Global Moderator
Dallas
Offline
Shannon Member
« Reply #30 on: July 12, 2012, 02:46:35 pm » |
explain why the manufacturer puts such was wide range on possible convertion times 13/125000*1000000 ...13 clock cycles / 125000 clock cycles per second * 1000000 microseconds per second. The 125000 can be configured and depends on the processor's clock rate.
Logged
Global Moderator
Dallas
Offline
Shannon Member
« Reply #31 on: July 12, 2012, 02:56:32 pm » |
Consider what happens if the first approximation just happens to match the input data within the required resolution. The comparator output shows conversion is finished. Nope. The comparator indicates less-than or greater-than but not equals. AWOL is correct. One clock cycle per bit plus a few for overhead. I suppose you also think that quicksort also takes exactly the same number of iterations irrespective of the data it is sorting. Why do you mention quick sort? It's a successive approximation converter not a quick sort converter. Now since that is roughly midway between 13 and 250 us , perhaps the "typical" conversion time is indeed 13 clock cycles or 104 us . A conversion is always 13 clock cycles (25 after changing channels).
Logged
New Hampshire
Offline
God Member
There are 10 kinds of people, those who know binary, and those who don't.
« Reply #32 on: July 12, 2012, 03:34:59 pm » |
void setup() { Serial.begin(115200); unsigned int maxReadTime = 0, minReadTime = 1000, singleReadTime, ReadVal; unsigned long AccumulatedTime = 0; ReadVal = analogRead(A0); for(int x = 0; x < 1000; x++) { singleReadTime = micros(); ReadVal = analogRead(A0); singleReadTime = micros() - singleReadTime; AccumulatedTime += singleReadTime; if(singleReadTime > maxReadTime) maxReadTime = singleReadTime; if(singleReadTime < minReadTime) minReadTime = singleReadTime; } Serial.print("Min: "); Serial.println(minReadTime); Serial.print("Max: "); Serial.println(maxReadTime); Serial.print("Avg: "); Serial.println(AccumulatedTime/1000); }
void loop() { }
Running that code, I get the following output (thereabouts anyways, there is some occasional variation) Min: 112 Max: 124 Avg: 116 Comment out the initial analogRead, and you'll see Max jump to around 212, which nicely correlates with the 25 cycles for the initial conversion. There is simply no rational arguing with empirical data.
Logged
Offline
Full Member
« Reply #33 on: July 12, 2012, 04:16:24 pm » |
jraskell, what was the input signal for that test?
Logged
Global Moderator
UK
Online
Brattain Member
I don't think you connected the grounds, Dave.
« Reply #34 on: July 12, 2012, 04:34:28 pm » |
Do you seriously think it matters? I suppose you also think that quicksort also takes exactly the same number of iterations irrespective of the data it is sorting. No, that would be foolish. Think, it's a RISC processor, and an extremely low cost one at that. Ever seen quick sort or anything similar implemented in RISC hardware? Thought not. Yesterday I deleted a post by a user on this thread that I thought was inflammatory, but now I'm beginning to see the truth in it.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Global Moderator
Melbourne, Australia
Offline
Shannon Member
Lua rocks!
« Reply #35 on: July 12, 2012, 04:46:50 pm » |
If you can't I suggest you learn some better manners before threatening people with mallets.
It's a Ban Hammer, not a mallet. Here, read about them: http://en.wikipedia.org/wiki/Ban_hammer
Logged
Global Moderator
Offline
Shannon Member
Lua rocks!
« Reply #36 on: July 12, 2012, 04:49:47 pm » |
Now that's insulting, in case you don't realize it. A quicksort is mathematical operation in a sequence of data points. Clearly it will not run in fixed time. The initial permutation of the data to be sorted would affect it. We are discussing the behaviour of some computer hardware here, hardly the same thing.
Logged
New Hampshire
Offline
God Member
« Reply #37 on: July 12, 2012, 04:54:31 pm » |
Input signal doesn't matter. Tie it to ground, to 5v, set up a voltage divider with a pot. The results won't vary.
Logged
Global Moderator
Offline
Shannon Member
Lua rocks!
« Reply #38 on: July 12, 2012, 05:01:38 pm » |
I ran jraskell's test above, feeding in a sine wave of 100 Hz from 0 to 5V from the function generator. The values detected are printed so you can see they are not all the same. I added noInterrupts () and interrupts() around the analogRead so a timer interrupt would not throw out the results. Output: 752 830 897 949 981 995 989 964 919 857 781 695 599 501 403 309 223 149 89 52 28 16 18 35 64 105 171 249 336 430 532 629 721 806 876 932 972 993 993 973 935 880 807 727 635 536 438 342 254 170 88 43 20 19 39 83 142 244 362 490 620 741 846 926 978 997 979 929 850 745 624 495 366 247 146 72 33 16 20 50 97 165 269 390 520 648 767 868 942 986 995 970 912 825 716 591 461 333 219 125 57 26 16 28 63 118 210 323 449 578 703 814 905 966 994 987 947 876 780 663 533 402 280 175 90 44 20 16 37 76 137 235 352 480 611 733 840 922 975 995 980 932 853 750 630 501 373 253 151 76 36 17 21 47 95 159 264 385 514 643 762 863 939 983 995 972 916 832 722 600 470 342 224 129 60 27 15 26 59 111 203 316 442 572 697 809 900 962 993 989 951 882 784 669 542 411 288 179 94 47 21 16 34 73 132 229 346 473 602 725 833 919 973 995 983 936 860 759 639 508 379 258 156 79 37 17 19 44 90 154 255 378 504 635 756 858 935 982 995 975 921 836 729 607 477 350 232 136 64 30 16 25 55 108 196 307 432 562 690 803 896 960 992 991 955 888 792 676 549 419 294 186 98 51 22 16 32 70 126 223 339 466 597 720 829 913 970 995 984 940 865 764 647 517 388 267 162 82 40 17 17 41 85 148 249 369 497 626 747 851 931 979 995 975 924 842 738 616 484 356 238 139 67 31 16 24 53 105 191 301 426 556 682 797 890 957 991 991 957 891 799 685 558 425 300 190 103 43 19 16 37 78 139 238 355 483 613 735 841 924 976 995 980 931 853 750 629 499 368 249 148 73 34 16 20 48 95 163 265 386 515 643 765 865 940 984 995 970 915 830 719 596 466 338 223 127 59 25 15 27 60 114 204 318 444 573 699 813 902 964 993 989 950 880 784 668 539 408 285 178 95 47 21 17 35 76 134 230 346 477 606 729 836 919 973 996 983 935 857 755 636 506 378 257 156 77 36 17 20 46 92 158 258 380 508 637 757 859 935 983 995 973 919 835 728 605 476 346 229 133 63 29 15 26 57 108 199 311 436 566 692 805 896 960 992 989 952 885 789 674 546 417 290 182 97 49 22 16 33 70 129 225 340 468 597 720 831 916 972 995 984 939 864 763 642 513 385 263 160 82 39 18 20 42 87 149 251 370 501 631 751 854 932 980 995 976 922 840 735 612 483 355 237 139 65 31 15 24 54 106 192 302 427 560 686 799 892 958 991 991 956 888 795 681 554 424 299 190 103 43 19 18 38 80 140 240 357 485 617 738 844 924 975 995 980 930 850 746 625 496 367 248 147 72 33 16 22 48 98 162 268 389 519 648 766 865 941 984 994 969 912 827 718 595 465 337 221 125 58 26 15 26 61 115 206 320 446 577 702 813 902 964 993 988 948 877 781 664 538 406 283 175 92 46 20 16 36 76 135 234 351 479 608 731 838 922 975 996 981 934 857 754 634 503 373 254 152 76 35 17 20 46 92 157 259 380 509 639 759 861 937 983 994 973 918 832 725 601 472 344 228 132 61 28 15 26 58 111 201 313 438 568 696 808 899 963 993 989 952 884 786 671 544 414 289 182 96 49 21 16 34 73 130 225 343 470 601 724 832 916 972 995 983 937 863 761 642 512 383 262 160 79 38 18 19 44 89 153 255 375 503 632 752 855 932 981 995 975 920 838 733 610 479 351 233 136 64 30 16 25 55 106 195 306 431 561 686 801 893 958 991 990 954 887 793 679 552 420 296 187 100 42 19 17 39 81 142 243 361 489 618 740 845 926 977 995 978 928 849 744 623 494 363 245 145 70 32 16 22 50 98 166 270 391 521 648 767 868 943 985 994 969 912 825 714 590 461 333 219 124 56 25 15 28 62 117 209 321 448 578 703 816 904 965 993 987 947 876 778 660 533 402 280 174 91 45 20 17 36 78 137 235 352 482 612 734 841 923 975 996 981 932 854 751 630 501 372 253 152 74 35 17 21 47 94 160 264 385 514 642 761 862 938 984 994 971 915 831 722 599 470 342 225 129 60 27 17 27 60 112 204 315 442 572 697 809 900 963 993 988 951 882 785 669 542 413 286 179 94 47 21 16 34 73 134 229 346 473 603 725 834 919 973 994 983 937 860 758 639 508 379 259 156 78 37 18 20 44 91 154 254 375 505 635 755 857 934 981 996 974 920 837 730 607 478 350 232 135 63 29 16 25 57 108 197 308 433 565 691 804 Min: 108 Max: 116 Avg: 113
Good distribution around the average. It's more than 104 but it would take a few cycles to get the time, save the analogRead result, etc. I also did a version which toggled a pin and checked with the logic analyzer. Indeed, there is a small variation (agreeing with the above figures). So we really need to ask: why 108 to 116 (difference of 6) and not just 113 every time? Well, back to the datasheet (page 253): When initiating a single ended conversion by setting the ADSC bit in ADCSRA, the conversion starts at the following rising edge of the ADC clock cycle. OK, so since "a cycle" in this case will be 8 uS we can see a range will be required (maximum 8) because we are looking for that rising edge of the ADC clock. So it would be fair to say the analogRead will take 104 uS plus up to 8 uS extra depending on where the ADC clock is when the conversion starts. However, not at all data dependent.
Logged
Global Moderator
Offline
Shannon Member
Lua rocks!
« Reply #39 on: July 12, 2012, 05:06:07 pm » |
You didn't delete my Ban Hammer, I notice.
Logged
Offline
Full Member
« Reply #40 on: July 12, 2012, 05:53:04 pm » |
http://www.maxim-ic.com/app-notes/index.mvp/id/1080having researched this a bit, it is indeed one cycle per bit as someone pointed out above. I was mistaken in thinking the conversion time of succ. approx depended on the data. Thanks to Nick for demonstrating with full scale input. 9.1.5 ADC Clock – clkADC The ADC is provided with a dedicated clock domain. This allows halting the CPU and I/O clocks in order to reduce noise generated by digital circuitry. This gives more accurate ADC conversion results.
ADC Noise Reduction Mode When the SM2..0 bits are written to 001, the SLEEP instruction makes the MCU enter ADC Noise Reduction mode, stopping the CPU but allowing the ADC, the External Inter- rupts, the Two-wire Serial Interface address watch, Timer/Counter2 and the Watchdog to continue operating (if enabled). This sleep mode basically halts clkI/O, clkCPU , and clk- , while allowing the other clocks to run. FLASH Atmel state that the CPU clock can be halted for noise reduction mode while doing ADC. So it is not using the CPU clock. That still leaves the question of what this means: 24.1 Features • 10-bit Resolution • 0.5 LSB Integral Non-linearity • ± 2 LSB Absolute Accuracy • 13 - 260 μs Conversion Time • Up to 76.9 kSPS (Up to 15 kSPS at Maximum Resolution)
76.9k seems to match 13us , that means adc clock of 1MHz based on 13 cycles. but what does the proviso "at Maximum Resolution" imply? What is the resolution at 76.9 kS/s ? Why the "up to" ? Does this mean those speeds can be obtained reliably using maximum cpu clock and minimum adc divider ratio. Perhaps "upto" just means if the cpu is not loaded doing anything other than the sampling.
« Last Edit: July 12, 2012, 05:56:02 pm by ardnut »
Logged
Global Moderator
Offline
Shannon Member
Lua rocks!
« Reply #41 on: July 12, 2012, 06:00:21 pm » |
You need to read that statement carefully. The clock is running ("while allowing the other clocks to run") but the CPU is not being clocked from it. Let's put it another way. There is a basic clock, which could be the crystal or the internal oscillator. Other clocks are derived from it. With the CPU asleep the clock is running (in some modes anyway) but the CPU is not being clocked from it. However (in this case) the ADC is still being clocked. So it is not "using the CPU clock" per se, but it is using the CPU clock rate. So, the fundamental clock rate, used by the CPU, is also used by the ADC. (There is also a secondary clock for the watchdog timer).
Logged
Global Moderator
Offline
Shannon Member
Lua rocks!
« Reply #42 on: July 12, 2012, 06:31:15 pm » |
As for your other questions, for maximum resolution we appear to need an ADC frequency of 50 kHz to 200 kHz, and the default prescaler (set in init) of 128 is the only one that falls in that range (125 kHz). The next prescaler (64) would give use 250 kHz which is too fast.
I can't really see where they say what resolution loss you get at higher frequencies, except page 323, which appears to indicate that a (ADC) clock rate of 1 MHz would give an error of 4.5 bits.
Logged
Offline
Full Member
« Reply #43 on: July 12, 2012, 06:59:46 pm » |
Thanks, I just found that. 23.4 Prescaling and Conversion Timing
By default, the successive approximation circuitry requires an input clock frequency between 50 kHz and 200 kHz to get maximum resolution. If a lower resolution than 10 bits is needed, the input clock frequency to the ADC can be higher than 200 kHz to get a higher sample rate.
Seems the 250us figure comes from the _slowest_ acceptable ADC clock of 50kHz that will give full 10b resolution, so that explains that part. 13us is the 1MHz clock but outside the range giving 10b resolution. 200kHz x 13 = 65us would seem to be the fastest 10b sampling freq. sounds like this is the freq limit of required accuracy from the comparator, so running at 250kHz (52us) would probably introduce some small additional error (prob < 1LSB ?) into the conversion. So to get full spec it looks like we're limited to the 104us figure you originally stated as the only "choice". Thanks for you help in getting to the bottom of all this.
Logged
