Arduino or stuff connected to it. I don't think that you can get rid of it just by optimizing the software - increasing sample rate will not change things. The quality out of the PWM is already superior, but get's damaged by the noise on the supply lines.
Therefore as I proposed before try to use something that "isolates" the digital PWM lines from power source. Use a buffer or a level shifter. Then filter the supply for that level shifter very thouroughly  using an own linear regulator or at least a serial resistor with a capacitor to gnd between VCC-digital and VCC-analog.
Regarding 4channel mode: If I translate the interrupt function to assembler then it should be possible to have enough computing power for stereo 16 bit playback...
Regarding pre-load: The function setFile stores internally something about the file in a small structure. By using that struct it should be possible to playback any file with very little latency. Maybe I will add this feature later to the library.
