Topic: Sudden unreliability with my network-enabled Arduino project [SOLVED] (Read 19140 times) previous topic - next topic
domiflichi
Well, I guess I spoke too soon. I had to power-cycle my device again last Friday (April 12th). :(
I don't know what's going on in my garage, but it must be pretty bad. I think I mentioned it before, but I've had to power cycle some of my other electronic devices in the past. For instance, I have a network-enabled sprinkler system controller that I bought from rayshobby.net that I was always power-cycling, but after I put it on a UPS, I only have to power-cycle it only every couple of months. And come to think of it I have to power cycle my router and my network switches once in a while too.
This is really making me think that there's nothing really wrong with my device and that it's purely the power in my garage. Is there anything I can do to correct the power in my garage/house?
SurferTim
#61
Apr 18, 2013, 03:46 pm Last Edit: Apr 18, 2013, 03:50 pm by SurferTim Reason: 1
Your timing is good. I found a problem with the server code we were using. Here is a thread that covers a lot of this without having to duplicate all that.
http://arduino.cc/forum/index.php/topic,160048.msg1200379.html#msg1200379
and
http://arduino.cc/forum/index.php?topic=160912.msg1206332#msg1206332
Here is the server code with the timeout applied.
http://playground.arduino.cc/Code/WebServerST
Maybe that will take care of that pesky crash.
Sprocketq
In south west Florida they have really dirty power. I have customers with routers not on UPSs loose their configs all the time. For areas with bad power like that, I always recommend higher end APC UPS like Back-UPS Pro that has power conditioning, not only power loss support (corrects for over voltages and under voltages). That would of been one of my first steps after you stated that you have to reset network gear every so often.
I would also use a packet sniffer (wireshark) to confirm everything is working on the network side of the app.
domiflichi
Well after almost 2 years, I've found the problem of my issue!
The culprit(s)?:
and/or
(These are a couple Insteon smarthome Devices)
I don't know why I didn't think to try it sooner, but a few months ago, I just decided to pull the above 2 devices (sorry I don't know which one of the 2 is actually the cause of the problem, but once I do, I'll try to report back if anyone is interested) out of commission in my garage to see if anything improved. Sure enough, I had no problems with it after I removed them.
I created a post on my blog that talks about this a little more, but that was it! I just thought that everyone who helped me out with this deserves to know, and anyone who may have the same 'setup' as me may benefit from knowing this too.
Thank you very much to all who generously helped me out in troubleshooting this long-standing problem!
