Topic: Help for MIDI Library v3.2 (Read 3646 times) previous topic - next topic
phm78
Hello,
I use the MIDI library version 3.2.
No problem to send and receive message noteon, noteoff example.
No problem to send sysex messages (f0, ......., f7).
But I do not understand how to read the sysex messages.
How should we declare the variables (ARRAY)?
How call the function MIDI.getSysExArray()?
Thank you for your help.
Philippe
robwlakes
Hi Philippe,
I did not know about the MIDI library version 3.2.
Where did you find that?
Rob
Learning Flute and C++, heading for a meltdown.
robwlakes
Hi Nantonos, I have had a quick look at the project and while I think it looks like an excellent standard of coding, it still does not handle what I am after.  Correct me please if I am wrong, but this library either can process incoming midi-streams on the fly or generate them itself.  What I was after and still after is a library devoted to reading a stored midi file and parsing it, and being able to extract the number of beats from the start of the tune, and then begin the tune at any such point and finally stop on a predetermined beat as well.  OK for example, load midi file, play tune from bar 12 to 15 and stop.
This I believe introduces the challenge of calculating the state of the midi parser at a certain point in the tune so it can be loaded with that state to begin there, or alternatively parse it up to that point and preserve the state as found at that point and then use that state to pre-load the parser?
I have a program which achieves quite a lot of what of what I am after, but my programming style is poor and while it works the program is increasingly difficult to work with.
Have you heard of any similar project to mine?  Or have I misread what your project could provide me in the way of a well written library?
Nantonos
#4
Sep 23, 2012, 06:32 am Last Edit: Sep 23, 2012, 06:23 pm by Nantonos Reason: 1
A clarification - I posted the links because I saw you asking about the library. I didn't write it; I'm just a user of it.
I agree that the MIDI analysis and modification that you are working on would not be helped by this library.
In terms of state, you would need to keep track of any notes which have started, but not yet stopped, at the start time of the section you want to play; and similarly allow any notes which are still on at the end of the section to continue, and stop. You would also need to track the most recently modified value of any control changes.
Effectively, you are generating a 'section start state' MIDI file, which you play, followed by the actual MIDI section from the original file.
robwlakes
Damn just composed a reply and hit some mysterious key and lost it.  Thank you for your posting, however you are one the few people who has been able to reiterate my challenge clearly and acknowledge the key problem of determining the state of the tracks' musical rendering at the start of the nth bar.
I am learning flute, mainly Baroque pieces at the moment.  Excellent for technique my music teacher tells me.  However I do not have a ready source of youtube material to groove along with to provide me with backing material for duets etc.  I don't mind entering the music myself into midi format as it is very versatile (ie can alter tempo without changing pitch, and achieving/modelling accurate pitch is very important for flute). However I don't know of a midi player that permits the operator to begin at the nth bar and play to the mth bar, over and over.  I would like to be able to play the harder subsections of a tune and have the accompaniment work in with that, and play it at slower tempo at first so I don't practice in errors.
A number of problems have become evident.  First is that the composing software introduces rounding errors into the delta delays and then the parser also adds small errors so that the parser eventually drifts away from the exact beat.  I discovered this when I added an automatic metronome beat based on the tempo calculations and found the parser was about a whole beat out by the end of a longish tune with many small beats.  Not only that but the multiple tracks were drifting at slightly different rates and the first notes in a bar were not necessarily going to have exactly the same timings, especially at the end of a longish piece.  I tackled this by adding a quantizing routine that aligns the timing of any first note in a bar to the calculated start of the bar, ie not what the delta wait time dictated (generally delta-times run a little too quick, and when a first note in a bar is detected it needs to be given the Bar time, rather than their own delta time, which causes them simply to have to wait a bit longer before playing - this can occur at different times on the different tracks!).  This brought the beats back to strict tempo and made it easier to determine what was happening midi-wise and music-wise at a particular bar.  I could then calculate the exact time of a particular bar. The drift is not as significant between tracks as the errors probably cancel out to a large extent and the tracks remain relatively "in time" as far as our ears are concerned.
The second major problem was the number of tracks that needed each state captured, and given that each midi track is stored in sequence in separate blocks and not interleaved, means that each tracks needs its own state stored.  The pointers into each track do not have a simple numerical relationship that ensures synchrony of events in absolute sense.  So I have an array of 16 arrays for each possible channel to store these states.  The idea being that I can use these states to begin the tune at that point once it has been captured?
Given that the midi file will most likely have multiple tracks, and each track with their own individual drift that needs correcting, (to even know what is in a bar and what is not, some form of quantizing will have to take place), means to me that I must do a sort of "Silent fast forward parsing" where the file is parsed in real time, but without the Arduino Mega2560 talking to the Fluxamasynth board, and the corrected-delta-times not being enacted until the nth bar is reached whereupon a snapshot of the parser's state is taken and this is used as the new starting point.  Click the IR remote and voila the tune begins.... if you get my drift.
I hope I have not bored you to tears, and that if I have made some fundamental blunder in the logic you can help me out.  Am I on the right track?  (Please excuse the indulgence in the pun, couldn't resist it  :))
crlMidi
Hello,
I came across this thread while looking for something else.
It prompted me to post - very much prematurely - a sketch that does Roland sysex: http://www.music.chrblee.net/tuningaid/index.html. Since I did that I discovered how to attach files to a post on this forum. The code is definitely not for the eyes of Inspector TidyCode, but it works. Well, it started working this afternoon.
One thing I forgot to mention is that if you send a sysex Data Request to a Roland JV, the response lacks the final F7. This might be troublesome if you locate the data you want by its distance from the end of the array. Perhaps I should configure the brilliant MIDI.h, as proposed, to insert the F0 and F7 automatically.
Another thing, if you send a Data Set sysex, make sure you put in a delay (Roland says 20ms, a source on the web says 40). The JV responds with some junk, perhaps to make sure you remember this.
Finally, the best way to use a MIDI shield with a Mega is to snip off the two serial (0) pins, and connect the shield to serial1. You need serial0 to see what your code is getting up to...
