Loading...
Pages: [1]   Go Down
Author Topic: Anyone using SD.h with Leonardo?  (Read 1883 times)
0
Offline Offline
Edison Member
Arduino rocks
View Profile
Anyone tried SD.h with Leonardo?
While updating SdFat for Leonardo, I realized that the version of SdFat used in Arduino 1.01 assumes an ATmega32U4 is a Teensy 2.0.
I tried SD.h with a Leonardo and a SD in the Ethernet shield and it failed.
I modified the SD library by editing Sd2Card.h in the SD/utility folder.
I changed this:
Code:
/** The default chip select pin for the SD card is SS. */
uint8_t const  SD_CHIP_SELECT_PIN = SS_PIN;
// The following three pins must not be redefined for hardware SPI.
/** SPI Master Out Slave In pin */
uint8_t const  SPI_MOSI_PIN = MOSI_PIN;
/** SPI Master In Slave Out pin */
uint8_t const  SPI_MISO_PIN = MISO_PIN;
/** SPI Clock pin */
uint8_t const  SPI_SCK_PIN = SCK_PIN;
To this:
Code:
#include <Arduino.h>
uint8_t const  SD_CHIP_SELECT_PIN = SS;
uint8_t const  SPI_MOSI_PIN = MOSI;
uint8_t const  SPI_MISO_PIN = MISO;
uint8_t const  SPI_SCK_PIN = SCK;
That made this version of the ReadWrite example work with Leonardo and a SD in the Ethernet shield.
Code:
  SD card read/write
 This example shows how to read and write data to and from an SD card file
 The circuit:
 * SD card attached to SPI bus as follows:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 4
 created   Nov 2010
 by David A. Mellis
 modified 9 Apr 2012
 by Tom Igoe
 This example code is in the public domain.
#include <SD.h>
File myFile;
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // disable Ethernet
   pinMode(10, OUTPUT);
   digitalWrite(10, HIGH);
  Serial.print("Initializing SD card...");
  // On the Ethernet Shield, CS is pin 4. It's set as an output by default.
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  myFile = SD.open("test.txt", FILE_WRITE);
  // if the file opened okay, write to it:
  if (myFile) {
    Serial.print("Writing to test.txt...");
    myFile.println("testing 1, 2, 3.");
// close the file:
    myFile.close();
    Serial.println("done.");
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
  // re-open the file for reading:
  myFile = SD.open("test.txt");
  if (myFile) {
    Serial.println("test.txt:");
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
    Serial.write(myFile.read());
    // close the file:
    myFile.close();
// nothing happens after setup
Logged
Offline Offline
Newbie
View Profile
Yes i am using this version.
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
The new version of SdFat now supports the Leonardo for both Hardware SPI and Software SPI.  It is sdfatlib20120719.zip at http://code.google.com/p/sdfatlib/downloads/list.
By default Software SPI supports the pin configuration for 328 shields with:
Code:
/** Software SPI Master Out Slave In pin */
uint8_t const SOFT_SPI_MOSI_PIN = 11;
/** Software SPI Master In Slave Out pin */
uint8_t const SOFT_SPI_MISO_PIN = 12;
/** Software SPI Clock pin */
uint8_t const SOFT_SPI_SCK_PIN = 13;
To use Software SPI on Leonardo and Hardware SPI with other CPUs, edit SdFatConfig.h at about line 121 like this:
Code:
#define LEONARDO_SOFT_SPI 1
Logged
Pages: [1]   Go Up
Print
Jump to:
