Author Topic: put these into a Uno  (Read 419 times)
Nottingham, UK
I have just purchased the following 2x ATMEGA328-PU Arduino UNO Bootloader,
Will i be able to drop these chips direct into my Uno and program them?.
Thanks.
If they have a boot loader already they should work fine.
Boston area, metrowest
You may get a Signature Byte error. If you do, its pretty easy to make a file change to have them recognized.
Nottingham, UK
Thanks.
Europe
how to fix signature byte error?????
Canada
Code Monkey
You need to tweak the avrdude.conf file to include sections for the chip variation you have. You describe its signature and fuses. Search for avrdude.conf here.
I yield() for co-routines.
Denmark
Take a look at this:
http://arduino.cc/forum/index.php/topic,98956.0.html
Find avrdude.conf in this folder:
C:\Arduino-1.0.1\hardware\tools\avr\etc
copy the '328 section and paste it at the end.
Change the couple of lines I have indicated with <<< below
# ATmega328P                                               <<< <<<  change to ATMEGA328
part
    id         = "m328p";    <<< change to m328
    desc      = "ATMEGA328P";           <<<  change to ATMEGA328
    has_debugwire   = yes;
    flash_instr      = 0xB6, 0x01, 0x11;
    eeprom_instr   = 0xBD, 0xF2, 0xBD, 0xE1, 0xBB, 0xCF, 0xB4, 0x00,
           0xBE, 0x01, 0xB6, 0x01, 0xBC, 0x00, 0xBB, 0xBF,
           0x99, 0xF9, 0xBB, 0xAF;
    stk500_devcode   = 0x86;
    # avr910_devcode   = 0x;
    signature      = 0x1e 0x95 0x0F;   <<<  change to 0x1E 0x95 0x14 >>> I think rest of this stays the same
    pagel      = 0xd7;
    bs2         = 0xc2;
    chip_erase_delay   = 9000;
    pgm_enable = "1 0 1 0 1 1 0 0 0 1 0 1 0 0 1 1",
       "x x x x x x x x x x x x x x x x";
    chip_erase = "1 0 1 0 1 1 0 0 1 0 0 x x x x x",
    timeout   = 200;
    stabdelay   = 100;
    cmdexedelay   = 25;
    synchloops   = 32;
    bytedelay   = 0;
    pollindex   = 3;
    pollvalue   = 0x53;
    predelay   = 1;
    postdelay   = 1;
    pollmethod   = 1;
    pp_controlstack =
   0x0E, 0x1E, 0x0F, 0x1F, 0x2E, 0x3E, 0x2F, 0x3F,
   0x4E, 0x5E, 0x4F, 0x5F, 0x6E, 0x7E, 0x6F, 0x7F,
   0x66, 0x76, 0x67, 0x77, 0x6A, 0x7A, 0x6B, 0x7B,
   0xBE, 0xFD, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00;
    hventerstabdelay   = 100;
    progmodedelay   = 0;
    latchcycles      = 5;
    togglevtg      = 1;
    poweroffdelay   = 15;
    resetdelayms   = 1;
    resetdelayus   = 0;
    hvleavestabdelay   = 15;
    resetdelay      = 15;
    chiperasepulsewidth   = 0;
    chiperasepolltimeout = 10;
    programfusepulsewidth = 0;
    programfusepolltimeout = 5;
    programlockpulsewidth = 0;
    programlockpolltimeout = 5;
    memory "eeprom"
   paged      = no;
   page_size   = 4;
   size      = 1024;
   min_write_delay = 3600;
   max_write_delay = 3600;
   readback_p1   = 0xff;
   readback_p2   = 0xff;
   read = " 1 0 1 0 0 0 0 0",
          " 0 0 0 x x x a9 a8",
          " a7 a6 a5 a4 a3 a2 a1 a0",
          " o o o o o o o o";
   write = " 1 1 0 0 0 0 0 0",
      " i i i i i i i i";
   loadpage_lo = " 1 1 0 0 0 0 0 1",
            " 0 0 0 0 0 0 0 0",
            " 0 0 0 0 0 0 a1 a0",
            " i i i i i i i i";
   writepage = " 1 1 0 0 0 0 1 0",
          " 0 0 x x x x a9 a8",
          " a7 a6 a5 a4 a3 a2 0 0",
          " x x x x x x x x";
   mode      = 0x41;
   delay      = 20;
   blocksize   = 4;
   readsize   = 256;
    memory "flash"
   paged      = yes;
   size      = 32768;
   page_size   = 128;
   num_pages   = 256;
   min_write_delay = 4500;
   max_write_delay = 4500;
   readback_p1   = 0xff;
   readback_p2   = 0xff;
   read_lo = " 0 0 1 0 0 0 0 0",
        " 0 0 a13 a12 a11 a10 a9 a8",
        " o o o o o o o o";
   read_hi = " 0 0 1 0 1 0 0 0",
        " o o o o o o o o";
   loadpage_lo = " 0 1 0 0 0 0 0 0",
            " 0 0 0 x x x x x",
            " x x a5 a4 a3 a2 a1 a0",
            " i i i i i i i i";
   loadpage_hi = " 0 1 0 0 1 0 0 0",
            " 0 0 0 x x x x x",
            " i i i i i i i i";
   writepage = " 0 1 0 0 1 1 0 0",
          " a7 a6 x x x x x x",
          " x x x x x x x x";
   mode      = 0x41;
   delay      = 6;
   blocksize   = 128;
   readsize   = 256;
    memory "lfuse"
   size = 1;
   read = "0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 0",
          "x x x x x x x x o o o o o o o o";
   write = "1 0 1 0 1 1 0 0 1 0 1 0 0 0 0 0",
            "x x x x x x x x i i i i i i i i";
    memory "hfuse"
   size = 1;
   read = "0 1 0 1 1 0 0 0 0 0 0 0 1 0 0 0",
   write = "1 0 1 0 1 1 0 0 1 0 1 0 1 0 0 0",
    memory "efuse"
   size = 1;
   read = "0 1 0 1 0 0 0 0 0 0 0 0 1 0 0 0",
          "x x x x x x x x x x x x x o o o";
   write = "1 0 1 0 1 1 0 0 1 0 1 0 0 1 0 0",
            "x x x x x x x x x x x x x i i i";
    memory "lock"
   size = 1;
   read = "0 1 0 1 1 0 0 0 0 0 0 0 0 0 0 0",
          "x x x x x x x x x x o o o o o o";
   write = "1 0 1 0 1 1 0 0 1 1 1 x x x x x",
            "x x x x x x x x 1 1 i i i i i i";
    memory "calibration"
   size = 1;
   read = "0 0 1 1 1 0 0 0 0 0 0 x x x x x",
          "0 0 0 0 0 0 0 0 o o o o o o o o";
    memory "signature"
   size = 3;
   read = "0 0 1 1 0 0 0 0 0 0 0 x x x x x",
          "x x x x x x a1 a0 o o o o o o o o";
« Last Edit: July 07, 2012, 02:47:32 pm by CrossRoads » Logged
Find boards.txt in this folder:
C:\Arduino-1.0.1\hardware\arduino
Copy this section, paste it at end, make these changes as indicated by <<<
In both cases, I used free download of Notepad++ for editing, lot easier than fighting with Notepad to do it
I don't have a 328 chip to try it, but I believe this is what is needed.
uno.name=Arduino Uno with 328 <<<<<<<   added 'with 328'
uno.upload.protocol=arduino
uno.upload.maximum_size=32256
uno.upload.speed=115200
uno.bootloader.low_fuses=0xff
uno.bootloader.high_fuses=0xde
uno.bootloader.extended_fuses=0x05
uno.bootloader.path=optiboot
uno.bootloader.file=optiboot_atmega328.hex
uno.bootloader.unlock_bits=0x3F
uno.bootloader.lock_bits=0x0F
uno.build.mcu=atmega328            <<<<< removed 'p' at the end
uno.build.f_cpu=16000000L
uno.build.core=arduino
uno.build.variant=standard
