Loading...
Pages: [1]   Go Down
Author Topic: [Patch] Recently opened files patch for Editor  (Read 740 times)
Offline Offline
Newbie
View Profile
I've always wanted a feature to be able to pull up recently opened files.  Here is a patch that adds this to the File menu of the editor:
  https://github.com/ericzundel/Arduino/compare/open-recent
Created an issue in the google code issue tracker:
http://code.google.com/p/arduino/issues/detail?id=979
EDIT: This patch is broken (I broke it when I added truncating file names), see below
« Last Edit: July 10, 2012, 10:10:31 am by ericzundel » Logged
Leeds, UK
Offline Offline
God Member
Once the magic blue smoke is released, it won't go back in!
View Profile
WWW
Quick question, how do you apply the patch?
Logged
~Tom~
Offline Offline
Newbie
View Profile
Hi Tom,
I don't know what your background is, but to give a broad outline, you have to apply to the java source downloaded from github then rebuild the Arduino project.
http://code.google.com/p/arduino/wiki/GitandGithubGuideforArduinoDevelopment
To apply the patch, use the 'patch' command from the command line on unix, or cygwin.  Or you can use the command 'git apply'
Typical usage would be:
$ cd <root of the source tree>
$ patch -p1 open-recent-file.patch
Then use 'ant' to re-build the project.
You could also pull the branch I posted from github just compile it if you just want to see what it looks like.
Logged
Offline Offline
Newbie
View Profile
Updated patch attached. Previous version saved filename with '...' characters in it, which you couldn't re-open, of course.
Logged
Pages: [1]   Go Up
Print
Jump to:
