I am new to this and trying to test my cards connectivity i am using a basic sketch as below but Whenever i try to monitor it with the serial monitor it drops the ip connectivity is this normal or am i doing something wrong?
Web client
This sketch connects to a website (
http://www.google.com)
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 18 Dec 2009
by David A. Mellis
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x81, 0x30 };
byte ip[] = { 192,168,0,80 };
byte gateway[] = { 192,168,0,98 };
byte subnet[] = { 255, 255, 255, 0 };
IPAddress server(74, 125, 113, 99); // Google
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
// start the serial library:
// start the Ethernet connection:
Ethernet.begin(mac,ip,gateway);
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.println("connected");
// Make a HTTP request:
client.println("GET /search?q=arduino HTTP/1.0");
client.println();
else {
// kf you didn't get a connection to the server:
Serial.println("connection failed");
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println();
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
for(;
