Topic: Arduino powered ECU for diesel engines (Read 22845 times) previous topic - next topic
UnaClocker
Why use a Mega when the DUE is out now? The DUE has oodles of ram, as well as having a native CAN bus. It'd make an awesome ECM.
Oldbeaver
I once bought an engine without original ECU unit at all. So i did have choice to find original ecu or bring own solution for that, and i did choose later option.
So here is it, running fine on test bench: http://www.youtube.com/watch?v=qj0S2_57EU4&feature=player_embedded
This engine (Audi 5cylinder TDI) has Bosch VP37 injection pump on it. I had to fully reverse engineer all controlling parameters for it.
Configuration can be done over USB real time (ANSI/VT102 text-mode user interface), there is also Debugging and Monitor software written in processing which includes meters display, data logging and of cource - terminal emulator for to connect the boards UI.
More information on my website: http://dmn.kuulalaakeri.org/dmn-edc/
Very nice Project. Please continue posting yr progress.
janost
Simple answer: The ATmega chip is like $4?
rusefi
Are you still playing with all this?
I am involved with another DIY ECU project and I wonder if you have the time to help us add diesel support, at least by trying our board & code on your test engine?
