Topic: what about debugging? (Read 11129 times) previous topic - next topic
ardnut
I seem to find little mention of debugging techniques here.
Is the arduino IDE simply a compile and upload facility?
avrdude allows access to flash and EEPROM but not the volatile memory it seems.
There does not seem to be any access to RAM and the registers which is necessary for any serious development.
Playground mentions debugging but only in the context of Visual Studio it seems.
So what are the options for full debugging in this environment?  I was under the impression that AVR allowed development platform free from expensive development kits and hardware.
Maybe I'm just not looking in the right place but there seems oddly little talk of how to do debugging here.
Thanks for any pointers.
AWOL
You're working on a tiny, slow microcontroller with limited memory, but with largely well-tested libraries.
How much serious debugging do you envisage?
(FWIW, I work on much faster processors, with very many times more memory, more, complex peripherals yet still use pretty much the same techniques to debug as I use on the Arduino)
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
wildbill
Basically, you're back to the world of the 80s. Printf (Serial.print), logging to a file (if you have an SD card) are your primary tools. Forget breakpoints, watching variables etc. If use of the serial port impacts your program's timing too badly, you have I2C and SPI. Lighting LEDs is used as a low impact debugging indicator, though it obviously doesn't tell you much. Signal analyzers and Oscilloscopes can help too.
Consider this though: the code you'll write for most arduino sketches isn't going to be that complex usually, so debugging them even without the fancy IDE tools, isn't especially difficult if you know what you're doing.
If you really want that stuff, take a look at the netduino: C# and a fully functional debugging IDE.
ardnut
The libraries may be well tested but my use of them is not. If something does not do what I expect I need to look to see why not rather than just have another stab in the dark upload.
I'm not aiming to use the hardware to flash LEDs on and off, I need to control external hardware real time, reading ADC ports, monitoring the state of the external hardware and outputting control signals.
I would expect to do this by setting break points and checking registers etc.
"yet still use pretty much the same techniques to debug as I use on the Arduino"
Which is what in the most simple terms, print to serial port?
thx
AWOL
Quote
Well, it's a very, very fast serial port, but yes, pretty much that's what we do.
Graphics, DSP, I/O (lots of I/O), all get debugged through the serial port.
I haven't debugged with any kind of ICE in over ten years.
bperrybap
Yep, pretty much.
Quote
For any real sort of real debugging (which I assume you mean at the source level with variables, break points etc...)
you will want to use gdb or some GUI wrapper around it.
And to do that you will probably want/need to use makefiles to make sure you set
up everything the way you want it.
The Arduino IDE is simply too wimpy and didn't use Makefiles underneath so it is pretty
painful to use the debugging tools with the Arduino IDE.
You can choose to abandon the IDE (there are some makefiles out there that come close to working similarly)
or leave Arduino and its libraries behind and write your own code using avr gcc with makefiles,
or use AVR studio
You can use AVR studio if you are still using windows and want a GUI solution for Windows based OS's.
Alternatively you could use something like eclipse - I think they have some Arduino plugins now.
You will also then need some additional hardware that can access the chip on behalf of the
debugger. The AVR dragon is probably the most cost effective device for source level debugging.
It can use the ISP port, JTAG pins,  or can use the reset line (debug wire mode) to access the internal chip resources.
Debug-Wire is very cool as it only uses a single pin that usually is not used for anything else anyway.
As far as "back to the world of the 80s" type debugging goes.
Boy do I wish it was that good on the AVR. By the late 80's gdb was already fully
working in many embedded environments
and true source level debugging with breakpoints and access to variables
was easily accomplished over a serial port
with the simple addition of a gdbmon to your embedded target code.
Today, on the AVR, life is not so simple nor as good. The Harvard architecture really throws
a wrench in things, (much of this issue has work arounds) but as far as having a gdmon goes
that allows source level debugging over a serial port goes, it is non existent.
There are some technical issues in making something like a gdbmon interface fully work
on the AVR so at this point everyone that wants
source level debugging is using a h/w tool that can be controlled by a debugger - usually gdb.
Tools like the AVR dragon or JTAGice are used. This is what avr studio and packages like DDD use)
I've often thought about doing a gdbmon for the AVR. Break points and single stepping
can be made to work but are ugly under the hood as you have to steal one of the interrupt pins.
I've just not had the time and an AVR dragon using debug-wire is actually better anyway.
For now, you are kind of stuck with a few options.
- use IDE "as is" and revert to using primitive debugging techniques like
"printf()", toggling pins, LEDs, etc...
- switch over to a more advanced build/development environment and use a h/w debugging tool
If you switch build environments, you will have to decide if you want to stick with
the Arduino s/w environment or leave it behind as well.
If using a windows platform, AVR studio is a pretty nice tool set and offers full debugging
as well as a simulator.
You could use AVR studio with some "Arduino" makefiles to allow using AVR studio and its
debugging tools with the Arduino s/w environment and libraries.
You can also ask questions over on the AVR freaks site about AVR (non Arduino) development:
http://www.avrfreaks.net
For realtime runtime debugging even having a source level debugger may not help.
For example you may need to see a certain stream of events in real time.
A break point won't help in that situation as it halts the processor.
For sure anything like a serial port transfer will kill the realtime timing.
kiss i2c goodbye it is WAY slower than a serial port, even SPI can be too slow.
For these situations, I use multiple output pins and a logic analyzer.
You can assign an event to a pin or use a collection of pins along with a "strobe" indicator pin
to indicate the event. On the AVR, this allows indicating an event in as little a single AVR clock cycle
since if you pick your pins carefully you can update them all in a single write to the port register.
This is very unobtrusive to timing.
I've used this output pin strobing technique on many systems over the past 30 years especially for very
realtime systems where you simply can't do much of anything or something bad can actually happen
(like corrupt the format of the hard disk - in the case of disk controller)
It is very easy to implement, uses a very small amount of code in the target
and gives you realtime visibility into the code flow.
It is great for profiling routines as you can do strobes around portions of code to time it.
--- bill
Graynomad
Until recently I've used two spare pins and a logic analyser for low intrusiveness and printf if I can afford the time. I have felt no real need for a debugger.
That said, over the last two days I've been working on a system with full debugging capability and it's been a dream. For example I had a hard fault exception, the debugger showed the stack frame so I clicked on the last executed line of code and immediately found a bad index into an array of function pointers. That would probably have taken half an hour of dicking around placing pulses to see how far the code got etc.
I still plan to use the pin-pulse method for time-critical stuff, but apart from that I'd say "Use a system that allows real debugging". Hopefully the new Due will.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
Nick Gammon
That is usually my first fallback. Then there are other methods:
http://www.gammon.com.au/forum/?id=11329
It's all very well setting breakpoints etc. but often this sort of imbedded microcontroller is doing something timing-dependent, and setting breakpoints doesn't really help with that.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
Frisky
I've been spoiled with AVR Studio and JTAGICEmkii for so long before Arduino. I like to use simulate or monitor what going on if I feel that something is not happening correctly. I made a simple SPI pod for my logic analyzer it has helped me. Serial.print is very useful too.
Setting and clearing output also.
Don
ardnut
Thanks Bill, that's exactly the kind of detailed information I was looking for.
It seems calling the Arduino IDE an IDE is over selling it a bit. The "I" in IDE stands for integrated. The integration being that of code generation and debugging.
Nick Gammon
Can you oversell something that is free?
Check this out:
http://arduino.cc/en/Main/Software
Quote
The open-source Arduino environment makes it easy to write code and upload it to the i/o board.
It claims to be easy to write code and upload it. Which I believe it achieves.
More info:
ardnut
Frisky:
Quote
JTAGICE can run atmega168 and atmega8 , both of which can run in the UNO , as far as I have been able to determine.
JTAGICE is not cheap ($300) but that would provide one route to having a full debugging evironment for Arduino, unless I'm mistaken.
ardnut
Quote
Overstating it's capabilities if you prefer. I don't consider something with no debugging capability to be an IDE Though if you want to be pedantic you could always say the have "integrated" code generation and an uploader.
For what it does it seems to be a pretty good tool. But calling it and IDE is rather misleading.
Nick Gammon
My point was that on that page the letters IDE only appear once ("Previous IDE Versions"). It represents itself as "The open-source Arduino environment".
More info:
JimboZA
We mustn't lose sight of Arduino's provenance and original purpose, which (at least as I see it) was to let a bunch of lay folk write code and get it into a processor in a bit of a quick-n-dirty way so they could make stuff happen in the real world. And today my daughter- who would never otherwise have developed any kind of interest for this stuff- does exactly that when she writes simple C code to drive her 2-motor Magician chassis with an Uno and a MotoMama board.
That said, it has of course evolved and seems to have become a genuine embedded control platform used by professionals. Professionals need better tools than amateurs like 16yo schoolgirls, since they have time constraints and get paid to make stuff quickly and cleanly (not quickly and dirty  8) ).
So perhaps there's place for a (maybe even no longer free?) Arduino IDE-Pro to sit alongside the current and always free Arduino IDE-Am
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
