Topic: Qt Creator Arduino Project wizard (Read 4043 times) previous topic - next topic
arcachofo
I'm using the Qt Creator Custom wizards feature to create Arduino Projects based on makefile (Linux).
The makefile is based on this one: http://mjo.tc/atelier/2009/02/arduino-cli.html with some modifications
Has someone tried to use Qt Creator this way?
There are some things i would like to improve, but i'm little stucked, so any collaboration is very welcome.
Files can be dowloaded from here: http://sourceforge.net/projects/qtarduino/
There is a readme, but if someone needs any help or explanation just ask here or in the project forum.
Best Regards.
NeoStark
Your right in saying the README is limited. What platform are you on?
I'm using Ubuntu 12.04, when I create a Arduino project, I have difficulty uploading my project to my arduino.
no problem using Terminal:
Code: [Select]
$ cd <path to project>
$ make clean
$ make
$ make upload
using the terminal I can compile and upload my project to the arduino but have not yet found out how to upload via Qt Creator.
btw installing gtkterm is helpful when using 'Serial.println();'.
getting this error:
Code: [Select]
/usr/share/arduino/Arduino.mk:513: build-cli/depends.mk: No such file or directory
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
