Topic: avrdude: verification error; content mismatch (Read 3490 times) previous topic - next topic
chrishjones
Binary sketch size: 45290 bytes (of a 258048 byte maximum)
avrdude: verification error, first mismatch at byte 0x0308
         0x62 != 0xff
I found the offending code but can't figure out how it's broken. I've converted a png to hex and have it in PROGMEM. It's an icon that I'm going to display on a touchscreen. I have another icon that works fine.
Here's the relevant code:
The weird thing is that I have another icon I'm displaying the exact same way and it works fine. It compiles and uploads successfully. Once the code is uploaded it appears to still be running the old program and the reset button the arduino doesn't work. If I pull the USB and reconnect I get a blank screen and nothing in the Serial monitor. If I comment out just the prog_uint16_t it all works fine.
Code: [Select]
// after headers
extern unsigned int glovesicon[4096];
myGLCD.drawBitmap(120,110,59,60,glovesicon);
prog_uint16_t glovesicon[4096] PROGMEM={
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0010 (16) pixels
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0020 (32) pixels
......removed
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFFFF,   // 0x0300 (768) pixels
johnwasser
Too many 0xFF's.  AVRDUDE, the program that uploads sketches, assumes that memory is full of 0xFF (has been erased).  If it sees that a page to be written is full of 0xFF it doesn't bother to send it.  Unfortunately the Arduino upload doesn't do a Chip Erase first so whatever garbage was left in FLASH is still there for the verification.
I don't know how to work around the problem.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
chrishjones
All those 0xFFs are probably white pixels. Maybe if I change the background of the image to slightly off-white it'll fix it??
chrishjones
Changed it to a black background and it minimizes the 0xFFs and it worked fine. Thanks for the help.
