Topic: I am trying to get higher speed for a stepper motor (Read 413 times) previous topic - next topic
ksshhs
I am trying to get higher speed for a stepper motor with this code below.
is there any other way I can get higher speed.
also I want to make speed decreasing gradually.
any advice?
//©2011 bildr
//Released under the MIT License - Please reuse change and share
//Using the easy stepper with your arduino
//use rotate and/or rotateDeg to controll stepper motor
//speed is any number from .01 -> 1 with 1 being fastest -
//Slower Speed == Stronger movement
#define DIR_PIN 2
#define STEP_PIN 3
  pinMode(DIR_PIN, OUTPUT);
  pinMode(STEP_PIN, OUTPUT);
void loop(){
  rotate(16000, .900);
  delay(0);
void rotate(int steps, float speed){
  //rotate a specific number of microsteps (8 microsteps per step) - (negitive for reverse movement)
  //speed is any number from .01 -> 1 with 1 being fastest - Slower is stronger
  int dir = (steps > 0)? HIGH:LOW;
  steps = abs(steps);
  digitalWrite(DIR_PIN,dir);
  float usDelay = (1/speed) * 70;
  for(int i=0; i < steps; i++){
    digitalWrite(STEP_PIN, HIGH);
    delayMicroseconds(usDelay);
    digitalWrite(STEP_PIN, LOW);
PeterH
You have already asked this question in another thread.
AWOL
Specifically here.
OP, you've already been asked not to cross-post.
DON'T DO IT.
