Loading...
Pages: [1]   Go Down
Author Topic: How to solder on a perfboard.  (Read 727 times)
India
Offline Offline
Full Member
So, you want to make something, huh?
View Profile
I'm completely new to soldering and I want to make a ldr circuit using a perfboard. I'm having difficulty deciding how to solder on a perf board. Should I use jumper wire  or use solder trails to connect components together? Is there a tutorial or instructable on how to solder on a perf board. Can you give me tips on how to do it. Thank you very much.
Logged
If you want to meet a beautiful nurse you must be patient.
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Use whatever is easiest, there's no right way.
Often with long-legged components like LDRs you don't cut the the leads but bend them to the next component.
Otherwise use jumper wires.
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
India
Offline Offline
Full Member
View Profile
How do I know where to place the components. Do I place them like on a bread board. Is there a program which automatically generates a picture or something on how to place the parts?
Logged
Offline Offline
Tesla Member
View Profile
WWW
Quote
Just figure it out, place components as appropriate, for example if A connects to B then it makes sense for them to be near each other unless there's an overriding reason not to.
Quote
There may be but I will guarantee it will do a crap job, all auto-placement tools do AFAIK.
______
Rob
Logged
Greenville, IL
Offline Offline
Edison Member
Warning Novice on board! 0 to 1 chance of errors!
View Profile
 You should also think about strip board. It is similar to bread board with parallel traces. Use a dremel or knife to break-up trace lengths.
http://en.wikipedia.org/wiki/Stripboard
Logged
Offline Offline
Tesla Member
View Profile
WWW
Quote
Or a 1/8th drill bit in a pin vice, I find that's the easiest.
______
Rob
Logged
South England
Offline Offline
Full Member
View Profile
I usually just use hookup wire. Once all my components are in, any leads are trimmed back to about a cm or so. The wires themselves (I use .15/7 PTFE insulated for almost everything low-current) are stripped back to about 4mm, tinned on each end and made into little eyelets around round-nosed pliers. I then hook this over the component lead, press down on the pad with some tweezers and reheat the solder joint. Presto!
It's probably by no means the BEST method, and it does get a bit challenging when there's lots of connections to be made, but it seems to work ok for me!
Logged
the land of sun+snow
Offline Offline
Edison Member
View Profile
WWW
You asked about using jumper wire or use "solder trails" on a "perfboard", and
GN said use either one. That doesn't sound right. Perfboard typically means a
fiberboard with holes spaced at 0.1" and no traces [stripbars] or pads on the
board. If this is the case, you certainly do not want to use solder trails to
make connections.
If the fiberboard has pads, however, you may get away with using solder trails
to make your connections, but it's still probably better to use short jumpers from
solid wire.
This is assuming that what you mean by "solder trails" is what I assume you
mean. I'm beginning to realize that about 98% of the confusion around this
forum is people using their words to mean different things.
Logged
Something different - Kitchen-Sink Arduino-compatible boards
Cumming, Ga
Offline Offline
Edison Member
Ultimate DIY: Arduino
View Profile
WWW
There is software... LOCHMASTER is one of them.
Logged
Anaheim CA.
Offline Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
View Profile
Adafruit sells a real solder-able Bread Board... Looks just like an 830 point solderless bread board except it requires soldering... one lays out the thing on a 'solderless'  (830 point only) bread board and once it is working as you intended just transfer the parts and jumper wires and it's done.
Doc
Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Anaheim CA.
Offline Offline
Edison Member
View Profile
I understand that Lochmaster works well too, makes pretty pictures.
Doc
Logged
SE USA
Online Online
Faraday Member
@ssh0le
View Profile
use jumper wire or component leads, you will drive yourself nuts trying to bridge pads
Logged
Pages: [1]   Go Up
Print
Jump to:
