Author Topic: LM 35 DZ + Arduino  (Read 559 times)
Germany
My Problem is that my LM 35 DZ is not working right. Serial Monitor:
3.42
11.23
38.09
24.90
0.00
115.72
118.65
33.20
13.67
43.95
25.39
27.83
16.60
100.10
112.79
example code
float temp;
int tempPin = 5;
  temp = analogRead(tempPin);
  temp = temp * 0.48828125;
  Serial.println(temp);
I've connected it like described on the data sheet. Flat surface on top. Left = VCC (5V) center = Data (A5), Right = GND
I've tested 5 of them with the same result.
What is wrong?
« Last Edit: July 06, 2012, 10:19:16 am by heckmic » Logged
Did you connect it to digital input 5, while you are reading analog input A5 ?
It looks like if the input A5 is not connected.
Germany
Sorry, i connected it do A5. I've corrected it on top.
Hello,
This link will help you.
http://www.ladyada.net/learn/sensors/tmp36.html
Germany
I know this link. But it dont helped me...
Can you measure the output voltage of the sensor with a multimeter ?
Germany
Its 0.45 Volts
Its 0.45 Volts
If that is stable, the analogRead() must be stable.
Can you try this:
double temp;
int tempPin = 5;
  int rawADC;
  rawADC = analogRead(tempPin);
  Serial.print("rawADC = ");
  Serial.print(rawADC,DEC);
  temp = (double) rawADC * 0.48828125;
  Serial.print(", temp = ");
If that doesn't work well, try a different analog pin and perhaps upload a photo of how it is connected.
Germany
Yes, voltage is stable. When i take the LM in my Hand it raises constantly. So everything looks good.
But in Terminal:
rawADC = 48, temp = 23.44
rawADC = 54, temp = 26.37
rawADC = 65, temp = 31.74
rawADC = 73, temp = 35.64
rawADC = 0, temp = 0.00
rawADC = 61, temp = 29.79
rawADC = 91, temp = 44.43
rawADC = 112, temp = 54.69
rawADC = 78, temp = 38.09
rawADC = 9, temp = 4.39
rawADC = 66, temp = 32.23
rawADC = 29, temp = 14.16
rawADC = 50, temp = 24.41
rawADC = 45, temp = 21.97
« Last Edit: July 06, 2012, 02:16:18 pm by heckmic » Logged
Thanks.
So the sensor is good. And your readings are all over the place.
I can't think of anything else than that the wiring is not right.
(1) try my little sketch -> check, you've done that
(2) upload a photo of your wiring.
(3) try a different analog input pin
(4) Use a power supply for the Arduino (not just the USB power).
(5) Connect all digital and analog pins one by one to ground, while the sketch is running and see if something changes.
(6) try a different Arduino
(7) connect a potmeter to the analog input pin and vary that.
Germany
on the right my relay connected to my fans for cooling my reef tank.
Another analog input is used now (A0).
« Last Edit: July 06, 2012, 02:32:22 pm by heckmic » Logged
Brunsbüttel, SH, F.Rep.GERM
what if u disconnect A0 and pull it high internally?
pinMode(14,INPUT); digitalWrite(14,HIGH);
http://arduino.cc/en/Reference/DigitalWrite
-Arne
Germany
Thank you for all help. I've managed it! - The Problem was a hair thin wire with connected  A0 AND A1.
I'm glad you found it !
